Question about Gateway GTW-P42M303 42 in. Plasma Television
Digital Signal? How do I get ditital signal on my Gateway TV?
  • 95 Answers
Get a digital tuner.. set top box $59, newer recordable
dvd player that has a digital tuner $149 or a newer dvd/vcr combo with a digital tuner while you can.$229 or buy a dig. turn for the p.c. $89 and run the vidio to the Gateway.Last ... get a mini digital tv that has vid/audio out $129. Use that to feed the bigger tv..Don't forget you need a good outdoor antenna to make it work. (royalhdtv.com for more info)
Posted on Aug 14, 2009
    President:
  • 2,992 Answers
This TV does not have a digital tuner built in, so you'll need a converter box if you want to get off-the-air digital broadcasts. These boxes are available at all big retailers and on-line. The US Gov't is offering $40 coupons to help pay for these, but the program is out of money and all you can do is go on a waiting list at this time. Information is at www.dtv2009.gov.
Posted on Feb 05, 2009
How do I get a signal from my Jack OA8200 digital tv antenna.
The signal meter should show you available TV transmitters. If you have received a signal at this location before and you definitely are sure it is powered up the antenna is defective. Check for anything that appears loose or broken. If the meter indicates a signal check the cable that goes to the TV.
Oct 28, 2014 | Jack OA-8000 Digital TV Antenna
Trying to put on closed caption on gateway tv 42 inch-a large black screen appears
don't know if CC can be used when watching a DVD. seems to me that it would cause a conflict on the display where the dvd is sending the image which is really not part of the TVs input control options.
CC is usually related to the digital signal from signal broadcasts and not video images coming from an external source. if it was controlled i would think it would be from the dvd remote controller. not the tv.
Oct 14, 2012 | Gateway FMC-901 w/ 42-inch Plasma TV...
Does it have an analog tuner? or do I have to buy one?
This TV is equipped with a digital TV tuner. As long as your giving it a digital signal either from a cable box or through a digital antanea, it will be able to decode the signal.
Mar 21, 2011 | Philips 47PFL7403D 47 in. LCD TV
Does my comp Video Card supports digital signal output through VGA function? If not, what kind of cable i have to use to connect it to TV Toshiba(flat ckreen, digital)? I'v tried many cables... just...
no vga is just analoge use a svideo cable and set it up as pal if your tv is a pal or ntsc if ur tv is ntsc the tv format is not right ntsc is us pal is japan it can be found the ati cfg utility
Jan 18, 2011 | Gateway MT6840 Notebook
I cant get any channels with my coby tv
This COBY only has an analog tuner. Thus unless you are close to one of the remaining low-power stations, you need a digital-to-analog converter for OTA TV signals. For digital TV, you should use antennaweb.org or tvfool.com to identify the antenna and direction for the digital signals that you may be able to receive. Antennaweb assumes an outdoor antenna is conservative in the channel list it provides. Digital signal is either enough to register with the tuner or No Signal. An amplifier may be needed is the signal is split to several TVs.
If you have cable, check the type of signal coming in to the TV. If the signal has been switched to digital, you need a set top box.
I hope this helps.
Nov 24, 2010 | Coby TVDVD1350 13 in. TV/DVD Combo
I have hooked up cable to the RF connector but it will not show a picture. I also tried an anntenna and it does not pick up a picture either. All I get is snow. However, I had a VCR/DVD combo connected and...
This tv is analog tv,will not get today free air tv broadcasting signal.Today free air tv signal are all digital free air broadcasting tv signal now.Anolog tv must have a pay cables tv or satalites tv signals to get a picture on analog tv set.U want analog tv to get the free air digital tv broscasting signal.The analog tv,must have it broadcasting tv signal must go through a box call a Converter box to able to produced a Digital free air broadcasting signal for analog tv to get a digital broadcasting tv signal.
Nov 07, 2010 | RCA F27442 27" TV
Gateway DX4720-03 desktop the HDMI stopped working when it's connected to the tv. Message on tv says no signal says no signal. How to repair?
Make your hdmi port a separate monitor in your display settings. If that didn't help leave a comment and ill try to help you again.
Jul 02, 2010 | Gateway DX4720-03 PC Desktop
TV tuner and Cablevision box incompatible
You need to go through the Setup in Media Center. Open Media Center. Click on "TV and Movies" and then "Set up TV"
Good luck.
Mar 19, 2009 | Gateway LX6200-01 Phenom X4 9500 8GB DDR2...
Is my tv digital?
It is not a matter if your TV is compatible with a digital signal, it is the signal being offered to the TV.
Meaning, if you are using Cable TV, you are fine and need no further action because the digital signals are already converted by the Cable Box into either an analog TV (RF) signal, or a PBR (RGB or Comp.Video) signal which the TV understands via a separate input (external video input).
Feb 14, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Does my tv have a digital tuner (RCA Model E13320, 2/2001)?
The digital tuner has nothing to do with the new signal you will be receiving in February of next year. The new video signal is a digital signal. The old video signal is analog. Your television receives the analog signal and converts it to what you see on television. You need a converter box to convert the new digital signal back to an analog signal your television can convert.
Jerry
Nov 07, 2008 | Televison & Video
Gateway GTW-P42M303 42 in. Plasma Television Logo
287 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
