Question about Toshiba Satellite A135-S2386 Notebook
Windows media player does not work (vista home) unless run as adm
I cannot start my wmp by clicking on any wmp icons,even if i find it in programs,click on it,nothing happens just little yellow dinosaur runs for a sec then nothing.i can make it work if i right click then say to run as administrator then it will run.but if i put in a disc it will not play even though the settings clearly are set to autoplay on wmp.i have vista home basic and neither toshiba or microsoft will help
  • hodelizioso Feb 09, 2009
    yes i just ended up erasing my hard drive.... that worked thank you everybody for your responses
  • Jason Edinger May 11, 2010
    Are you logging into a domain?
  • 33 Answers
Maybe your windows have been corrupt or the WMP files have been deleted by a virus. Try to repair it with recovery CD.
Posted on Feb 09, 2009
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
I can't run Windows Media Player 12 due to lost of wmp dll 12.0.7601.71514
You should reinstall Windows Media Player. Download the version that is for your operating system at this website: http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Reinstalling WMP should fix your DLL issue, unless the DLL isn't missing from WMP but a different Windows Component.
Feb 28, 2011 | Video Game Consoles & Games
Removing Windows Media Player on my Desktop
Method 1: Uninstall Windows Media Player in safe mode loadTOCNode(2, 'moreinformation');
  1. Start the computer in safe mode. To do this, follow these steps:
    1. Restart the computer.
    2. Press F8 while the computer is restarting.
    3. Click Safe Mode, and the press ENTER.
  2. Click Start, click Run, type appwiz.cpl, and then click OK.
  3. Click Windows Media Player 11, and then click Remove.
  4. Follow the prompts to uninstall Windows Media Player 11, and then restart the computer when you are prompted.
  5. If Windows Media Player 11 is not removed, try Method 2.
uparrow.gifBack to the top Method 2: Run a program to remove Windows Media Player loadTOCNode(2, 'moreinformation'); If Method 1 does not work, you can use this procedure to uninstall the core of Windows Media Player.
  1. Click Start, click Run, type %windir%\$ntUninstallwmp11$\spuninst\spuninst.exe, and then click OK.
  2. Click Next, and then click Finish.
uparrow.gifBack to the topTo prevent Windows Update from downloading Windows Media Player 11, follow these steps:
  1. Click Start, point to All Programs, and then click Windows Update.
  2. Click Custom, and then click Software, Optional in the Microsoft Update Home pane.
  3. Expand Windows Media Player 11.
  4. Click to select the Don't show this update again check box.
    Note If the Don't show this update again check box is unavailable or dimmed, click to clear the Windows Media Player 11 check box, and then click to select the Don't show this update again check box.
  5. Click Review and Install updates to save the setting.
Jan 17, 2010 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
My WMP 11 on Vista will not recognise my philips
Could be driver problem. You can try reinstalling the driver for the device. If it's a vista system, you might want to run the executable file in administrator mode, or even change the compatibility to XP.
Uninstall the current installation of the device software.
  • Insert CD in CD-ROM
  • Right click on the setup file
  • Choose properties / Compatibility Tab
  • Set it to XP
  • and tick the box at the bottom run as administrator.
I hope that help.
Aug 16, 2009 | Philips HDD1630 MP3 Player
Wmp 11 on vista
right click on your cd rom drive. Click on properties, then, autoplay>Select Music cd from dropdown menu. then select "take no action" for disabling WMP popup , if you have another cd player software, choose it to make that popup when you insert cd.
Sorry to say, That wonf fix your WMP but the problem. And sorry, there is not enough info to help you on WMP fixing.
Thanks
and yes, please dont forget to Rate, if it works.
Apr 10, 2009 | Microsoft Windows Media Player
Windows Media Center proplem ( unknown Audio Error 80040155 )
Go to start : All Programs: Accessories: right click on Command Prompt, click run as administrator. click continue: you should see C:\Windows\system32> type there regsrv32 wmp.dll It should look like this C:\Windows\system32>regsrv32 wmp.dll
(make sure to put the space in between 32 and wmp)
An info box will appear. Click Ok then restart.
That should fix it!
Mar 23, 2009 | Microsoft Windows Vista Home Premium with...
Windows Media Player Keeps Popping Up.
ok, you need to type msconfig in the in the search bar in the start menu, when the window pos up select the startup tab and uncheck the boxes that says WMP in the name, and click apply and exit, reboot the machine so the registry is updated, now you will ahve the pc booting without WPM starting up at all!!!!!
any probz and post back'
kind regards and don't forget to rate us please
Nov 27, 2008 | Acer Aspire 3623WXMi Notebook
Sansa e260 and Windows Media Player 11 Issue
What you need to do is to uinstall the device completely from the computer..once you have the device remove, open your windows media player click on tools, options, go under privacy,clear the history and caches...and then reinstall the device back...let me know if that doesnt help yo
Please rate accordingly
Thank you
Computerrrep
Aug 16, 2008 | SanDisk Sansa e260 MP3 Player
Windows media player can't play .wmv files
  • Firstly a UPS is an abbreviation for Uninterrupted Power Supply - meaning emergency backup power in the event of a mains power failure. This is not a type of PC.
  • Secondly - Windows media player does not support every type of movie format, as Microsoft Update it from time to time, some formats will still not be supported, these are known as codecs.
  • Thirdly, codecs to support your particular format can usually be downloaded and added to Windows Media Player, however i can not think of any reason .wmv files are not supported by Windows Media Player.
You could try re-downloading the latest version of Windows Media Player from one of the links provided below.
WMP 11 will support the latest codecs, but if for some reason you find yourself needing the older version, use WMP 10.
You will most likely have to remove your current version of WMP, and you can do this by using Windows Add/Remove programs.
  1. Click on the Start menu button ( bottom left corner of your screen. )
  2. Click on Control Panel.
  3. Click on Add or Remove Programs.
  4. Click on Windows Media Player in the list.
  5. Click Remove ( right hand side of the listing )
Microsoft WMP 11 is available by clicking on this link:
http://www.microsoft.com/windows/windowsmedia/player/11/default.aspx
Microsoft WMP 10 is available by clicking on this link:
http://www.microsoft.com/windows/windowsmedia/player/10/default.aspx
WMV 11 is available by clicking on this link:
http://filehippo.com/download_windows_media_player/
Feb 05, 2008 | Computers & Internet
Toshiba Satellite A135-S2386 Notebook Logo
271 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
