Question about X2Gen MG19MY 19" LCD Monitor
Monitor is to bright
Monitor is so bright colors such as this text box can not be seen
  • 2,229 Answers
Your monitor has brightness and contrast controls either on the bottom or the right side. Sometimes you have to push the menu button and then scroll to the proper setting. If this is the case, there will be an "up" and a "down" button to use.
Once you are in the correct menu, you will have to push the menu button or the enter button to activate the setting. This all depends on the monitor model.
Posted on Feb 05, 2009
Adjust brightness
Hi Valerie.
Brightness is adjusted via keys on the keyboard or through the monitors/dispalys control panel in System Preferences.
If you have a screen that is excessively bright (which does seem to happen on these laptops) you may need to visit an Apple store to have it looked at. I've seen several where the screen is so bright it's difficult to read text and adjusting the brightness has not had any noticeable effect.
Dec 04, 2013 | Computers & Internet
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
How to change the 'Contrast' and 'Brightness' on the monitor screen
Bootup your computer and display your Windows Desktop. Make sure yourmonitor stays on for at least half an hour before you begin, so that itis properly warmed up.
Seta pure black image on the monitor so you can adjust the brightness. Toget a pure black image, do the following: Choose Start, then ControlPanel, then Display. This will open the Display Properties dialog box.Click the down arrow next to the representation of the desktop color inthe Color field. Choose black from the color palette, then click OK.
Maximizethe Brightness control on your monitor, then slowly reduce it until theblack of the image perfectly matches the black at the edge of thephysical screen. This puts the brightness at the proper setting.
Open a screen with a plain white background soyou can adjust the contrast. One of the best ways to do this is to open aword-processing document without any text in it. Gradually reduce the contrastsetting of your monitor until the white area of the screen begins to lookslightly gray or off-white. Then gradually increase the contrast until thewhite area on your monitor is pure white. This will give you the proper whitebalance. Now you've got your monitor ready for peak performance.
Hope this may help you solve your problem.
Nov 12, 2010 | Computers & Internet
MY LG 500G CRT 14" monitor is become faded and very white color graphics(nothing seen with out white color) after 1 or 2 sec. when i re start the monitor i can see some very brigh graphics then again...
open the monitor there is a movable preset attached to EHT rotate that preset by screwdriver in active on condition of monitor reduce the brightness to satisfactory level
Mar 29, 2010 | LG Studioworks 775N 17" CRT Monitor
Dell LCD Monitor Pictures, Dark Colors Course, Fuzzy, Pixelly
You might find a BACKLIGHT FLUORESCENT BULB on eBay.
Jul 04, 2009 | Dell E173FP 17" LCD Monitor
My monitor displays bright green pixcells in the black areas of text and pictures .I have tried a different monitor (lcd also, no problem ) to isolate the fault back to the monitor.
some time we can see that of problem as screen convert in to voilat and green colour. it is called colour fade. assambaling parts is lose of bord and other. it can be correct by soilding by expert tech. it is more seen in old crt monitor. thanks
Jun 14, 2009 | ASUS LCD Monitor
Videoseven 19
MS-DOS color command Examples. Color 0A = Creates a Black background with light bright green text, similar to many of the FTP, telnet, and old BBS console screens.
Good Luck, Please dont for get to Vote/Thank You
Dec 19, 2007 | Gateway FPD2275W LCD Monitor
Constant white screen
check the brightness and contrast from the menu on the monitor try increasing it ... the problem will get solved...
if same problem persists contact ur near by experrt technician he may tell that the tube is gone he must recharge it....
Sep 11, 2006 | Sony SDM-HS73P 17" LCD Monitor
X2Gen MG19MY 19" LCD Monitor Logo
120 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
