Question about Panasonic DMR-EZ47V DVD Recorder/VCR
How to set my vcr dvd player to record from the tv
After the timer is set, what do I do, to make the recorder go off automatic, at the time that it has been set to?
Remote broke can i set upp without it
Posted on Feb 05, 2009
How to record
Be sure you have first set the clock correctly. After setting timer recorder time, channel, speed etc. hit enter to highlight the setting to be sure you have it. Press setup to put you back to tv screen. Then press t-Set button on remote. Unit will automatically shut off and there will be an amber symbol on the unit lcd along with the time. This indicated the unit is in the timer mode. It will automatically turn on and record the program at the set time.
Sep 26, 2012 | Sylvania DVR90VE DVD Recorder/VCR
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
I'm thinking of buying this VCR/DVR combo - Toshiba DVR670 -- but first I want to know if you can program the VCR recording timer using time span information -- not just those codes for programs you find...
Usually, depending on the source, or channel, timer recording can be performed on a VCR; even this model.
The short answer is YES - you can record cable times or set manual scheduled recordings on this VCR. It depends on the channel(s) available in your area, and/or the source (such as cable receivers/set top boxes, etc.) which are intended to be recorded.
Feb 09, 2010 | Toshiba DVR670 Player
How to program vcr to record digital channels?
Any VCR select to input source from where recording.
So select appropiate Euroscart or other AV connection.
Digital channel will be your digital cable set top box or sat receiver, DVD player, whatever. Very unlikely you use a digital capable set topbox to output to your VCR or TV with old fashioned RF coax cable where you have to tun in to cerain RF frequency under Channel 0 or so. So when in timer menu select that input source connection. Direct recording without timer select the source with remote. This solution applies to all brands
May 02, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
Can play video, but can't record
Have you tried to record your channels with the converter switch set to antenna?
In otherwords;
Step 1. With your converter switch set to converter mode select the Direct tv channel you wish to record.
Step 2. With your converter switch set to antenna press the record button on your DVD Recorder.
Step 3. Switch your converter switch to converter mode.
I hope that you find this solution helpful.
Feb 06, 2009 | Philips Magnavox DVD/VCR Dual Player
Timer programming
The remote control is key to timer recording. Notice the selections are color-coded: grey-black for VCR, gold for DVD. Then look at the second and third rows of buttons. Each button has multiple functions depending on if the VCR or DVD button has been pressed. To record from TV signal to VHS, press the VCR very top button. (The controller will also control your TV if set up properly, so be sure the small switch at the top-left of the controller is set to the VCR/DVD side. I use a separate controller for my TV so I never change this.) Now press the "PROG." button located beside the "3" button. (Your television must be on and set to "see" the VCR not the normal TV signal.) Now look at the second row of buttons, the ones with the "+" signs. The grey words below them indicate what they'll do when pressed (the same buttons do what the gold words say when the DVD is selected.) So to set the start time, press the first "+" button with the word "START" below it. That sets the start time of the show you want to record. It'll go in 30-minute intervals if you hold it down, otherwise it's a minute-at-a-press. If you go too far, you can back up with the third row's "-" button. When you have the start time set, move on to the next button labeled "STOP" and similarly set the end-time of the program. Continue with the third "+" button to set the date you want to record. Lastly, set the channel by pressing the fourth "+" button labeled "CH." It's a bit tedious if you have a high channel number to get to. When you have all these set properly, it's important to then press the "TIMER" button (located next to the keypad number 6). That turns the VCR off but "watching" for the settings you've just made, and it'll wake up and do the recording at the proper moment. You can confirm you've got it waiting by looking at the display on the VCR; to the left of the channel number a red "clock" image should be lit. That says it's waiting. You can program several shows to record by repeating these steps, or you can do them all sequentially by setting the first one, then pressing the "PROG" button again (rather than the "TIMER" button) and setting up the next recording. When you're done, THEN press the "TIMER" button and the VCR will go to sleep until it's assigned wake-up time.
Sep 16, 2008 | JVC HR-XVC30U DVD Player/VCR
Samsung DVD-V4600A Combo DVD / VCR will no longer timer record to Videotape
Storms tend to fry most delicate electronics. Quality surge protection is required.
Ben
Jul 25, 2008 | Samsung DVD-V4600 DVD Player/VCR
Owners manual
Turn on power to TV, and DVD/VCR, set TV to channel 3 or 4
Insert video cassette
Select desired channel by using CH/TRK
Set the desired recoring speed (SP or EP)
Press REC once
Press STOP to stop recording.
Timer Recording,
Press Menu and the Main menu will appear.
Use up and down arrows to choose the Timer record menu
Press Select/Enter to go to the Timer Record menu.
Use arrows to choose the program no. (1-8)
Use down arrow to choose Month option
Use arrows to choose the desired month
Use down arrow to choose the Day option
Use arrows to choose the desired day
Use down arrow to choose Start Option
Use arrows to choose the desired start time
Use down arrow to choose the Stop option
Use arrows to choose the desired stop time.
Use down arrow to choose the Channel option
Use arrows to choose the desired channel (Channel, Line1 or Line2)
Cable users: If you have Cable TV and used Cable Box in Connecting Antenna/Cable TV to DVD/VCR using a cable box converter, you must set the channel in this step to match the cable box output channel (usually 3 or 4). Change channels on the cable box instead of the DVD/VCR
Mar 15, 2008 | Sanyo DVW-5000 DVD Player/VCR
Channel setup for VCR recording
WHAT YOU HAVE TO DO IS GO INTO SETUP AND DO A 'CHANNEL SET' EITHER AUTOMATIC (WHICH DID NOT WORK ON MINE) OR MANUAL AND ENTER EACH AND EVERY CHANNEL YOU WANT TO RECORD. THIS IS TIME CONSUMING BUT THAT IS THE ONLY WAY IT WILL WORK - IF YOURS WORKS WITH 'AUTOMATIC' YOU GOT IT MADE
Jan 24, 2008 | Philips Magnavox DVD/VCR Dual Player
Presidian DVD Recorder
i have a presidian dvd recorder and when i put in
a new blank dvd-r disc it only gets it prepared up to
21% and tthen it stops and opens
Nov 25, 2007 | Emerson EWD7001 DVD Player
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
56 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
