Question about ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth...
SUDDEN POWER FAILURE
I HAD JUST LOADED WIN XP ON MY PC, I TURNED OFF THE PC TO GET THE MOTHERBOARD NO. AND WHEN I WANTED TO TURN IT ON AGAIN IT WOULDN'T WORK.
THE LIGHT ON THE MOTHERBOARD IS "ON" BUT CAN'T SEEM TO GET POWER TO START.
ANY SUGGESTIONS
  • Chris May 11, 2010
    Some ideas:
    Broken power switch?
    Power switch connector unplugged from motherboard? (Maybe by accident when you were checking for the number??)
    Bad power supply? (How old is the PC?)
  • 2,229 Answers
The light on the motherboard will be on as soon as you plug the power supply in.
If, when you turn on the computer, the fan in the power supply does not start, your power supply is bad. In my experience, the switch in an ATX machine does not go bad--it's just a device to close a contact. If you really want to check it, though, find the place on the motherboard (lower right side as you are looking at the board with the top of the case away from you) where the wires from the front panel are plugged in--the ones that say pwr switch or something like that. When I do this, I remove the wires from the motherboard and short the two prongs where the wires were fastened.
In all probability, though, you need a new power supply.
Posted on Feb 05, 2009
Instal xp on panasoc cf 71
had same problem with loading win xp proff on cf 74 toughbook mk1.
soution for me was downloading sata hdd controller from panasonic toughbook support site, loading the driver onto floppy drive, using usb floppy with driver ready to use, loading win xp profesional and on first loading win screen pressing f6 when prompted at beginning of win intallation, when on screen instructions to load sata driver appeared, i followed on screen instructions and loaded 3rd option from floppy sata drive mobile driver, left usb installed untill xp loaded and running, do not remove usb floppy untill win loaded, i really hope this helps you
Mar 25, 2013 | Panasonic Toughbook CF-27 Notebook
Card installation
1) Turn the computer on. When Windows has loaded all the way, put the Installation (CD) disk in your optical drive. Load the software.
No disk? Go to the Sound Card manufacturers website, and download the software. Now INSTALL it.
If asked to restart your computer -> NO
Close all windows, go back to your desktop screen.
Turn the computer off.
FOLLOWING Anti-Static Precautions, and computer unplugged from power, open the computer case, and physically install the Sound Card.
Close the computer case, do not forget to hook up the audio wires to your sound card.
Plug computer into power, WAIT 1 minute, turn the computer on.
2) Doesn't have a sound adapter card, and is just Integrated Audio?
Download AND install the audio drivers from Asus for that motherboard, AND Operating System you are using.
(Win XP and Win 7, are two examples of an O/S)
Need further guidance than this?
Post the Sound Card manufacturer and Model Number.
Also post the model number of the Asus motherboard.
Post in a Comment.
Regards,
joecoolvette
Sep 03, 2012 | ASUS Computers & Internet
Compaq 615 laptop just hung, i removed the battery then tried to boot again but showed nothing
Hi
Not enough information.
It would be helpful to know if this machine running XP, Vista or Win 7.
Can you hear the CPU beep during boot?
Do the lights come/blink on on the front of the laptop?
All this information is important if you want accurate advice to help solve your problem.
If you have a desktop PC monitor available, connect this to the laptop's VGA port and press the Fn (function) key simultaneously with the F5 or F6 key (the key showing 2 monitors) while booting, to send the image to the external monitor.
If you can see images on the external monitor, then your laptop may have (in ascending order of seriousness/cost of repair), an LCD panel inverter fault/failure, a cold cathode backlight fault/failure, an LCD panel fault/failure, a graphics card fault/failure, a motherboard power management system fault/failure, a motherboard fault/failure.
Sorrry to not be able to be more precise.
Hope this helps.
Aug 02, 2011 | HEWLETT-PACKARD Compaq Presario CQ60-615DX...
I have win 7 and win xp loaded on my lap..How can I delet xp now?
You need to check if there any Boot Information in partition that is used by WinXP. In this situation best way is to reinstall Win7, and format all your partitions as you want in Win7 installations process.
Apr 18, 2010 | Microsoft Windows Vista Ultimate Edition
I installed a win 7 beta version on my pc..and when i wanted to revert it into vista again it won't install anymore to any os except win 7. When i tried to install vista it cannot detect my HDD, and when i...
To make sure you install back again your Windows Vista and Windows XP is this.
First:
  1. Go to Bios Setup and change the setting of your Hard Disk drive from Sata to IDE mode.
  2. Boot priority the CD/DVD Rom to run your Bootable CD/DVD.
This setting are quietly working, good luck!
Jul 29, 2009 | Computers & Internet
I have a DFI AM75-TC motherboard, 3beeps, no video
Hi richardbyers, three short beeps means there is a problem with your memory. (Base 64K memory failure). Unplug the power from the PC. Open the case & touch the bare metal on the case to discharge your self.
Remove the memory & reseat it. Leave the case opened & re-connect the power cord & try booting again. If you still hear three short beeps, shut the system down again as mentioned above. Gather some house hold alcohol & a couple cotton swabs. Drip a drop or two onto a cotton tip & wipe the memory's contacts, both sides & do not touch the contacts with your fingers during re-install or cleaning. Blow the memory slots out with canned air or use a clean paint brush. Insert the memory again & connect the power cord. Boot the PC. Try this first. If everything works out than good. If the problem does not clear its self let me know.
Good luck richardbyers!
Mike
Jan 06, 2009 | DFI AM75-TC Motherboard
No audio
You can find the drivers for this motherboard at the ASUS web site.
http://support.asus.com/download/download.aspx?SLanguage=en-us
Dec 22, 2007 | ASUS NVIDIA nForce Chipset A7N266-VM...
ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth... Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
