Question about Epson Stylus C86 InkJet Printer
C86 Epson printer will not print.
A red light is flashing on my Epson C86 pinter and it will not print anything.
  • Anonymous Feb 06, 2009
    green button is flashing and red button in the middle is on. will not print.
  • Anonymous Feb 12, 2009
    put new black cartridge in but will not print b&w
  • 353 Answers
Please see your user manual for the meaning of the various light combinations, or if you don't have one, see:
http://files.support.epson.com/htmldocs/sc86__/sc86__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
and look at "Diagnosing Printer Problems".
BOBDOYLE - can you confirm which red light is flashing? If it is the ink light, see the instructions for changing ink cartridges. If it is the paper jam light, check for a paper jam. If you still cannot fix it, come back with a new comment giving any further information.
If this advice was helpful, please rate it.
GUESTS - you both have quite different problems to bobdoyle. If you require specific further help, please register and post a separate request for help.
Posted on Feb 15, 2009
Two red lights flashing, but i can't figure out what's wrong
According to the documentation for your printer.
Red probsolv.6.3.11.jpg paper and probsolv.6.3.12.jpg ink lights flash alternately Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. If the lights are still on, contact your dealer or Epson as described in Where To Get Help.
Dec 16, 2010 | Epson Stylus C86 InkJet Printer
My epson c86 will not print but the 2 red lights to the left of the on/off button are flashing alternately
need to download adjustment program. you can found it "Indoreset" website.
reset wast pad counter
Jan 08, 2010 | Epson Stylus C86 InkJet Printer
I installed new ink cartrages in my Epson C86
this is idicative of a waste pad counter overflow, the ssc printer utility can clear the inbuilt counter but if your using your printer a lot it would be a good idea to replace or clean the waste pad, its inside the printer and will bee messy but if your doing lots of prints it will be less messy than if it overflows
Sep 26, 2009 | Epson Stylus C86 InkJet Printer
Epson stylus D88 - blinking red lights
this means that your printer need to be reset this should work http://www.ssclg.com/epsone.shtml
Nov 21, 2008 | Epson Stylus C86 InkJet Printer
Epson Stylus C86 won't print
You have to check if the waste pad of the printer is full. If this occurs, you have to call a technician to replace it (or yourself can do , if you are able to). With the waste pad replaced, you can reset the internal counter with this program :
This program can show you if the waste pad is full, or what problem is happening.
Apr 07, 2008 | Epson Stylus C86 InkJet Printer
Problem after jam paper
Turn off printer
-check for specks of paper inside the printer or parts that may appear to be damage.
-turn printer on
If you'll get the same error lights chances are there is an internal error. Sensor mechanism might be damage.
Check this site: www.epson.com/loyalty and use the passcode: Lock then register.
Thanks for your time, hope this will help.
Apr 05, 2008 | Epson Stylus C86 InkJet Printer
Epson Stylus C86 printer flashing lights
then you , like the printer are stuck? well, then open it up, inspect it closely, and find the little paper that is inside and making it flash red..
Mar 22, 2008 | Epson Stylus C86 InkJet Printer
EPSON STYLUS C86
Let's Try first if it can print without using your computer just to check if printer is working fine by itself.
step1
Make sure its not connected to the computer and there is paper loaded on the printer. Turn off printer, press and hold paper button (middle button) then press and release the power button (right button). If you can see a flashing green light release your hold on the paper button.
If it prints by itself good go to step 2 if not check what lights do you see. Solid red light on ink light (tear drop button) means one or more inks is empty. Epson printer will not print if one or more ink is empty.
step2
Check if computer can detect printer goto start/control panel/systems/ click on hardware tab and click on device manager
On device manager click on Universal Serial Bus controllers press on the "+" sign check if there is USB printing support on it
Check if there is a mark (ie. ?, !, red x mark). If none good there is no conflicts. If there is a mark right click on USB printing support and click on update driver and install recommended
Oct 21, 2007 | Epson Stylus C86 InkJet Printer
Red Paper light keeps flashing
Try to find thge combination of buttons that reset the printer. there are many possiblities due to the modles - but try pressing any 2 and whilst holding them down switch off and then on again. Also this utility could proce use full. When it is loaded -right click the task bar icon. www.ssclg.com
Oct 02, 2007 | Epson Stylus C86 InkJet Printer
Epson Stylus C86 InkJet Printer Logo
261 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
