Question about Fender Frontman 65R 65W 1x12 Guitar Combo Amplifier
When i turn on my amp it makes a loud beeeeeeeeeeeeeeeep.
I dont even connect the guitar, and when i turn on my amp it makes a loud beeeeeeeeeeeeeeeep sound. what can i do?.
  • garycorbett May 11, 2010
    Does it continue this "beeeeeeeeeep" sound until you turn it off? Or just momentarily?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
I've got the same problem, volume, gain and others are down, what now?
Posted on Mar 26, 2016
    Champion:
    Scholar:
  • 210 Answers
Volume way too loud
Posted on Oct 26, 2011
  • 22 Answers
Turn the volume down.
Check your gain.
That should solve it.
Posted on Sep 28, 2009
I have a peavey VIP2 amp.Can I use my acoustic/electric guitar in the electric guitar setting
You can not only play it on electric guitar setting, you can play it LOUD. Its all about what YOU do and what YOU like. Dont accept it when somebody tells you that the music you're playing doesnt sound good to them. ITS YOUR MUSIC !
Do whatever you want. And NO it wont hurt guitar or amp. Rock on or whatever it is you do.
Oct 26, 2015 | Peavey Vypyr VIP 2 40W Modeling Combo...
Action is a bit high. Everyone is saying the DC16RGTE guitar sounds great and gives good volume. I found the one I have is not loud and it has too much boom. Is there a problem with this guitar?
Make sure the guitar CANNOT "HEAR" the amp you are using. Local regeneration (feedback below the level to sustain full feedback) will give a boom sound like in a cave. If you get near enough to the amp for feedback to build up, you can actually see the string vibrating and building up. The loudness has much to do with the amp you connect this too and the settings
Aug 30, 2011 | CF Martin DC16RGTE Aura Drednought Cutaway...
My amp makes a loud foghorn type noise whenever turned on. Even if i have the volume turned all the way down and the guitar unplugged it still hums. I'm not sure if its an amp or speaker prolem. I took...
Likelly the TDA7293 chip in the power amp has failed. It shorts to one power rail and drags the power down where it hums... this CAN damage the speaker if left on. Verify the problem and replace the chip. Slight chance there are bad electrolytic filter caps but those are easily spotted.
Aug 06, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
When I turn on the amp, I get a loud hum. plugging into the jack doesn't change anything. turning the dials doesn't change anything. when I turn off the amp it makes a loud crack.
i) Disconnect one lead of loudspeaker & insert an open-ended guitar cable into headphone socket.
ii) Put a dc voltmeter across open end jack then turn Frontman ON for a few seconds.
iii) The reading should be about 0volts - if the voltage is high (27v), then it is likely that the PA chip TDA1514A has blown.
iv) If,however, the voltage is correct in iii) , then reconnect speaker & put guitar cable into the POWER AMP IN socket & connect other end to guitar...Turn on briefly, if there is still hum then fault is in the output stages & will require chassis removal to solve.
Feb 23, 2011 | Fender FrontmanTrade 25r Combo Guitar...
I have a Marshall MG100DFX. I turned my amp on a few days ago and I heard this loud sound (not the standard hum/buzz that you hear when you plug a guitar into an amp; it sounded more like a foghorn). Now,...
I would try hitting the side of the amp before turning it on. There may be a loose piece of solder or other conductive particle stuck somewhere. Bang the cabinet rather hard with your fist. If that doesn't help it might be a loose solder connection at a resistor or capacitor but a tech should check that out.
Dec 04, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
Well i dont have a les paul studio i have a les paul menace with the same problem. Hopefully you can still help me. When i plug the guitar in and turn the volume up on the guitar a loud hum appears. ...
OK... Most of the guitars have a PAINTED on shielding in the well with the electronics. Sometimes the electrical connection to this is broken causing hum. Sometimes the connection is by way of the potentiometer shaft nuts and they spin and break the connection. This paint is conductive and often black know as aquadag. Use an ohmeter to verify connection.
Oct 27, 2010 | Gibson Les Paul Studio Electric Guitar
Amp turns on but no sound even with diff guitars and cords
Hi Dan
I wish I could just say what to fix, but you can not do this at home. Line 6 is a great amp and worth the time taking it down to the music shop , to be looked at an give you a repair estimate. good luck keep on rocking in the free world. DFD
Apr 12, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Loud buzzing when amp connects to guitar
Is there a loose connection anywhere?
Jan 03, 2009 | Music
Electric Guitar wont play through Amp
the buzzing is indicative of an open ground connection, check the cord by substitution or with an ohm meter, if the cord is good look at the connections to the jack inside the amp ( im guessing you built the amp from a kit). Is this a solid state amplifier? Tube amps have lethal votages and should not be experimented on without knowledge of electronic safety. Also if there is more than one input to the amp try plugging the guitar into another one and see if its still the same.
Dec 30, 2008 | Yamaha Electric Guitar
Fender Frontman 65R 65W 1x12 Guitar Combo Amplifier Logo
316 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Are you a Fender Music Expert? Answer questions, earn points and help others
