Question about Fostoria FHK-212-1CA Infra-Red Utility Heater
OVERHEATING OF THE PLUG-IN AND THE CORD IN GENERAL
I THINK THAT DUE TO THE LENGTH OF THE ELECTRICAL CORD IS THE REASON FOR THE PLUG AT THE WALL GETTING HOT ENOUGH TO MELT THE COVERING UNLESS I UNPLUG IT AND LET IT COOL DOWN? WHATS WITH THE OVERHEATING THING??
  • 1 more comment
  • bently371938 Feb 05, 2009
    I hve over 45 receptacles around the house and garage and they all are fine, # 12 wiring through-out and I still say if I shortened the cord by five feet it would not overheat......bently371938
    DIDN'T SAY THE CORD MELTS, JUST GETS WARMER THAT JIT SHOULD,  COULD BE THE CORD IS NOT HEAVY ENOUGH DUE TO THE TRIP FROM CHINA.......MAYBE 14GA OR EVEN 16 GA BUT NOT HEAVY ENOUGH, I WILL LET YOU KNOW WHEN I REWIRE IT.  ELECTRICIAN FOR 50YRS AND I STAND/SIT BY MY OBSERVATION
    THANK U FOR U;R PROFESSIONAL ANSWER, FROM CHINA WE GET WHAT WE PAY FOR AND SOMETIMES LESS
  • 360 Answers
Poor contact at the receptacle will cause the plug to heat. Look at the plug prongs for any sign of discoloration or arcing. You may need to replace the receptacle and/or plug.
Posted on Feb 05, 2009
  • 1 more comment
  • clarkco2002 Feb 05, 2009
    if the cord were the problem, the cord would be hot/melting.......master electrician with 25+ yrs experience....I stand by my initial solution.
    Your original post.
    "I THINK THAT DUE TO THE LENGTH OF THE ELECTRICAL CORD IS THE REASON FOR
    UNPLUG IT AND LET IT COOL DOWN? WHATS WITH THE OVERHEATING THING??"
    You stated "the initions */
    p.MsoNormal, li.MsoNormal, div.MsoNormal
    {mso-style-parent:"";
    margin:0in;
    margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:12.0pt;
    font-family:"Times New Roman";
    mso-fareast-font-family:"Times New Roman";}
    @page Section1
    {size:8.5in 11.0in;
    margin:1.0in 1.25in 1.0in 1.25in;
    mso-header-margin:.5in;
    mso-footer-margin:.5in;
    mso-paper-source:0;}
    div.Section1
    {page:Section1;}
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    font-size:10.0pt;
    plug
    at the wall getting hot enough to melt the covering" with the information given, I still stand by my solution
    Wow, thats not what it said on my screen...it said..
    Your original post.
    You stated "the plug at the wall getting hot enough to melt the covering" with the information given, I still stand by my solution
The plug on my Toro power blower vac got super hot and melted the inside of the extension cord plug. what happened?
It appears that for some reason, the connection at the extension cord, overheated. Could be caused by: 1. a problem with the vacuum unit (bearings, jamming up, something like that)
2. The extension cord itself was defective. Could have been abused, moisture could have broken down the "contact" or the point of contact or blades of the extension were loose and caused excessive current draw at that point, overheating the device.
Or, it could have been a factory fault with the extension.
Plug your blower into a good receptacle, and see how it runs. If it is
sluggish or not coming up to speed, the problem could be in the unit.
Check manufacturer's recommendation for extension cord size and length.
Dec 02, 2016 | Toro Garden
What might causeI my electric mower to slow down and speed up and the electric cord connection has overheated at the mower connection?
there is approximately one OME of resistance per foot of power cord. the power cord must be sized according to the amps drawn. if the cord is undersized the motor will not get enough power. the results are a hot cord and probably a hot plug. a loos plug will also over heat, you may need to replace the outlet in the wall as well, get a 12 AWG cord if you are using a 100 foot cord. I personally would never use a 14 AWG if I had a choose, but if the cord was 25 feet or less that would probably be ok. if you are still using the old cord or if the wall outlet is damaged this could cause the ossolating current.
Jul 27, 2014 | Black and Decker USA MM-875 19" Mower...
My dryer is just blowin cold air but its still spins can you help try and solve what the matter with it
Hi, the same thing happened to me and is quite an easy fix,
1 remove the plug from the wall socket.
2 Inside of the drum at 12 o clock (above the door on the inside) is a thermal cut out which has tripped due to overheating.
3 Remove two screws on the retaining clip and take the thermal cutout out. This should be self resetting but for some reason it has not reset (a continuity test with a multi-meter will prove this is the problem)
4 Give it a sharp tap on the bench and it will re-set ( if this sounds too extreme go out and buy a new one but trust me it will work)
Jun 24, 2014 | Zanussi TC7102W Electric Dryer
My cord has to be pushed in to socket and giggled to get the vacuum to have power? Any suggestions?
You might want to remove the electric plug from the wall and spread the prongs just a little bit, it sounds like the plug might be loose in the wall socket.....try it in another wall socket and see if the problem continues to exist...generally it you get the same result from similar wall sockets...you may have looseness in the electrical plug...meaning that you might have been unplugging the cord by grabbing the cord and snatching versus unplugging with the plug itself. Hope this helps.
Sep 25, 2013 | Electrolux Guardian Bagged Canister Vacuum
For a/c unit, is there an adapter available or do I need a new plug cord
Actually you should buy and install an AC wall outlet. An AC uses more amperage than most any other appliance due to the fact it has 2 motors the compressor and the blower / fan motor. An AC wall plug has larger terminals so that the plug does not ever heat. Changing the cord to a different and smaller terminal plug is a bad choice due to the danger of overheating the wall outlet terminals. You can buy the AC horizontal terminal outlets at any hardware store. Unless you have a 110V AC unit you will also have to run a 220V #10 Romex (3 wire) with ground to the outlet to be in code.. An AC unit 1 HP (10,000) BTU or larger requires over 15 Amps for start up. Those that are 20,000 BTU or larger obviously require more than 15 amps as a power source.
Thanks for using FixYa.
Kelly
Jun 01, 2010 | Heating & Cooling
Discolored terminal on cord
Check the dryer power cord for any signs of melting or charring. It could just be a loose connection. Then.....
Check the wall plug - there's a possibility the wall socket is either worn or the wiring to the socket isn't tight. The socket will need to be removed to check this, so make sure the power is off first.
Mar 30, 2010 | Amana NDE5800AY Electric Dryer
Grill problems
I would advise not to use the grill or the plug it plugs into before determining what the problem is. It could be the grill cord, or the wall plug.
If you have been in the habit of pulling the cord plug out of the wall by tugging on the cord, then chances are the problem is broken conductors inside of the wire insulation. One way to test this is to attempt plugging the unit into a totally different wall outlet. If the cord and outlet heat up again, chances are the cord needs to be replaced (if possible). If the both do not heat up, then the outlet wiring connections inside of the wall need to be checked.
Bad wiring connections either in the wall, or in the cord, will generate heat, when will then conduct to the other connector. So it is difficult to use heat as the indicator of which connector is bad.
Dec 10, 2009 | George Foreman GR36P
Compaq presario m2000 overheating, broken fan.
Overheating issues are considered as safety issues and are take very sincerely by Computer manufacturer. Generally, overheating occurs due to any mechanical fault. So, you may contact the customer service of the Computer manufacturer to get any sort of assistance.
Nov 17, 2009 | Computers & Internet
We have tried 3 maytag and now one whirlpool electric dryers at our lake house...all new but they all take toooo long to dry what I think is a very reasonable load. We checked the outlet for power seems...
The problem is not the power cord, it maybe the length of the venting. Every elbow is equivalent to 8 more feet of pipe. Not sure which model you have. How long is the length of vent? Does it go right out the wall?
Jun 16, 2009 | Estate TEDS740JQ Electric Dryer
Electric cord lost
Call the customer service number 800-323-9519. They are great to solve issues and offer great help!
Feb 13, 2009 | Rival S16RB Electric Skillet
Fostoria FHK-212-1CA Infra-Red Utility Heater Logo
733 people viewed this question
Top Fostoria Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Fostoria Heating and Cooling Expert? Answer questions, earn points and help others
