Seems my Poulan Chainsaw P3314 is flooding.
Ron, the excessive gas could be the result of continued start attempts with a weak spark or a bad plug or a carboned plug. If none of the carb adjustments have not been turned or twisted prior, I'd suggest obtaining a fresh spark plug. Make sure the gap is correct. Blow out the cylinder with compressed air to vent all the residual gas/oil within. Ground the new plug against the engine and pull the cord. You should observe a fairly bright spark at the plug. If no spark you could have a faulty coil/ignition module. If a bright spark is present, install the plug and give it full choke and attempt to start. It should attempt to start within a few pulls....when it does, go immediately to HALF-choke and pull again and it should start.
