Question about Panasonic (KX-TG1032S) Phone
Toll saver does not work. Ring count set to 4 rings
The toll saver feature does not work. The ring count is set to 4 which shold default to 2 when there are new messages. It always rings to 4 with new messages or not.
I've unplugged the unit and re-plugged it in more than once hoping it would re-set properly. Nothing seems to help.
Any ideas?
"2 rings" or "4 rings" (the default) are not "toll saver". You need to set the ring count to “toll saver”.
On the handset
1) Press Menu
2) Scroll down to Answering Device then press menu
3) Scroll down to Settings press menu
4) Scroll down to Ring Count press menu
5) Scroll up to “toll saver” and then press menu
Posted on May 07, 2009
  • Ms Billie Jansky
    Ms Billie Jansky Jan 27, 2014
    We have a Dect 6.0 with BU50067496 and the information given does NOT help!
  • Ms Billie Jansky
    can there be a live chat so I get the help I need.
My voice mail doesn't work. I cannot get more than 2 rings on my incoming calls.
Press.MENU/SELECT > Ans. Setup menu > Ring Time submenu
Select a Ring time - Toll Saver, 2, 4 or 6 rings. Press MENU/SELECT once again to get a confirmation tone. The Toll saver setting is for if you are checking voicemail on a Long distance call, the call rolls over to the voicemail immediately if there are new messages
Dec 11, 2014 | Uniden DECT 6.0 Cordless Phone ID
My att cellphone only rings 4 times before voicemail
If the problem is with an AT&T cellphone you will need to call them or go log in online to change that feature, however if it is with a Uniden Cordless Phone (the product this question is linked to) the directions below found in their manual should help:
From the base
1) Press [clock/menu] three times. The base displays the current number of rings (2, 4, 6, or TS for toll saver) and announces the setting.
2) Press [>>/select] or [<</select] until the desired ring time appears.
3) Press [set]. A confirmation tone sounds, and the answering machine announces the new ring time.
From the handset
1) Press the MENU soft key. Select the ANSW. SETUP menu, and then the RING TIME submenu.
2) Move the cursor to select a Ring Time (2 TIMES, 4 TIMES, 6 TIMES or TOLL SAVER).
3) Press the OK soft key. You will hear a confirmation tone.
Hope this is of help
May 05, 2014 | Uniden Cordless Phone
Panasonic number ring
Answering system settings
Number of rings before the unit answers a call.You can change the number of times the phone rings "Ring count"before the unit answers calls. You can select 2 to 7 rings, or "Toll saver".The default setting is "4 rings"."Toll saver": The unit's answering system answers at the end of the 2nd ring when new messages have been recorded, or at the end of the 5th ring when there are no new messages. If you call your phone from outside to listen to new messages (page 34), you know that there are no new messages when the phone rings for the 3rd time. You can then hang up without being charged for the call.
Jan 16, 2014 | Lands Phones
I can not locate how to limit the number of rings; and the answering machine does not come on even after 20 rings; I can hear my message recording- when I play it back; but it does not come on for incoming...
Ring count You can change the number of times the phone rings before the unit answers calls. The default setting is "4 rings". "Toll saver": The unit answers on the 2nd ring when new messages have been recorded, and on the 4th ring when there are no new messages. If you call your phone from outside to listen to new messages, you will know that there are no new messages when the phone rings for the 3rd time. You can then hang up without being charged for the call.
1 {MENU} 2 {V}/{^}: "Answering device" i {OK} 3 {V}/{^}: "Settings" i {OK} 4 {V}/{^}: "Ring count" i {OK} 5 {V}/{^}: Select the desired setting. 6 {OK} i {OFF}
MANUAL http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf
HOPE IT HELPS GILES102
Jun 27, 2011 | Panasonic KX-TG1033S Cordless Phone
My hp 1040 will not pick up fax after the fifth ring answering machine picks after forth ring can't tell the between phone call or a fax used to before changed date on answering machine fax quite working
Set rings to answer
You can select the number of rings that will occur before the fax answers an incoming call. If you are using your machine as both a telephone and a fax machine, we suggest you set the ring count to at least 4 to give you time to answer.
TIP: HP 1050 Fax: The Toll Saver function for the Digital Message Center interacts with Rings to Answer. See Toll Saver on page 40. If you have the HP 1050 Fax and have Toll Saver turned on, set the Rings to Answer to 2.
1. Press Menu repeatedly until BASIC FAX displays and press Start/Enter.
Rings to Answer will display.
2. Press Start/Enter.
3. Enter the number of rings you want (2-7) and press Start/Enter.
The HP Fax rings the set number of times and then answers. It then produces a different sounding ring to alert you to which type of call is incoming.
• The additional ring may occur once for a fax call
• The additional ring occurs 5 times for a voice call. After the 5 additional rings, the answering machine will answer.
Dec 08, 2010 | HP 1040 Plain Paper Inkjet Fax
How do you set the number of rings?
Ring Select and Toll Saver
Use Ring Select to choose how many times
the line will ring before the system
answers a call. Set for 2, 4 or Toll Saver.
When you set the system for Toll Saver, it
answers after four rings when you have no
new messages, and after two rings when
you have new messages.
1 Press and hold S for about two
seconds. The system announces the
current ring selection.
2 Press and release or
until the system announces your ring
selection.
3 Press and release P to exit
— OR —
Press and release S to change the
Remote Access Code (follow Steps 2–5
under “Remote Access Code”).
Here is the manual:
http://telephones.att.com/docMgt/public/art/162/1717_manual.pdf
Nov 22, 2009 | AT&T 1717 Digital Answering Machine
How to set number of rings
1. Press and hold "set up" for about two
2 Press and release "ANNC/SKIP" or "MEMO/REPEAT"
selection.
3 Press and release "Play/Stop" to exit
Jan 21, 2009 | AT&T 1717 Digital Answering Machine
Can not set no of rings on old sprint answer machine SP818 please help
Use Ring Select to choose how many times the line will ring before the
system answers a call. Set for 2, 4 or Toll Saver. When you set the
system for Toll Saver, it answers after four rings when you have no new
messages, and after two rings when you have new messages.
1. Press and hold [SET UP] for about two seconds. The system announces
the current ring selection.
2. Press and release [ANN/SKIP] or [MEMO/REPEAT] until the system
announces your ring selection.
3. Press and release [PLAY/STOP] to exit
-OR-
Press and release [SET UP] to change the Remote Access Code (follow
Steps 2-5 under "Remote Access Code").
Oct 01, 2008 | Lands Phones
Number of rings before recording answers
Choose how many times the line will
RINGS IS...” ring before the system answers a call.
• Set for 2 to 7 rings, or choose
Toll Saver 2/4 or Toll Saver 4/6.
• When set to Toll Saver 2/4, the system
no new messages and after two rings
when you do. Toll Saver 4/6 causes the
system to answer after six rings when
you have no new messages and after
four rings when you do.
• During setup, the Message Window will
display the number of rings (8 for Toll
Saver 2/4, or 9 for Toll Saver 4/6).
Sep 05, 2008 | AT&T 1738 Digital Answering Machine
Number of rings
Looks like 6 is the Max, according to the Manual.
Setting the Ring Time
Ring Time allows you to set the number of rings the caller hears before your
answering system plays the outgoing message. You can set the ring time to answer
after two, four, or six rings. If you enable the Toll Saver (TS), the answering system
picks up after two rings if you have new messages and after four rings if there are
none.
1) Enter the Answ. Setup menu, and then the Ring Time
submenu (see "Entering the Menu Option" on
page 16).
2) Press volume up/down to select a Ring Time (Toll
Saver, 2 Times, 4 Times, or 6 Times).
Toll saver is a feature where you can call the phone yourself, if there are messages it wil answer in 2 rings, if not it'll answer in 4 rings. The idea is to hang up on the 3rd ring and save the LD changes.
Hope that fixed Ya...
Geno
Mar 27, 2008 | Uniden TRU8885 Digital Answering Machine
Panasonic (KX-TG1032S) Phone Logo
1,172 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
