Question about Siemens Gigaset 8825 Cordless Phone
Switch Lines on hand sets
How do I switch from line 1 to line 2 on the handsets?
I had the same problem before. I found the answer by reading the Appendix C: Base Station Menu Tree in the munual.
If you don’t have the manual, here is the link:
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000027395.pdf
Go to System Settings/Automatic Line Select/Base Intercom 1-8, select the Manual Line Select. After this setting, when you use the handset to make the call, handset will prompt you to select the line.
Posted on Feb 14, 2009
Really bad crackling sound on certain calls
if only happens on certain calls it could either be the handset itself, a week point on all corded phones is the cable between the handset and the body of the phone. whilst talking to someone on a call wiggle the cord where it enters the handset, does it crackle if not do the same where the cord enters the phone body, if no crackle likely not phone.
next select a line if you have more than 1 line note which 1 and dial 17070. this will BT autotest the line. if more than 1 line on system do same for all lines. check with your system admin if there are quick codes to select individual lines, eg dial 9 for any line or 81 for line 1 82 for line 2 etc .
if you get crackle still on 1 of the lines get your maintainer to check the lione at the cable head where lines enter building
Mar 02, 2015 | Panasonic KX-T7731 Corded Phone
Dpu 414 stacks lines
Set SWDIP switch 1, switch number 4 to ON. That switch controls whether when you get a CR (Carriage Return), you get just that carriage return or a CR-LF (carriage return + line feed). You need the latter. Setting the switch to ON will accomplish that. Have a good day.
Jul 02, 2012 | Seiko DPU 414 Matrix Printer
Problem for Plantronics CS50 Wireless Headset - I can hear the person on the other end when the configuration dial is set to 1,2 or 3. But th other person cannot hear me. When I set the dial to 4, others...
The following is a cut from Plantronics web site. I hope it helps, It's just possible you have missed a setting, such as the mute switch.
The CS50 has both transmit (how you are heard) and Receive (how you hear) controls on the unit itself.
The Master Transmit controls are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting. You can fine tune this setting with the Plus (+) and minus (-) buttons on the back of the base that are above and below the picture of the microphone.
The Master Receive setting is on the back of the base (below the picture of the microphone) there is a 1234 switch 1 being the highest setting and 4 being the lowest setting. You can fine tune this setting by using the volume control on the headset itself. This is the rocker volume wheel on the back of the headset (opposite of the microphone).
The headset volume control also doubles as a mute switch if you press it in, instead of rocking it back and forth.
There are also configuration settings on the left hand side of the base. This is a dark grey dial with a 1234 on it. There are notches to the right of this dial. Whatever number is lined up with the notches it what setting you are on.
This needs to be set to the clearest setting.
There is a silver button on the headset itself which is your “Talk button”. This is what you press to use the headset and or transfer the call from the headset back to the hand receiver.
There is also a switch on the right hand side of the base which is your the IntelliStand feature.
When the CS50 is used in conjunction with the HL10 handset lifer you can enable the IntelliStand feature.
The IntelliStand feature senses when the headset has been removed or placed into the CS50 base unit which automatically activates the Handset Lifter and enabling headset/handset mode to answer or end the call.
There is a switch towards the bottom on the right side of the base unit that will switch the IntelliStand feature On and Off.
Apr 11, 2010 | Plantronics PL-CS50 Professional Headset
THE PHONE LINES ARE ARE MAKING A CRACKLING SOUND, WHICH SOMETIMES MAKES IT DIFFICULT TO HEAR WHAT IS BEING SAID
Crackling and buzz can come from a few different sources. I need a few more details. Is it on all phones? Is it on all lines of all phones? Does your caller hear the crackling too?
If it's in just one phone then switch out the handset & cord to see if the problem stays with the phone or the handset. You may just need a new hand set cord.
If it's in more than one phone then the problem will need some more testing.
Feb 23, 2010 | Panasonic KX-T7050 Corded Phone
Transfer case wont engage
shift into 4wd and move truck a couple of feet.
if light is still off, park truck block the wheels set the park brake jack right front wheel and try to hand spin the wheel if wheel doesn't turn 4x4 is functioning properly but there is a wiring problem use an ohmmeter to check the 4x4 switch wiring fuse and bulb
if wheel turns freely the front axle or transfer case is not engaged
attempt to hand spin the front driveshft if the driveshaft will spin the transfer case is not engaged check the transfer case shift linkage, problem is in linkage or transfer case internals
if the driveshaft will not spin the transfer case is engaged properly
with trnsmission in neutral or park start engine measure vacuum on the two vac lines at front axle shift motor . one line should have approx 20" vacuum. other line should have none
if no vacuum measured look for vac leak or bad vac switch
if both lines have vac look for a bad vac swithc or ruptured cad actuator diaphragm
if one line has 20" +- VAC
move transfer case lever to 2wd measure vac again lines should have swapped vac signals
if no vac switch bad or 4wd shift likage needs adjusting
if yes vac motor bad or stuck or shift fork stuck
remove vac shift motor from the axle attach vac lines to shift motor engage disengage 4wd
does shift motor plunger move at least 1/2 inch
no shift motor bad
yes check axle shift fork and vac motor for binging
Jan 27, 2009 | 1999 Dodge Ram
No link to base
The solution works!
Thanks.
Feb 15, 2008 | Panasonic KXTG2344 Cordless Phone
ELBT595 & TCX905 compatibility
from uniden regarding your base station:
"This expandable base system is compatible with Uniden handset models ELX500, TCX400, TCX440, and TCX805. However, only the ELX500 is compatible the base system's Bluetooth and CellLink features."
Feb 09, 2008 | Uniden TCX905 Cordless Expansion Handset
EnGenius DuaFon 1X
Registration:
a. Press MENU-6 to enter the registration mode
b. Press and hold the base’s Registration (REG)
button for 2 seconds until 4 LEDs light up. (Located on the base where you plug in the phone jack)
c. Press handset key “1”, this completes the
registration process. When you register the
handset to BASE 10, the base will assign a
handset ID between 11 and 19. The assigned ID
will be displayed on the handset LCD, indicating
successful registration.
d. Repeat above steps for all additional handsets.
e. The first two handsets registered will be given ID
11 and 12, which gives them administrator
privileges.
Jan 04, 2008 | EnGenius DURAFON1X DuraFon 1X System Phone
Handsets bypassed; need to restore
I found some old notes of mine you could try, but they're involved: 1. [Spkr],#,603,500,[Speed Dial],[Redial],[Spkr],pick up hand set, hang up. 2. [Spkr],#,656,9,phone extension,[Redial],[Spkr],pick up hand set, hang up. 2. [Spkr],#,657,#,phone extension,[Redial],[Spkr],pick up hand set, hang up. Were you able to find a free manual online? Pat
Feb 20, 2007 | Toshiba DKT-2010 Corded Phone
Siemens Gigaset 8825 Cordless Phone Logo
254 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
