Question about ASUS M2N-SLI Deluxe Motherboard
Asus m2n sli deluxe sli 1 is 16 and 2 is 8 how to work 8 8
Have two 9800GTX+,and i want to know how to switch SLI
to speed x8(on firs PCIe),and on second PCIe also x8.Firs card works with speed of PCIe x16, and second x8.
MY rig is: m2n sli deluxe,kingston ddr2 800 4x 1gb,cpu 6400+,coolermaster extreme power 650w ,sound blaster xfi titanium Fatal1ty pro.v stream terminator tv card ,pci ide controler ,2 sata hdd wd 80gb wd500gb ,1 ata wd320gb
  • 1,602 Answers
THIS MAY BE THREE WAYS ONE IS THREW THE BOIS
AND
JUMPERS ON THE MOTHERBOARD
VEDIO CARD
AND
SOFTWARE DRIVEN FOR THE MOTHERBOARD AND VEDIO CARD
THE MONITOR TOO [DRIVERS]
PROPERTIES, ADVANCE SETTINGS
IF YOU NEED MORE INFO PLEASE CONTACT THREW THE WEB SITE
ROD
Posted on Feb 05, 2009
Need audio installer asus m2n-sli deluxe
If it is: M2N - SLI Deluxe:
http://www.asus.com/product.aspx?P_ID=szSFtrap7crpBaQE
if: M2N - SLI Deluxe/Wireless Edition
http://www.asus.com/product.aspx?P_ID=0jMy2X8lKstYRvev
select your OS
Aug 06, 2010 | ASUS M2N-SLI Deluxe Motherboard
Boot up problems on an Asus M2N-SLI Deluxe motherboard
Try reseating the power cable to your HDD and also the data cable to and from your motherboard. If no joy - then it sounds to me like a power supply unit failure
Dec 03, 2009 | ASUS M2N-SLI Deluxe Motherboard
BIOS voltage settings for ASUS M2N-SLI Deluxe 570 SLI chip set.
Hi glen909nwi,
Here's the configuration for that board. If your trying to overclock, you'll want to go with a higher setting.
CPUChiosei HT Voltace 11.20 VI
Allows you to set the pocessorhipset HyperTranspoit voltage.
Configuration options: [1 .20V] [1 .25VJ 11 .30V] [1 .35VJ [+1 .40V1 [+1 .45V] [+1 50V]
Chtoset Core Vo#aae f1.40V1
Allows you to set the dlipset core voltage.
Configuration options: [1 .40V1 [1 .50V] [1 .60V]
Ctitpset Slan&w Core Vo?taoe 11.40 VI
Allows you to set the diipset standby coe voltage.
Configuration options: [1 .40V] [1 .6OVJ
CIhVsef Fi-E Voitaae 11.50 VI
Allows you to set the dlipset PCI Express voltage.
Configuration options: [1 .50V1 [1 .55V1 [1 .60V] [1 .65V] [1 .70V1
CPU Vcore Offset Voltage fDisabdJ
Allows you to csable or set the processo vCore offset voltage.
Configuration options: [Disabled] [Offset lOO.OnIV]
ASUS M2N-SU Deluxe
Oct 21, 2009 | ASUS M2N-SLI Deluxe Motherboard
Can a p5n-e sli handle a single 9800gtx? I
Yes as long as the 9800gtx is PCI Express x16. I am assuming the p5n-e is the Asus MB. Since I couldn't find any other Manufacturer using that MB#
Sep 19, 2009 | ASUS P5N-E SLI Motherboard
Something wrong with SLI
If you are using two SLI card they need to be bridged together so that the GPUs work together to process the load. Also, in your BIOS you must make sure you configure it to use SLI. Furthermore, the most important thing is that if you are using SLI cards that you update the graphics softeware and set the cards to be bridged. SLI is flaky sometimes, just have to iron out the behavior and tweak it over time and make sure that everyting is clocked right.
May 27, 2009 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
ASUS M2N-SLI DELUXE 2 hr "warm up"
Try changing the Motherboard battery it could be flat
Oct 31, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Running dual bfg 8800gtx oc2
Hey, I own the same board, well the brother model, M2N-SLI and on both boards its the same, X8 when two cards are used, 16 when only one card is used, I have 8600GT two of them, previously used in sli, but now with 3 monitors I don't use sli at all, I still think both cards are working at x8 even if sli isn't enabled.
Sep 24, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
M2N- SLI Deluxe Motherboard won't power-up
Look for blown capacitors. Check this site for example pics.
Jun 29, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Second display not working
hi check for the BIOS settings for having both the cards work ..if not then try interchanging the card & slots with each other to check if one of it is faulty?
Bye Let me know
Dec 15, 2007 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
ASUS M2N-SLI Deluxe Motherboard Logo
301 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
