Question about Archos 605 WiFi Digital Media Player
WIFI error When I press the WIFI enable button I get 'WIFI Error press any button to continue' Please help!
  • From home screen, hit menu button, scroll to enable WiFi, hit OK. Get hourglass displayed for some time, then a dialog saying.
    WiFi error. Press any button to continue.
    [OK]
  • 22 Answers
Have you tried a full reboot by pushing a pin in the hole at the bottom?
Posted on Mar 06, 2009
My printer ESP5210 is showing error codes 3501,3606,3507. What can i do to fix this
To resolve this error, close the printer access door. The printer will not operate while the door/cover is open.
If the error continues even after you close the printer access door, power cycle the printer:
  1. Turn off the power (press the On/Off button on the printer).
  2. Unplug the printer power cord from the back of the printer.
  3. Wait approximately 30 seconds.
  4. Plug the printer power cord into the back of the printer.
  5. Turn on the power to the printer.
for more help visit https://cbrtechsolutions.net
Sep 29, 2012 | Kodak Esp 5210 Inkjet All-in-one...
When I turn on my brother mfc 8440 I received this message in the screen : Error 6A
To clear the error, the procedure is as follows:
1. Turn off printer
2. Hold down MENU button on front panel and turn on power while continuing to hold.
3. Release button after 5 seconds (after the Please Wait message)
4. If error still occurs:
5. Press 91
6. If error still occurs:
7. Press 99
This should clear the error.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jul 05, 2011 | Office Equipment & Supplies
How do you turn on the WiFi feature?
Pressing the keys Fn + F1 at the same time will enable or disable the built in wifi.
Mar 02, 2011 | Coby PC Netbook 1ea
Print enable
ERROR: Print Unable XX
The machine has a mechanical problem.
-OR-
A foreign object such as a clip or ripped paper is in the machine.
FIX 1: Open the scanner cover and look on the left, middle and right hand side under the covers for any foreign objects inside the machine. If the error message continues, disconnect the machine from the power source for several minutes then reconnect it.
FIX 2:
1. Unplug/disconnect the power cord from your printer.
2. Press Set button,while holding the Set button re-connect the power to your printer.
3. The Error code will be display "Machine Error 46."
4. If the Error code appear, press the "arrow up button"( ^ ) there will be numbers that are going to be display.
5. Choose 8 then press Set Button.
6. Press Arrow Up button again then Choose Zero (0) and press Set Button Again,now you will enter Service Mode.
8. Press "Mono Key/Button" 25 times or until "Purge Counter Appear."
9. Now press arrow up (^) again then choose "2" press Set Button.
10. Press Arrow Up (^) again then choose "7" press Set Button.
11. Press Arrow Up (^) again then choose "8" press Set Button.
12. Press Arrow Up (^) again then choose "3" press Set Button.
13. The purge counter will be reset to Zero.
14. Now Press Stop/Exit Button.
15. You will return to Machine Error 46.
16. Press Arrow Up (^) then choose 9 press Set Button.
17. Press Arrow Up (^) again then once more choose 9 press Set Button.
18. Your Printer will reset then wait until it power up again.
If all else fails, here is the User Manual with a troubleshooting section at the end:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002376/cv_dcp145_asaoceeng_usr.pdf
Dec 14, 2010 | Brother DCP 165C Compact Color Inkjet...
My sylvania notebook keeps displaying baud rate setting error which is enabling me to connect.
If you are getting the error code concerning the baud rate.. You need to go into my computer, click on control panel, go into network and connections and delete my connection. This will take care of the error message then you can continue to connect your device to wifi.
Hope this helps
Sep 16, 2010 | Sylvania G-Netbook
Hi! I am getting a "replace toner yellow" error message. The orange lightning bolt error light is on too. Do I need to replace the yellow toner to print in black and white or is there a different error...
Specifically on the Magicolor 5430DL you can print when a cartridge is empty, but this is disabled by default. To enable printing even with a toner cartridge empty.Press the Menu Button, then press the right button until the ENGINE menu appears and press the select button.Next press the right button until TONER appears and press SelectOnce in the Toner Menu the first option should be "EMPTY" if not press the right button until you see "EMPTY" and press Select.There are two options, the default is "STOP" pressing the right button once should change from STOP to CONTINUE.While the display reads "CONTINUE" press Select.You should see the message "CONTINUE is selected"You can now print even when one or more cartridges are empty. However, the lack of the cartridge's color will be noticed in any print jobs calling for that color... (Obviously)
Jun 13, 2010 | Konica Minolta magicolor 5430 DL Laser...
For Atheros PCIE Ethernet Controller... check cable connection PXE-E63:error while initializing the NIC PXE-MOF:exiting intel PXE ROM No bootable device-insert boot disk and press eny key happened after...
You didn't list your PC model or make, but it appears that you have enabled the network card to boot from it's rom chip. Turn that option off in your software or pcie Bios control.
Mar 15, 2010 | Computers & Internet
SURROUND FEATURE WONT WORK ERROR S10 WOULD APPEAR ON DISPLAY
Press and hold the VIDEO-1 button then press the SPEAKER A button and hold until "clear" is displayed. Then re-enter your setup menu, enable your surround speakers and if there is a decode priority select "PCM."
If your problems continue, contact Onkyo.
May 08, 2009 | Onkyo TX-DS838 Receiver
HOW TO TURN THE WIFI ON THE ARCHOS 605 160GB
you need to buy the wifi plug in from the archos website, then unload it on to device
Jul 12, 2008 | Archos 605 WiFi Digital Media Player
HP Laserjet 1320 Printer doesn't respond
Manual Feed or Continuable
Error
This state can be reached in
the following circumstances:
● Manual feed
● Out of paper for the
specified tray
● General continuable error
● Memory configuration error
● Personality/Job related
error
Solution
To recover from the error and
print whatever data is possible,
press the GO button.
If the recovery is successful,
the printer goes to the
Processing Data state and
completes the job.
If the recovery is unsuccessful,
the printer returns to the
Continuable Error state.
Feb 05, 2008 | HP LaserJet 1320 Printer
Archos 605 WiFi Digital Media Player Logo
222 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Jim Goldsmith
Jim Goldsmith
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
