Question about Toshiba 40H80 40" Rear Projection Television
Toshiba 40H80 Rear Projection TV Picture Rolling/Scrolling
Our friends gave us this TV a year ago because they said the picture would keep "rolling" (no vertical hold). We've used it now for a year and the problem has just started happening for us. At random times, the picture just starts to "roll" vertically. Sometimes switching the power on and off quickly several times via the switch on the surge protector that it's plugged into fixes the problem. Sometimes not. But the issue has been getting more frequent in the past couple of weeks. We just got a Wii last week and whenever we try plugging the Wii into the TV, it seems to set off the vertical scrolling immediately (though this could just be a coincidence -- the Wii has worked perfectly on the set a few times, too).
Is this worth calling a repair technician in to fix? Do you think this TV too old to be worth fixing? Any help you could suggest would be most appreciated!
Thank you!
  • Anonymous May 18, 2009
    Identical problem. I just called a repair center and he said that it's a component level problem and on a set that old, repairs are too costly. Basically, toss the box!
Problem is bad hyper module or can have tech repair it with capacitors
Posted on Apr 29, 2009
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half...
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half and half screen. Sound is fine, can you help me with this problem please.
Jun 23, 2010 | Sony KP-51HW40 51" Rear Projection...
Pc to tv connection keeps scrolling vertically
its probably your caps on the signal module
c2p05 and c2p08 100uf 16v capacitors
did the problem used to only happen when it was cold? = caps
is there rolling bars? is it a dark unstable picture? = caps
let me know if you need further assistance, the caps solder in
Jun 18, 2010 | Mitsubishi WS-55809 55" Rear Projection...
ROLLING PICTURE HATACHI
Replace Verical IC and componets in same circuit maybe 2or3 bad capacitors. 100uf 35v ,1uf or 2.2uf 50volt. you need to order vertical Kit.
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Sound, No Picture
The only thing you can do is to unplug the tv for 30 min. Then turn it back on and see if that fixed it. If not call a repair man, you are most likely missing a power supply voltage or deflection voltage.
May 26, 2008 | Toshiba 40H80 40" Rear Projection...
Vertical rolling on Hitachi 60SBX78B
It ended up being the Verizon Fios box. We recycled it and the picture stopped rolling. Thank you for being here to help. If I have any future questions, I'll definitely use your site.
Mar 07, 2008 | Hitachi 60SBX78B 60" Rear Projection...
40H80 Toshiba Rear Projection TV
it sounds as if it is solder related, bur hard to say for sure. You ay need a service manual to actually trouble shootthe power supply and opeating circuits. I will post a lnk where you can get a service manual emailed to you
http://servicemanuals.vstore.ca/
Feb 09, 2008 | Toshiba 40H80 40" Rear Projection...
TOSHIBA 40H80 projection TV - no sound / no picture
it could be, that would be the first thing i would do to rule out I would first check for loose connections on the board.
Dec 06, 2007 | Toshiba 40H80 40" Rear Projection...
Vertical Rolling picture
Vertical IC, caps or the hyper board would be my guess. None of which you can do yourself without some serious electronics experience. You'll need to ESR test the caps in the vertical circuit first, then move-on to static testing the vertical IC. If either of these are the problem it's not too expensive. The Hyper Module is a different story, usually only replaceable as a module but you can also send them in for rebuild to PTS Electronics.
Nov 05, 2007 | Toshiba 55H70 55" Rear Projection...
Picture is Rolling..stops after some warm-up
I have seen this many times. There is a 9 volt regulator on the small signal board that causes this. The regulator goes bad and the 9 volts starts dropping, especially at start-up when the regulator is cold. If the voltage is below 8 volts then the picture gets dark and the vertical becomes unstable, with the picture squeezing down and/or rolling. As the regulator warms up the voltage starts rising back towards 9 volts and the symptoms start clearing up. There are 3 regulators in a row on the board and the regulator in the middle is always the bad one. Replacing that regulator should cure your problems but it should be replaced by someone experienced in servicing Mitsubishi projection TV's because pulling the chassis out is quite tricky.
Aug 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Toshiba 40H80 40" Rear Projection Television Logo
611 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
