Question about Acer Computers & Internet
My laptot as started cracking near the left hand hinge
My acer 5920g as a air line crack near the left hand hinge caused through the caseing geting hot but its not coverd under warranty
    Novelist:
  • 171 Answers
Superglue it or epoxy it back together. that's about all you can do.
Posted on Feb 20, 2009
Water leaking from door when cold water dispenser being used
Hello Frank,
The line that runs from under the freezer door and connects to the dispenser is cracked or the connector is cracked. By removing the lower hinge cover ya should be able to see where the line connects to the door and see if it seems to be cracked and leaking their,if that connector is good then the line inside of the door is leaking..in some cases depending on brand the line is easily replacable without having to dis-assamble the entire door
GENE
Nov 11, 2011 | Refrigerators
Acer 9300 Laptop CRACKED BACK COVER NEAR HINGES
I would start watching e-bay for one. They're usually pretty reasonable, and without knowing exactly what part you're talking it's awfully hard to quote you a price.Good luck.-jmattes
Oct 19, 2009 | Acer Aspire 9300 Notebook
Cracking the case to get to the left hinge
If you don't know how, then take the computer to a qualified/certified technician, to avoid self-inflicted damage.
Wouldn't a drop of oil be all you need?
Sep 18, 2009 | Gateway M460A (2900728) PC Notebook
Acer laptop crack at the back of LCD near the hinges.
In my experience, I have been able to replace the LCD Bezel to fix the crack. You can order this from any online parts store if you are a Do-It-Yourself type or any computer support company could help. Good Luck
Frank
Jul 27, 2009 | Acer Extensa 503T Notebook
Acer extensa 5420 - crack on lid near both hinges....lid hinges seem tight causing strain and causing crack. Laptop is 9 months old...Is the fix/replacement covered under warranty?
Anything cosmetic is never covered under warrany unless there is a recall from the company and I don't remember hearing any recalls from Acer recently.
Only thing I can suggest is to get a hold of Acer and explain the situation and see if threre was or is a recall on your model.
My best solution, go to this page:
https://secure2.tx.acer.com/FixMyAcer3/FixMyAcer.aspx
Either fill out the form or call the number and see what they can do.
Let me know what they say and If they can't help at all then there is other routes we can try to take to keep costs down.
Jun 25, 2009 | Acer Extensa 5420-5687 Notebook
Acer Aspire 3613 cracks near hinges.
you can lift up the little round circles take out all screws,take top off, to lcd find the little gold nuts that the screws go into, try to put them back in plastic holes with super or gorilla glue,
or order screen parts on ebay, hinges usually get worse unless you find a way to secure those brackets attached to hinges
Mar 13, 2009 | Acer Aspire 3613WLMi Notebook
Cracks near hinge Acer 3613 laptop
Apply a lubricant to the hinges themselves - not a ton of lubricant, as you don't want anything running down into the laptop proper.
What sound like has happened is that the display has somehow been in a bind, and therefore the hinges are in a bind. This makes it harder to moved the hinges, and thus when you open the lid it is making the cracks.
You may also want to unseat / unscrew the hinges and re-tighen the little screws that hold them in place.
Mar 12, 2009 | Acer Aspire 5050-3242 Notebook
Left rear hinge failed on my Acer Aspire 9402WSMi Notebook
It depends if you can prove that the failure isent caused by you. if you can do that Acer will replace it.
Contact Acer and tell them your story. Here in Europe Acers custumer suport is good, dont know how the are in US.
Good luck
Dec 10, 2008 | Acer Aspire 9402WSMi Notebook
Cracked front cover at hinges
What does work is this-
Superglue the cracked lid as you WILL have one of these if you are reading this post- dont rush, I did about 10 glue applications over a few days to let it set correctly.
Next remove the offending hinges. You will see to spring/pressed steel curves in the body of the hinge, Next hack saw one (the outer is easier to get to) of these off, this frees the hinge up very well. Worked for me so give it a try
Feb 18, 2008 | Acer Aspire 3610 Notebook
Cracks in case around hinges.
Replace bottom plastics. Find them by doing a Google search. Use keywords 'laptop plastics for make/model.
Jan 06, 2008 | Acer Aspire 3610 Notebook
Computers & Internet Logo
198 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
