Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door won,t open with remote or keypad from outside, sometimes
Seems like the problem has something to with heat,when the sun moves away from the door everything works fine,and if I take the remotes inside they work fine.
  • donei2 Feb 06, 2009
    keypad and remote have new batterys,when the sun moves away from the garage door,the remote and keypad work fine
Sounds like a dead (or dying) battery in the keypad
Posted on Feb 05, 2009
My sears Craftsman 1/2 HP garage opener starts and quickly stops with a ****. sometimes only moving the door a inch or so. Lights on opener flash once, somethings power completely seems to go off... power...
Make sure all the connections are tight on the rear of the motor housing. The terminals where all those white wires go must be tight. Also make sure the plug into the wall is snug and not sloppy.
Jul 19, 2012 | Sears Craftsman LiftMaster Chamberlain...
Hi... I have a Sears Craftsman Garage door Opener Model# 139.53600 Outside garage door keypad which is hard wired (electric) isn't working. However the inside keypad and the car transmitter are both...
A wireless keypad will not work with your opener. Your opener is pretty old and the new models are much safer. You might consider replacing the entire thing.
Feb 22, 2011 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: Can I bypass the sensors on my garage door opener?...
You cannot bypass the sensors but you can try reversing their position so that the sun isn't hitting the receiving unit. You can also move them back from the door or use something like the tube inside a roll of toilet tissue to shade the lens.
May 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
I recently had to change the outside entry code on my garage door and since then my gargage door remote will not open or close my door. The code works fine, but the remote does not. The batteries seemed to...
You might possibly have held the smart/learn button in too long and erased the code for the remote. Hold the button down on the remote and then press and immediately release the smart/learn button. This should program it for the remote. Now make sure the keypad is still working.
Oct 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
We moved into a house with a LiftMaster garage door opener that we are guessing is almost 10 years old. No problems when using the one handheld remote we were given or the wall control; however, when...
Just to satisfy me would you try your original handheld remote once to make sure it is working properly. The wall control is hardwired so it is not a question.
Sep 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener only works from a couple feet away
On the rear of your motor unit just to the left of all those white wires you will see a small light. If this light is flashing randomly it is normal. If it is flashing rapidly it is an indication of interference or you have keyed your remote. It really sounds like interference and you will have to do some more checking things.
315 mhz is the radio frequency and you cannot change that. In fact if you purchase a new opener you will get that same frequency.
Your opener was made by Chamberlain Mfg. Co. that also makes Liftmaster. That may be where the confusion comes in.
Jul 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster Remote garage door openers work intermittently.
check to see if your ant. is up inside of the cover it's a little black wire that hangs outside of the operator shiould be about 6 inch.
Jun 02, 2009 | liftmaster Chamberlain Garage Door Opener...
Garage door will only close with keypad code it will not open
UNPLUG THE UNIT AND WAIT 5 MIN.
WHEN YOU PLUG IT BACK IN CLAER ALL CODES BY HOLDING DOWN THE PROGRAM BUTTON FOR 20 SECONDS.
NOW TRY TO PROGRAM EACH REMOTE AND KEYPAD - IF THERE IS STILL A PROBLEM CHANGE THE BATTERIES AND REPEAT THIS PROCEDURE.
I HOPE THIS HELPS
Mar 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote only closes the garage door, will not open it
Anytime a door opens and/or closes randomly or doesn’t work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation / interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
In your case the expansion of the wall in the afternoon may be enough to cause pressure on the wire to increase the problem – works in the morning but not the afternoon.
Also after you change the batteries you need to reprogram the remotes.
HOPE THIS HELPS
Aug 08, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
191 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
