Question about Dell Computers & Internet
Power problems Inspirion 8600-battery not charging
I am having power issues with my PC. About a month ago my battery stopped charging and I got a new AC cable that works with my computer, but isn't DELL. I noticed that battery was telling me that I had 2 hours of battery left, but would shut off much sooner. I thought the battery was dying as it was about 5 years old. I bought a new battery and installed it today. After using it for a few hours, my computer suddenly turned off. It was plugged in. I couldn't get it to turn back on at first. I put the old battery back in and it worked. I then tried the new battery and it works. Now, my computer tells me that I am not plugged in but I am. The battery is loosing its charge. Should I get the DELL charger? Is there something wrong with the charging system of my computer? Any other ideas?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 53 Answers
Most Dell batteries have an LED indicator that allows users to see how much run time and how much overall battery life are available at the touch of a button.
To check battery charge, press the button and the number of lights that appear will tell you charge status. If all lights appear, you have a fully charged battery. Each light that appears accounts for approximately 20% charge.
To check the battery health, press and hold the status button on the battery charge gauge for at least 3 seconds. If no lights appear, the battery is in good condition and approximately more than 80 percent of its original charge capacity remains. Each light represents incremental degradation. If five lights appear, approximately less than 60 percent of the charge capacity remains, and you should consider replacing the battery
if the ac adapter will power the laptop without the battery installed its fine. if the cord is fine and your battery is fine its a mother board issue and it will most likely have to be replaced
Posted on Feb 05, 2009
Laptop battery charges for 30 seconds and then stops
Dear Lauren Monge
The problem is in one of two,1st charge plug in your lap or the adapter itself and its plugins
Best Regards
Mazagange
Mar 28, 2013 | Dell Vostro 1710 Laptop
Laptop sometimes switches off when moved.
Sounds like a loose connection where the laptop opens and closes hinge there are wires that run from the main screen to the main board. If you know how to take the unit apart it maybe a cheap fix if not then a new laptop maybe the way to go the prices have really dropped from 4 years ago
Jan 12, 2013 | HP Hewlett Packard Compaq 6720s Laptop...
My laptop won't turn on. I tried taking out the battery, a different battery, a differnet power cord. It won't turn on. Is there a way to reset it?
Are there any lights or indications on the battery itself that might tell you if the battery is good? I had a laptop with a similar problem and it turned out to be both a bad battery and a bad "power brick". replacing both fixed my issues. Also, try holding the power cable at the point where it connects to the laptop and push to the left or right. A friend's laptop would only start if you held the power cable to the left. Otherwise, it sounds like a mother board issue. Sorry.
Oct 11, 2012 | Dell Inspiron 8600 Notebook
I have a Dell Inspirion 1525. I have a fairly new after market replacement battery which I have only had now for 4 months. I am using Vista. As soon as I unplug, computer shuts down. I go to power settings...
The adapter is working correctly. The battery is either slow to charge or in need of replacement.
It's possible your battery isn't charging at all so to test this boot into bios -> battery status and watch it run overnight.
Sep 09, 2010 | Dell Inspiron 1525 Notebook
I have an Acer ASPIRE 5735Z and i have a power issue
Hello, from what i have read, it seems you have'nt considered that the Battery itself may be the issue at hand.. If not, I recommend that it now becomes the focus at this time.
Apr 28, 2010 | Acer Aspire 5735 Notebook
Inspiron 8600 does not charge batteries. Power
hello
As you have mentioned that power supply is working fine then there can be only two things.
  1. Your charging module in the mother board is malfunctioning.And you cannot replace a particular module, you have to replace whole motherboard for it.If your system is under warranty Dell will do it for free.
  2. The connector which connects the battery with the mother board is gone.
hope this will solve your problem
Thank you.
Aug 16, 2009 | Dell Inspiron 8600 Notebook
Screen goes blank after hibernation - Dell Inspirion 530 Vista
Turn off vista hybrid sleep and hibernation mode. It causes more problems then it helps.
Jun 25, 2009 | Computers & Internet
Getting hot underneth
Both batteries could be dead. But if you bought a new battery, it's unlikely. I don't know what green light you see, but if it's on the power adapter, it just means it's turned on--not that it is charging.
Two possibilities: Your power adapter is bad or the motherboard is bad. Because you say the computer works if plugged in, then you have ruled out the adapter.
You should be checking/cleaning the battery contacts and if all else fails, going for a new motherboard.
Jan 16, 2009 | IBM ThinkPad T22 2647 Notebook
Dell Inspirion 1526 Laptop Battery is not charging
Sound like the battery. Take the battery out and there should be a power meter on it, press it, if there are three lights that flash, the battery is shot. Not all batteries will flash if they are worn out, but they are supposed to. Try a new battery, I believe this will coorect the issue.
Jun 21, 2008 | Dell Inspiron E1505 Notebook
Dell inspirion 6000 battery/charging problem
Also, check to make sure that you have a good connection between the laptop and the charging cable at the power port on the rear of the laptop. We have an Inspirion 6000 with this problem and we've discovered if you pull the power cord out very slightly and lift it upwards, the charging icon appears in the system tray. Appears to be a fractured connection inside the laptop at the power port. Changing chargers does not make any difference.
Nov 18, 2007 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
303 people viewed this question
Alun Cox
