Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Pro 110, runs 10 min., blows white smoke ,shuts off
I have a Reddy Heater Pro 110, several years old, has been a good heater, usually run kerosene, recently running diesel #2, have run several tanks through, no problems, recently acting up, will run for 10-15 min., then blows puffs of white smoke sparatically until shutting itself down or me unplugging it, i have no manual, have turned screws, lost track of correct position, where are screws suppose to be set, do i have other problems, ive cleaned spark plug, replaced fuel filter, cleaned air filter, ANY HELP? THANK YOU.
  • lkite600 Feb 05, 2009
    Thanks Tinytrees, I have access to free diesel , I agree it does burn dirtier, aren't they suppose to run on diesel also? Could
    I possibly mix 50/50 diesel-kerosene? what are the 2 screws for in the back? How do I adjust them once i get the guage? Thanks for the help. Larry
  • lkite600 Feb 06, 2009
    Thanks tinytrees, I'll try that.
  • 92 Answers
The first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Posted on Feb 05, 2009
  • Ira Bowles
    Ira Bowles Feb 06, 2009
    No reason you couldn't mix your fuel, it would definitly help some. the screws on the back are for the pressure. the gage will plug into the the air line that runs from the motor to the burner nozzle, clockwise turns the pressure down and counter clockwise up.
When i cut on heat run about 45 cut off smoke blue?
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 03, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
Runs about 5 minutes and shuts down but you can restart it with several trys
heatman101
Dec 30, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Shuts down after about 30 seconds, blowing some smoke.
heatman101
Nov 27, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Unit run for several mins then shuts off
Here is a tip that I wrote that tells you how to troubleshoot a Torpedo or Reddy heater...
heatman101
Sep 16, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Keeps cutting off after a min or two and blows white smoke
This is really a Reddy Heater and you have a problem with the pump pressure/air mixture. I have a tip which explains in detail how to fix the problem and where to get the parts at this link http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters Let me know if you need anymore help.
hardrocko
Thanks for using FixYa
Feb 22, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Reddy Heater will not ignite flame
Please answer the following questions. There are several folks on the board that can help but we need to know some vital information so we can get started. Answer these, if you can:
  1. Which Pro 110 do you have. We need the exact model number. Pro 110 is a series of heaters.
  2. Does the heater have a spark plug or a glowbar (HSI)?
  3. When the motor runs is it pumping fuel?
  4. When the motor runs is the spark plug firing (or glowbar glowing)?
Nov 13, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heater pro 110
My best guess is that you are are connecting to your AC receptacle with an extention cord that is too small. The Reddy Heater contains a computer that will shut the unit off if it cannot pull enough amps from your service. The longer the cord the higher the loss from receptacle to unit. This loss can be reduced by increasing the size of your extention cord. I run a 100' 10/2 cord.
Hope this helps!
Handy Home Guy
Boone, NC
HandyHomeGuy.com
Nov 01, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
1,425 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
