Question about Wacom Graphire 4 "Silver" 4x5 (WMM132369)
Tablet won't stay connected?
I have a Wacom Graphire3 and Windows XP.
I can't seem to get the tablet to stay connected with my computer. The plugged-in light is on and green, but the round blue "on/off" ring flashes, like when you push the 'connect' button on the back. However, my computer already knows the tablet is there - it's listed in Bluetooth Devices. It just won't connect.
I can get it to get to say it's connected in the Bluetooth Devices box-thing for a while by going to Wacom Pen Tablet Properties and just making sure the "Drivers for keyboard, mice, etc. (HID)" box is checked, but it only says it's connected for a few seconds.
http://img222.imageshack.us/img222/4108/bluetthxd3.png
^^^ screencap I took...I don't know, in case it helps.
5 Suggested Answers
SOURCE: serial to usb wacom tablet problem
I just got Vista and it killed my Intuos2 w/serial to usb also, but here's a half solution:
Download Wacom driver 4.78-6 http://www.wacom-europe.com/int/downloads/driver/driver.asp?lang=en. Make sure you remove any other Wacom drivers, tablet, and reboot. Install 4.78-6 driver and select serial port when the choice pops up. Plug in your tablet with the serial to usb adapter, wait a few seconds and click retry. Complete the install and reboot.
Your Wacom tracking should work now, but certain things might not work like pressure sensitivity and you'll get annoying error "reinstall driver" pop-ups.
I think you can aslo buy a PCI-serial card for your computer and skip the serial-usb adapter since Vista doesn't support the adapter for Wacom tablets.. but I'm not sure if there's a working Vista serial Wacom driver either.. or ever will be. The age of XP and Legacy support is at an end my friends.
Posted on Apr 03, 2008
SOURCE: WIRE FROM WACOM TABLET NEEDS REPLACEMENT
Wacom will send you the wire for your tablet. Its only $15. You have to be very careful in opening the tablet in that the top and bottom are connected by a short flat wire leash someone eager to get all the way apart will permanently damage. If its out of warranty you have absolutely nothing to lose. Its very easy to replace. Replacing it fixed my problem caused by having the computer sitting on the corner of the wire for several months.
Posted on Jan 30, 2009
  • 46 Answers
SOURCE: Wacom pen not working - on the pen side
check the battery of the pen
Posted on Feb 24, 2009
  • 78 Answers
SOURCE: need driver for an old wacom cte-430 tablet
Go to this page:
http://www.wacom.com/downloads/drivers.php
Choose Graphire 3 or Graphire 4 as your tablet model. These are the CTE models. Then pick your OS and download the driver.
-J
Posted on Sep 03, 2009
Testimonial: "Problem solved! thank you veary much"
aero26
  • 30 Answers
SOURCE: My Tablet pen wont release, it acts like im clicking and holding
I'm just gonna pass on a email from Tech Support I recieved.
"It sounds as though your pen has pressure in proximity. This is present when the tip sensor of your pen is stuck down causing the pen to think that it’s clicking before it’s even touching anything. What you may want to try would be to remove the nib from the tip end of the pen, it pulls straight out with a pair or tweezers or your teeth, and leave that out overnight with the pen left on its side. Place the nib back in the morning and if the issue persists then you may have a defective pen tip."
The rest consists of personal info and warranty advice so I'll leave it there.
Posted on Oct 13, 2009
Wacom tablet pen right click always active.
I'm having this same problem with my original Graphire (ET), with a replacement pen that's less than two years old.
I don't think it's a driver issue, based on the indicator light on the tablet itself. It turns green like it's detecting a click when either end of the pen is brought near the tablet. To me, that suggests an issue with the pen hardware. The mouse has no such problem.
I'd be very interested if anyone has a solution to this.
Feb 15, 2010 | Wacom Graphire3 Studio Usb (cte-430/b1)
Wacom Tablet Installation: Where's the Setup Process?
What you should do now is to go to Control Panel->Add Remove programs. Select the entry for this tablet and delete it. after disconnecting the tablet reboot the PC. Then without connecting the tablet, install the drivers, Reboot. Connect the tablet and allow Windows to detect the tablet and load its drivers. Then only will work properly.
Nov 19, 2009 | Wacom Graphire3 Tablet 6x8 (C267252627)
I dropped my blue tooth Wacom Tablet and the blue light flashes and the computer finds the tablet but won't connect to it. Any hope here?
Completely uninstall the software and drivers for the tablet, make sure you have the latest version of the drivers/software and reinstall as if it were a brand new tablet. Hopefully that will resolve it for you. If not please pop back and let us know!
Oct 28, 2009 | Wacom Graphire3 Tablet 6x8 (C267252627)
Corroding cord, Tablet>computer connection loss
FixYa does not carry out repairs but freely gives advice and solutions.
Your problem can be repaired by any electronic repair shop. I doubt if you can find replacement cord for equipment this old.
Oct 24, 2009 | Wacom Graphire3 Sapphire blue pen
Wacom tablet (Model ET-0405-U) Driver?
Wacom tablet drivers can be found at: Driver Update Software for XP Vista 7 8. Used it many times before. have a nice day
Oct 03, 2009 | Wacom Graphire Grape (ET0405UGRAPE)...
Have the graphire 3 tablet, Not working well.
Wacom tablet not plugged into your computer with the USB cable.
Go to Add/Remove Programs, (Start>Control Panel>Add/Remove Programs), and -> Remove
the Wacom software.
Restart your computer.
After Windows XP has fully loaded again, install the Wacom Graphire 3 CD, in your CD/DVD drive. Reinstall the software.
If you had to reinstall your Windows XP operating system, you may have corrupted some of the Wacom tablet's drivers. (Hence the shaky stylus cursor) Removing the Wacom software, and reinstalling it will repair.
Now plug the Wacom tablet into your computer.
You should see the, "Found New Hardware", pop-up out of your taskbar tray.
Jul 16, 2009 | Wacom Graphire3 White 6X8 USB (cte630pe)...
Wacom Intuos3 Tablet driver crash in photoshop
I was having the same problems, it only occurred when i updated the tablet driver to v. 5.2.1-6. So i've downgraded to the one that came with my graphire3 (tablet driver v. 5.2.0) ...hope this helps
Running: OS Win7 PS CS3 Wacom Driver v. 5.2.0 for Graphire3
Nov 18, 2008 | Wacom Intuos3 Graphic Tablet
Graphire4 Vista
Vista doesn't support many things.. you need to see if you can find a driver for it or revert back to XP, or get a new graphics tablet
Jun 12, 2008 | Wacom Graphire3 Tablet 6x8 (C267252627)
Wacom Graphire 4 "Silver" 4x5 (WMM132369) Logo
245 people viewed this question
Top Wacom Computers & Internet Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
NIK
NIK
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
