Question about Canon PC-950 Black and White Copier
Copies fade in and out horizontally
Prints copies like varying gradients of black and white. The top of the copied paper will have black text that grows lighter and darker throughout the page. It does this before it hits the fusing unit so I'm guessing optics or something beyond my comprehension. Any tips, please help!
  • Anonymous Feb 16, 2009
    Toner cartridge has been changed a few times with no luck. Took a flash light to the mirror and lens with no noticeable problems. I'll try cleaning them as you posted and will let you know if that helps! I also made a copy 1/2 way to see if it was the fusing unit, but it is not because the ink was still fading in and out. Thanks for your help!
One of 2 things likely...It could be as simple as your toner cartridge. Do you have another to try?? Otherwise it should be an optics problem. I've only worked on a couple of these, so i can't remember exactly, but basically you want to get the top scanner glass out. I think you have to remove one of the end panels, and perhaps the top back panel. should be fairly obvious when looking at it, the glass, should slide out the end (power should be "OFF" by the way), slide the scanner to the right and clean the mirrors, and bulb, and then clean the glass. replace and check.
Hope this helps.
Posted on Feb 16, 2009
Brother MFC-440CN - print quality terrible, almost non-existent in spite of many cleaning operations.
It sounds like the printhead needs to be replaced. Brother may cover the cost of repair if you call them at 877-276-8437 and tell them the prints are "missing black ink". Very common problem that a new printhead should fix.
Oct 08, 2012 | Brother MFC-440CN InkJet Printer
Full page is not copied
Hi, did you place paper in tray also horizontal? the paper in tray and on glass must be horizontal if you want to copy A4R size.
DO NOT forget to adjust the blue paper size indicator on paper tray to A4R also.
Also under user mode, under copy sett. you can find option for auto rotate, so copier will adjust size automaticaly.
Jul 17, 2010 | Canon iR 2016i Black and White Copier
Xerox DC12 printing black but copy works fine
Yor probles is caused for a pour conection from the fiery with the printer. Check disconecting and conecting again both conectors printer and scanner
Oct 26, 2009 | Xerox DocuColor 12 Printer
Mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Mar 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
My kodak 5100 printer is having problems printing black text
Clean the printhead, then print a demo sheet.
  1. Verify that inkjet paper is loaded in the paper trays.
  2. On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
  3. From the Help menu, select Maintenance, then select Printhead Cleaning. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows a steady green, press Photo and Copy simultaneously to print a demo sheet.
If the Demo print is bad- IE: no black, blurry print etc., then you may need to replace the printhead:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 31, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Canon PC860 - Paper Jam resulted in black horizontal lines in subseq.copies
Greetings,
If the blank ink still cames in the printer means that their still ink inside the cartridge, kindly check if there are papers left inside the printer when it was removed if there is you have to take it off.
Turn off the printer, delete the remaining files that is to printed on the printer dialog box by just double clicking the icon found at the bottom of the task bar.
Turn on the power of the printer, have a printer test to test if the pritned copy is good. Clean the head, or the nozzle of the printer at the maintenance tab.
If the problem still arises means the head align was damage or mess align that happend when the paper was remove forcely.
That's all
Thank you.
Nov 10, 2008 | Canon PC-860 Black and White Copier
Error 9-363
NOTE: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
NOTE: The above solutions are based on jobs using 8.5 x 11 inch paper, single sided, with no more than 28% coverage.
Feb 18, 2008 | Xerox DocuColor 12 Printer
Printing problem
The black cartridge printhead needs to be cleaned or replaced. Follow your printer manual instructions.
Mar 18, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Copying from Colored Paper
No..The exposure will only give you an overall lighter or darker copy.. Dave UK
Feb 23, 2007 | Canon ImageRunner C-3170U Copier
Canon PC-950 Black and White Copier Logo
67 people viewed this question
old marine
old marine
