Question about Nikon F80 35mm SLR Camera
When i re-load film the shot counter reads " error"
I have noticed that when i try to re-load film , where the shot count should be in the right hand bottom corner it reads e? what does this mean? this started happening when i took out a roll to be developed .
  • Print Mama May 11, 2010
    Does this just happen when you are loading film or does it also happen when you are taking a picture? Was you last set of film completly secure in the tube when you opened your camera? Have you been in any strange weather conditions with it? Have you left it in the car then gone inside and had the message? Is it freezing up on you at all, does it make you waste film to advance to the next frame? "e" is many things with Nikon. It just lets you know that there's an error. I know these are alot of questions but there are so many variables with cameras because they are metal, glass & plastic.
  • 538 Answers
Film didn't catch spool.
Try to put film on the spool, catch tooth on the spool.
Posted on Apr 02, 2009
Film count reading problem
I am not familiar with that model.. However ant time you open the compartment or unlatch it THE CAMERA think you are installing NEW FILM so camera goes back to the "Beginning". is this your first time use??, look for the instructions or google it.
Jun 02, 2015 | Fujifilm Instax Mini 25
Film-advance warning won't go away on a RB67 Pro SD 120 film back?
Mamiya RB67 Pro SD that is new to me. loaded the film correctly took the first shot. But, the film won't advance. What am I doing wrong?
Feb 18, 2012 | Mamiya RB67 Pro SD Medium Format Camera
My Mamiya C330 Pro only gives me 4 photos per roll
A few things to consider:
-Loading: Make sure you are not over loading the film before you start to shoot. I have sometimes turned the film advance too many times and end up cutting down on the amount of usable film.
-Are you loading the film in a dark area and careful to close up the back just after it has started to load to avoid exposing it?
-Shooting: Are you metering properly when shooting? Obviously underexposed images won't develop. You should consider a hand held meter.
-Shooting: Are you advancing the film more than it needs to be after you take your shot? Watch the film counter and feel for that click as it hits the next frame. I have advanced past the next shot many times by accident.
Hope that helps, Matt
Apr 05, 2011 | Mamiya C330 F Professional TLR Film Camera
I put the film in the camera and the knob wont turn when i advance the film. I don't know what to do.
If the knob on the left hand side of the top plate (as viewed from behind) does not rotate when you operate the film advance lever, then the film has not been loaded properly and has failed to engage onto the take up spool. It's a very common fault and even experienced photographers sometimes make the same error. The frame counter will advance every time the lever is wound on, it only counts the number of full lever actuations, not the actual amount of film which has been wound on. The rewind crank is the only reliable way of knowing that the film is actually advancing.
Open the back of the camera and re-thread the film leader onto the take up spool. Close the back and wind one frame with the lever, and then open the back again to check that you got it right. This may potentially waste one shot but it will reassure you that you got it right. Once you're familiar with your camera you won't have to do this any more as you'll be able to feel and hear when the film is loaded properly or not.
If this does not solve your problem then please add a comment and I'll offer further assistance. If I have solved your problem then please take a moment to rate my answer.
Mar 06, 2011 | Vivitar V3800N Zoom 35mm SLR Camera
I didnt use all of my film but i pressed the rewind button and when i turned it on the film rewond on its own. what do i do?
Nothing. You pressed the rewind button and the film rewound: it didn't do so "on its own", it just did what you told it to.
Get it developed and put another film in and don't make the same mistake twice.
You can buy a film leader retriever which fishes out the end of the film from the canister enabling you to reload it, but you need to remember exactly which frame you were at. To get it back to the correct position you then set the camera to fully manual and using the fastest shutter speed and smallest aperture, leave the lens cap on and cover the viewfinder and away from bright light you fire the shutter until the counter reads one lower than you were last at (if your frame counter counts down to zero shots remaining). If the subsequent shots don't register exactly with the old shots, the automatic film processing machinery will likely cut into some frames when cutting the negs into strips. You'll also find that a leader retriever costs more than another roll of film and can take some skill to use.
In summary, your Minolta 7000 is behaving exactly as designed and the cheapest fix is to just drop in a new roll of film.
Sep 20, 2010 | Minolta Maxxum 7000 35mm SLR Camera
Camera does not rewind after end of film it spins, but does not engage the film. Joe M.
it is likely that this model of camera spins the entire roll onto the take-up spool, and then slowly rewinds one frame at a time until the last picture is taken. Then it has already almost rewound,
This shows up when you load the film. The cameras digital counter counts up to the number of pictures available, and counts downward each picture taken.
Sep 08, 2010 | Canon Sure Shot 80U 35mm Point and Shoot...
Stuck remaining exposure count despite new film, new film unlded
You might try closing the film compartment without film in it and press the manual rewind button. This might reset the counter circuit.
Dec 08, 2008 | Kodak Advantix 2100 Auto APS Point and...
Loading film
After further investigation and because I can't keep my hands out of things I now know that the camera body is defective and that the shutter is jammed. It will only release with assistance. I was loading it correctly.
Apr 17, 2008 | Photography
F--
Unlike other cameras that start at frame #1 after loading and count up as the film is used, the N55 advance the film to the last frame during the loading process. When loading is complete, the frame counter stops at the number of available frames on the roll (usually 24 or 36) and counts down as photos are taken. I know it sounds backwards but it actually makes a lot of sense to engineer it this way. After the last photo is taken (displays 1 on the counter), the camera automatically winds the end of the film into the cassette and the counter shows a blinking E. I am assuming that that is what is being displayed and not a blinking F. it it is an F, perhaps there is a problem with the LCD display? If so, it probably isn't worth having it repaired.
Jun 26, 2007 | Nikon N55 35mm Film Camera
Nikon F80 35mm SLR Camera Logo
141 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
