Question about InFocus ScreenPlay 7200 Multimedia Projector
Horizontal lines rotate from infocus 7200
Lines keep on rotating on screen.
  • donnelly810 Feb 10, 2009
    Ended up calling Infocus
Unplugged the unit.
Posted on Feb 07, 2009
Please keep my screen from rotating on my ipad.
Swipe your finger up from the bottom of the screen so it displays the controls. The one at top right with a padlock in a circle with an arrow in the clockwise direction is the orientation lock. Tap it once to lock.
Jun 07, 2015 | GSI Wireless Mini Bluetooth Keyboard For...
How do I change the reading manual ?
If the text is landscape and you want it portrait (or vice-versa) you must unlock the screen. Then when you have it in the position you want you can lock it again. Quoting from the onscreen manual,
"Swipe down from the top of the screen to see Quick Settings. From here, you can access volume, brightness, wireless options, or tap More to see other settings.
  • Locked/Unlocked: Tap to lock or unlock the screen rotation on your Kindle Fire HD. You can lock the screen to keep it from rotating when you tilt the device."
Aug 26, 2014 | Amazon Kindle Fire HD
Screen will not rotate
Go into settings and tick auto rotate
Dec 26, 2013 | Mach Speed Trio Stealth G2 Tablet -...
Monitor flashes different colors
Monitor has been successfully broken with fall.
Aug 31, 2017 | Samsung P2370HD 23 in. TV
I am getting a vertical white line that runs from the top of the screeen down to the bottom of the screen. It is about 2" wide on a screen 12' away. It flickers. It rotates to the other side of the...
it is most likely the dmd board on the light engine. very expensive and parts may be hard to find for a projector that age. you could try to find a 4800 on ebay for parts....
Feb 03, 2011 | InFocus ScreenPlay 4800 Multimedia...
My screen is side ways how do i put it back to normal
Do you have a rotating monitor? There are a few that can be rotated 90 degrees in the plane of the screen for a "portrait view" instead of the standard landscape view, and they will automatically swap horizontal and vertical signals as needed. If you have one of these, the position detector switch is stuck in the wrong position. You may be able to get it unstuck by rotating to the other position and back again.
There are some programs (e. g., Acrobat Reader) that let you rotate the view of the file you have open, but that only affects the contents of the window, not everything on the screen. I'm not aware of a program that rotates the full screen view for the entire system.
Nov 19, 2010 | Computers & Internet
Half inch crystal/ solid white vertical line on screen
Adjust the horizontal in the menu then try the overscan adjustment. If the image does not look dim you do not need a lamp.
Jun 04, 2010 | InFocus IN72 Multimedia Projector
My Sony KP-57WS500 TV has curved horizontal white lines. You only see them when there is something dark on the screen. Any ideas?
You have 3 CRTs inside of your TV that create image. Blue, Green and Red. Looks like one of them need adjustment due aging.
Remove front grille. Than remove center "shielding" piece held by 4-5 screws. Behind this cover you will find little black plastic box that have 6 rotating buttons on it. Take you time to study them. There is three columns and two rows. Columns represent color, rows - "Focus" or "Screen". You need to locate "Screen" row of three rotating buttons. They will be marked "B', "G", and "R" for colors accordingly. Turn on TV let it warm up and try to figure out witch color is dominating others on your screen. Then carefully turn rotating adjuster counterclockwise using Philips screwdriver. Try to muscle-remember original position of screwdriver so you can turn it back to it.
Eventually you will find the right one, you will see lines dissapear when you reduce voltage and reappear when you turn rotating shaft back. Sometimes more than one have to be adjusted.
Try to have all three color to be present and visible but with no over saturating and no horizontal lines.
Put cover and grill back - and that's should do it!
Regards.
Russ.
Apr 06, 2010 | Sony KP-57WS500 57" Rear Projection...
How do I rotate my screen back to horizontal view?
press ctrl+alt+arrow(of that direction which u want to rotatae ur screen)
Feb 25, 2010 | HP DC170B Keyboard
Scrolling Horizontal lines
This usually happens when some other appliance is causing noise on the AC power. Try powering the projector from an outlet by itself and whatever else you're running from a different outlet, preferrably one on a different circuit breaker if possible.
Feb 19, 2010 | InFocus Office Equipment & Supplies
InFocus ScreenPlay 7200 Multimedia Projector Logo
156 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
