Question about Sanyo DP42746 42 in. Plasma Television
Cannot scroll through menu
I have a sanyo 42 inch flatscreen and i can bring up the menu but cannot scroll through it or get it to work at all
  • debob2012 Mar 05, 2009
    i ordered a new remote specific for the tv and that worked fine thanks all
  • Anonymous Mar 19, 2014
    Im trying to find the menu button on my sanyo flatscreen
  • 71 Answers
Use the down arrow button. u shoul be on rite video source
Posted on Mar 05, 2009
I have a Sanyo Flatscreen, the original remote was lost. Now when I turn on the TV the picture is to big to fit. HOW do I adjust it without the remote?
use the menu button on the side of the tv
that brings up the screen menu
using the channel and volume buttons move around until you find aspect ratio
find the one that fits the screen and press the menu button to save and exit
it could be a pixel setting so find pixel settings while the menu is on the scree and adjust to the correct pixel setting
there are plenty of remotes for tv units on e-bay
all you have to do is select one that is for sanyo led/lcd tv's and read the details to see it it works your model tv
Oct 01, 2016 | Sanyo Televison & Video
Sanyo TV will turn on but no picture and will not turn back off with remote or manually
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 05, 2016 | Sanyo Televison & Video
I have a sanyo 42 inch flatscreen tv. When I turn on the power, there's sound but no picture. Could this be a power supply issue?
Might be. But, before making it sure, you have to confirm the condition of its back light inverter baord, and CCFL lamps.
Sep 27, 2012 | Televison & Video
Universal remote (GE 24116) that i purchased to replace the lost remove control for my sanyo 42 inch tv won't work. the arrow buttons don't work in the menu which is the only reason I bought the...
Hi, You need a code to match with your TV remote. The codes for the Ge universal remote for Sanyo are 0049 0097 0110 0004 0268 0012 0108 0180. You will have to try each code seperately untill you get one that works. Good luck.
Sep 09, 2011 | Sanyo 42 in. LCD TV
My Sanyo 26" flatscreen tv
hi,
if u using a cable connection direct to tv. then goto the setup menu and select auto tune function. wait till all the channel memories. for any further assistants contact me through fixya.
ok
Dec 13, 2010 | Sanyo DP26746 26 in. LCD Television
Why does the audio output on my 42 inch flatscreen tv not putting out any audio for my stereo. I have a Sanyo DP42849 tv, bought new in Dec 09. The audio worked ok for about 2 months hooked up to my...
all you need is optical toslink to rca converter(adapter)
but you will really loss some clarity and features
because converting digital to analog always eats up quality
and the disadvantage is still now these adapters has 2.1 output not 5.1
i hope this will solve your problem
regards,
cseian
Jun 15, 2010 | Sanyo DP42849 42 in. HDTV
Sanyo Sound going in and out
the first thing you should try is to connect exturnal speakers, if they work fine, then use them, as the wireing harness has a bad solder joint (inside the TV) you will need to go to yoru onscreen menu to activate the exturnal speakers. If this still occurs, then there is a major inturnal fault, with luck it is still under warrenty, otherwise it will be costly to fix. Due to teh high number if flatscreen failures I and other tech friends of mine have run into, we all agree this is the one case where extended warrentys are well worth the investment.
Feb 08, 2010 | Sanyo DS27800 27" TV
I have a 42 inch aoc flatscreen hdtv. Every thing was working fine until I hit a wrong button on the remote. Now all I get is a no signal message. I have tried every thing, but I cannot get the picture...
If you're on cable then I would think you are connected via a scart, therefore you need to select use your Input button on the remote or the manual button & scroll through the menu & select the AV source.
Nov 02, 2009 | AOC Envision L32W461 32 in. LCD HDTV
The caption button is locked out - I cannot access it or scroll down to it - it skips the button. it's an lg flatscreen 42 inch
Unplug overnight might reset it self it will be back to normal or tries reset everything to factory setting.
Sep 13, 2009 | LG 42PX5D 42 in. Plasma HDTV
Sanyo DP42746 42 in. Plasma Television Logo
163 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
