Question about HP Pavilion dv2500t Notebook
HP dv2500 laptop keyboard issues
Something is stuck behind some of the keys causing problems. How can I safely open the laptop to clean behing the keys?
Thanks
    Master:
  • 474 Answers
To remove the keyboard, you have to remove all the screws on the bottom that have picture of a keyboard next to them. theres usually 3 but there may be more.
Then on the top, you have remove the plastic bezel that runs along the top of the keyboard where the bottons are. There may be a screw that holds it down from the back so be carefull and pry it gently.
The keyboard can then be lifted out. lift slowly as the keyboard and mouse attach with a small data ribbon and you will need to remove it. This of course may not help you as the keyboard has a back to it.
It may be simpler to just pop off the key with the problem and then pull out the object thats under it.
Using compresed air to blow it out would be what i would try first though.
Posted on Feb 05, 2009
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 53 Answers
Keyboard on hp dv1000 won't type letters how to fix this issue?
please clarify the query, it will not type letters when?
Jun 10, 2015 | HP Computers & Internet
Hp notebook not working?
Scan for Viruses
Sudden, unexplained computer issues are commonly caused by a virus infestation. These sneaky programs secretly install themselves on your system and alter the way the machine functions and responds to commands. Eliminate any hidden malicious programs by running a deep scan to find and destroy unwanted programs. You may need to perform a restore or recovery action on your system afterward to replace corrupted files with the correct versions.
Troubleshooting
To determine whether your non-functioning F5 key is due to a software issue or faulty hardware, connect a separate keyboard to your Pavilion. If the F5 key works on the external keyboard, the problem with your Pavilion's F5 key could be physical, such as a dirty key or spilled liquid. If the F5 key does not work on the external keyboard either, the problem likely lies in the software. Make sure that your operating system files are up-to-date to encourage proper communication between the keyboard and motherboard.
Thorough Cleaning
A keyboard key can become non-functional if it cannot make contact with the proper sensor beneath it, such as from accumulated debris or a spilled liquid. Dust, hair and lint can collect beneath and between your Pavilion's keys, which can interfere with proper contact when the layer becomes too thick. Sticky residue left behind by sugary liquids, such as soda or juice, can cause the key to stick, preventing the computer from registering the press. Thoroughly clean the area beneath the F5 key by gently prying the key off and using a cotton swab and rubbing alcohol to remove any dirt or residue.
Safe Mode
When you start your Pavilion, numerous other programs automatically start with it. Any of these programs could cause the F5 key to become non-responsive. Starting the Pavilion in Safe Mode will load only the essential operating system files and drivers, and if the F5 key works while in this mode, your problem most likely lies with an installed program or hardware device. To enter Safe Mode, restart your laptop and press the F8 key immediately. You'll enter the "Advanced Boot Options" menu, where you can use your arrow keys to select "Safe Mode" and press "Enter." If your F5 key still does not work, you may have a problem with your operating system files.
Jan 10, 2013 | HP Pavilion dv1000 Notebook
Our HP Pavillion dv8000 just recently started having problem with keyboard. No Virus. Caps Lock light will not go on (frozen) and "s" key does not work. Sometimes the keyboard properly- sometimes it...
Clean the keyboard wiith a compressed air can, if that doesn't do the trick try a usb keyboard, if the external keyboard works well then you need to replace the laptops keyboard.
May 13, 2010 | HP Pavilion dv8000t Notebook
Error 0210: stuck key 01
I assume its a laptop. laptops some times get stuck keys, meaning one of the keys has not fully released after it was depressed. I recommend getting some compressed air in a can and give it a good cleaning. there might be something stopping git from popping back up. then give the keys a little work out. just mash the keys a bit. then turn it back on. if you still have an error, then you might want to consider replacing the keyboard. if you don't, it will not harm you pc in anyway...good luck
May 04, 2010 | IBM ThinkPad 390X 2626 Notebook
Dell xps m1530 nonstop beep
Sounds like a keyboard key is stuck in an engaged position. Hold the laptop upside down and while open tap the underside of the machine gently to dislodge the key. Otherwise you will have to take off the whole keyboard to see if something is lodged behind keys. Hope this helps.
Apr 06, 2010 | Dell XPS M1530 Laptop
HP dv2500 start-up problem
Check the memory of the system maybe it is not properly fit in
Aug 25, 2009 | Computers & Internet
Can't click a key back on my dv2500 keyboard
Once you slip the key under the metal keepers, push down a bit harder until you feel a click. (Sorry, no pics... just "Use the force, Luke")
Apr 19, 2009 | HP Pavilion dv2500t Notebook
Keyboard locked`
TRY UNPLUGGING THE KEYBOARD FROM THE COMPUTER THEN PLUGGING IT BACK IN, IF YOU STILL HAVE THE SAME PROBLEM AFTER THAT I WOULD SAY THAT YOU HAVE SOMETHING STUCK IN OR AROUND THE KEY THAT IS MAKING IT STAY PUSHED DOWN
Jan 10, 2009 | Computers & Internet
Compaq laptop keyboard mulfunction
try having your laptop checked by a competent technician... there might be an obstruction in your keyboard (like dust) which causes the key to stuck and have it cleaned
Aug 09, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
HP Compaq NX960 Laptop Keyboard Problem
This is generally a sensitivity issue with the keyboard. It's usually caused when the rubber depressors that activate each key start getting worn. Sometimes you can take each key off individually, take off the rubber depressor and clean the contact point on the keyboard and up inside the depressor where it makes contact. Clean it with with rubbing alcohol and Q-tips. This is alot of work and only fixes the problem about 60% of the time. Your only other option is replacing the keyboard.
Jul 23, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv2500t Notebook Logo
1,924 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
