Question about ASUS Eee 4G Notebook
Eee Pc 900a Mouse Button problems..
My right mouse button is really hard to click something..My sisters went out completely.. But the left works just fine.. how can i fix this?
  • 3 more comments
  • Anonymous Feb 15, 2009
    i have a eee pc 901 and my right button now dose not make the click sound but it cloick and my left button makes the sound
    I have Asus EeePC 900 20GB.Left mouse button on Touhpad screen doesn't work. It sounds click but hardly works.
  • pauls68uk Feb 19, 2009
    I had the same problem...and so do quite a lot of users. I sent mine back to Asus to be repaired under warranty and it now works as it should.
  • Anonymous Feb 21, 2009
    mouse buttons have stopped working completely. first they became crappy to use, now theyre useless.
  • mriver7432 May 11, 2010
    is it a external mouse or internal on the laptop touch pad please clarify wich one so i can better assist you
Samsung laptop mouse left button
-If me I'll buy a new mouse.
Good luck
Jun 16, 2017 | Computers & Internet
The right click button isn't working
does this mouse have a ball on it or its the ones with the red light.
Jan 28, 2014 | Microsoft Comfort Optical Mouse 3000...
ASUS 1000 left mouse button not working
Yes! get a can of compressed air and attach supplied straw, now with your fingernail lift up the left mouse button and give a few good blasts in the crevice, this will clear out any buildup of dirt and grime that has collected, repeat as required. If this fails it will involve laptop service.
Jul 04, 2012 | ASUS Eee PC 1000 Notebook
Left button of the Asus Eee 900 is not working?
I guess you mean the left touchpad button. With my 900 that happened after only 4months extensive use. Reasons could be dirt in the microswitch under the button or broken contact of switch on MB. To exclude software problem, switch buttons in touchpad driver panel and see if the right button function is not working when pushing the left button. If you don't want to open your eeepc to clean or fix, activate the tapping option in the touchpad options and asign a "2taps with one finger" to a left mouse click for replacement. I work with that for almost 2 yrs now without ever using the left button again. Should you just switch buttons, be prepared that the right button might leave you too in a while.
Take care,
Jan 17, 2011 | ASUS Eee PC 900 PC Notebook
The left click button doesn't work. Right click works fine.
check it for dust trapped in switch or mouse button might have come out of it's housing
Nov 16, 2010 | ASUS Eee PC 900HD Netbook
Acer d150 left trackpad button not clicking/working
go to control panel click on mouse and set for right handed
Jul 29, 2009 | Acer Aspire One Netbook 8.9" Notebook
The image on the monitor is too large and I don't know how to reduce it.I have just plugged it into my new wireless ASUS Eee PC 900A that is not connected to the Internet Beth
Are you using Windows XP or Vista? On XP it would be right mouse click on open area of desktop, select properties. On Vista it would be right mouse click on open area of desktop & select personalize. You can change your graphics settings from there. Hope this helps.
Mar 27, 2009 | Computers & Internet
MX Revolution left click problem
Try a bit of compressed air - perhaps dirt is jammed under the button.
If its under warranty you might want to return it to where you bought it.
Feb 27, 2008 | Logitech MX Revolution 931689 Mouse
"sticky" mouse on compaq laptop
Unless your left mouse button has been severely damaged, it is unlikely that a loose button is the cause of your problem. More likely, it is your touchpad. Chances are your touchpad is set to click when tapped. Oversensitive touchpads can click randomly when you're dragging your finger across the touchpad.
To test this, position your cursor over a link (or other button) but don't press the left mouse button. Instead, lightly tap the touchpad itself. If the link or button is clicked, go to your Control Panel and adjust the Mouse options so your touchpad no longer clicks when tapped. It's usually a setting titled "tap to click" or something along those lines.
Nov 07, 2007 | HP Compaq Presario V2000 Notebook
ASUS Eee 4G Notebook Logo
1,596 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
