Question about LG Heating & Cooling
Ch26 error air not cool turn up high get ch26 error
  • 400 Answers
CH26 is DC compressor error, you would need to get a repairman from LG to repair this. ratemeplease
Posted on Mar 12, 2009
Got a LG ducted air conditioner coming up with error code ch26 tested winding all reading 1.6ohms is that normal on a inverter system
Do you mean it is powered by an inverter or is it a 12VDC unit for an RV?
If it operates from 12V, the motor and compressor will measure quite low using only a resistance meter.
For one thing, your meter leads will introduce 0.4-0.6 Ohms of resistance. Short the meter leads together to see this.
Any device using a motor or transformer (as in an inverter) and 12 volts will measure low resistance since the major portion of its 'resistance' is determined by the inductance of the windings and a normal meter cannot measure this.
Nov 25, 2014 | Heating & Cooling
Idec inverter e3 problem
This is stating that there has been a high pressure error on this system.
This could be due to fan motor or air flow problems with the condensing unit, but it could also be an issue with the high pressure sensor or switch
Oct 23, 2013 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
Lost remote, it only operates on low fan when I turn it on with the control on the unit.
I had the same problem, so out of frustration i kept turning the unit on/off button about 5 times real fast and wala it came on High speed Cool
Jun 20, 2011 | Haier HWR05XC7 Wall/Window Air Conditioner
Our LG Art cool Airconditioner displays the error code CH 21. The unit turns on BUT after about 5 minutes the unit turns its self off. Please Help
Inverter compressor run current high. Check compressor windings all equal 1 to 4 OhmsCheck to earth 50 MOhm minimum, check run current. If high, winding is weak. Solution: Replace compressor.
Jan 11, 2011 | LG LSC183VMA Split System Air Conditioner
High low fan motor
Your main concern is the temperature difference across the indoor coil for both heating and cooling. When you turn your thermostat from auto to on, you are on high speed.
If you have long duct runs and little return air registers then high speed
would help cool the house better. However in the heating mode, you
could lose up to 10degrees by having the high speed setting.
What they installed is sized for your house and the speeds should not have to be changed unless the ductwork is not sized right for the house.
Cooling should be High-Black wire.
Heating should be Low-Red Wire.
400cfm equals a ton of cooling= 1200 sq. foot, For cooling you need
High speed. For heating it is whatever the temperature rise across the
coil is, which is located on the furnace/air handler.
Jul 13, 2010 | Goodman CLQ36AR49 Air Conditioner
Duo-therm mod # 57915 not cooling fan?????
need to get at the capacitor for the fan. Try spinning blower when it hums. If it runs then the cap is bad if not the motor.
Aug 13, 2009 | Dometic Rooftop RV Air Conditioner
F61 error code
Sorry to hear about your error code F61
This code refers to a High Limit Temp. condition.
This is most likely caused by the cooling fan.
If the Fan has stopped running or not running at full speed, you will recv. this error message and the temp. reaches high-end limit.
Please check the cooling fan, any possible air flow restrictions and correct running RPM.
Hope this information has helped you.
Readers, please rate your technicians information.
Thanks,
John Ray
john@johnrraycomputer.com
Jun 30, 2009 | Panasonic SC-HT740 System
High cool not working
Compressors on these units runs at only one speed. The change to high cool is only a change in blower speed moving air faster over the cooling coil. I would have the running capacitor for the fan motor checked. A bad capacitor can cause your type of problem. The other problem could be that the high speed winding in the fan motor is bad. Try it operation in the fan only position through the two speeds. If it works in the low and high speed for fan only your problem could be in the selector switch.
Jun 23, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
214 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
