Question about Pioneer GM-5100T Car Audio Amplifier
What are the correct spaekers for the gm 5100t ?
I blew 2 10" jensons white smoked them
  • 323 Answers
    CEA-2006 Compliant Amplifier Power Standard:
  • 125 Watts x 2 @ 4 ohms <= 1% THD+N
  • 380 Watts x 1 @ 4 ohms BRIDGE <=1% THD+N
  • 75 dBA Signal-to-Noise Ratio
  • Peak Music Power: 250W x 2 (4 ohm) / 760W x 1 (Bridge)
  • 2 Channels
  • Continuous Power @ 4 Ohm: 125W x 2
  • Continuous Power @ 2 Ohm: 190W x 2
  • Continuous Power Bridged @ 4 Ohm: 380W x 1
  • Frequency Response: 10Hz-50kHz
  • THD (1kHz, 4 Ohm): <0.015%
  • Signal to Noise Ratio: >95dB
  • Dimensions: 11 13/16” x 2 3/8” x 12 7/8”
  • PWM Regulated MOSFET Power Supply
  • Balanced Isolator Input Circuit
  • Oversized Screw-Type Power/Ground Terminals
  • 2 Channel RCA Inputs
  • Speaker Level Input
  • Screw-Type Speaker Terminals
  • Hi-Volt Input Level Control (200mV-6.5V)
  • Bass Boost (50Hz, 0/6/12dB)
  • Selectable LPF (80Hz, -12dB/Oct.)
  • Pioneer 1-Year Warranty
I'm assuming the subwoofers were bridged and couldn't handle the power. Make sure you have atleast 300 watts peak power wattage.
Posted on Feb 09, 2009
502 Chevy crate. Big puff of white smoke at high rate of speed. Doing 70 mph and throttled up and white smoke blew out.
I'm not saying that you did, but white smoke usually indicates that you blew a head gasket or worse. White smoke is an indicator that coolant has entered the combustion chamber.
Dec 14, 2015 | Cars & Trucks
My Nissan outlaw just died in a cloud of white smoke. It is getting no fuel to the engine according to my husband who wondered if it was the fuel pump or an electronic problem?
White smoke is an indicator of water being burnt so Perhaps the head blew of your radiator has a big hole , water pump leaking , rad hoses blew, heater hose blew .
Apr 22, 2015 | Nissan Cars & Trucks
The Pioneer GM-5100T wiring help?!!
i just sent you the manual for your am everything you need to know is in there. i also have tht plug if you need it. but will only be used for high level inputs for factory radio's if you have a after market radio use your rca jacks. or if you want you could use a converter if you have a factory radio that makes speakers outputs from the radiointo rca jack that will go into the amp. the rca'sare the best way it will sound much cleaner. good luck
Sep 27, 2009 | Car Audio & Video
White smoke Air Cooled Suzuki dr 200 with oil next to carb
usaually white smoke means you're burning too much oil.
Jun 26, 2009 | 2003 Chrysler Sebring
White smoke from the tailpipe
GM is my expertise, but white smoke, is white smoke. If it doesnt go away on warm up , also is thick maybe sweet smelling, soundsl like coolant ( antifreeze) is getting into the combustion chamber and burning out through the exhaust, Could be a blown head gasket or cracked head etc. Hope this helps
Apr 20, 2009 | 1993 Ford Festiva
System Remote Control Wire.
Wal Mart generally has 4g wiring kits for ~$40. Some of the kits contain everything you'll need to install your amp (including RCA cables, fuses and fuse holders).
If you want to understand more about car audio installation, read through the following site:
bcae1.com
Read the following pages specifically:
Installation Primer
Wire
Fuses
Amplifiers
Head Unit
Dec 28, 2007 | Pioneer GM-5100T Car Audio Amplifier
Pioneer GM-5100T Car Audio Amplifier Logo
177 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
