Question about Tomtom ONE 3rd Edition GPS
Tomtom one 3rd edition well not reformat
I have a problem tring to reformat my tomtom when right click on it in my computer and tell it to reformat it does at least thats what it looks like. It takes it a day to reformat and at the very end it tells me windows cannot reformat it.
  • phmichae Feb 16, 2009
    i am trying to reformat tomtom one so that i can load the application. every time i try to format it says "Unable to complete format". The disk shows up but i cant view the files because when i try to enter the drive, it tells me it must be formatted.
E61N
  • 515 Answers
SOURCE: how to change the home
Tap screen, tap Change Preferences, tap Right Arrow, tap Change Home Location.
Then choose how to enter new home location:
Address, Recent Destination and so forth....
Posted on Apr 09, 2008
E61N
  • 515 Answers
SOURCE: activation code tomtom 3rd edition
Please read this solution:
http://www.fixya.com/support/t504295-tomtom_710
Posted on Apr 13, 2008
SOURCE: TOMTOM ONE 3rd edition NO Maps found
noob
Posted on Sep 09, 2008
  • 848 Answers
SOURCE: TOMTOM ONE MAP GREECE
you need to check the official website for downloading the map .....
if you cant find map for that particular country ...
you need to contact the tomtom for alternative ways to download map.......
Posted on Oct 17, 2008
  • 171 Answers
SOURCE: can not open it to change battery tomtom 1 3rd
I take no responsibility if you damage your tt in this procedure.
To open the tt one third edition and change the battery you will need a # 8 and a # 6 torx bit. Remove the 4 # 8 torx screws on the back of your tt. After removing the screws carefully insert a guitar pic between the two halves starting at the top and continue around to the sides. Be careful so you don't damage the case. After you have gotten the three sides loose (top, right side, and left side gently pull the two halves apart from the top (be very careful at this point so you don't dislodge the USB port). Do NOT take it completely apart at this point because you have to remove the battery and speaker connections (they just pull out with a little wiggling motion). After you have taken the case apart and disconnected the battery and speaker cables you will need a # 6 torx to remove the board (don't skip this step because the battery is held in with two sided tape and you have to pry the battery out). Now that the board has been removed take a small screwdriver and pry up on the battery. Now all you have to do is reassemble your tt in the reverse order. Just remember the smaller screws are for the board
Posted on May 31, 2009
How do i update my Tomtom 3RD Edition (1GB) GPS Systems for free i would appreciate it if you have an answer thanks.
Hi, I was having trouble too and have found the manual for the 3rd edition online
http://download.tomtom.com/open/manuals/one3rd/refman/TomTom-ONEv3-en-GB.pdf
I'm following these instructions:
Installing TomTom HOME
Install TomTom HOME on your computer in the following way.
  • Connect your computer to the Internet and then connect your TomTom ONE to your computer using the USB cable.
  • A pop-up window appears. Select Run TomTom HOME. Click OK and follow the on-screen instructions.
  • If the pop-up window does not appear, browse to the TomTom device on your computer and run the file named Install TomTom HOME.
  • TomTom HOME is also available for download from the TomTom website.
  • For more information visit www.tomtom.com/home
  • Once installed, TomTom HOME will start automatically whenever you connectyour TomTom to your computer.
Hope this helps, Lynsey
Jan 06, 2011 | Tomtom ONE 3rd Edition GPS
Updated Tom Tom One Edition 3 and no have no maps and told there is not enough room to download from computer back up; tried to delete from device but still not enough room
There is this problem with TomTom. Tom do not seem to overwrite the existing map file. So before trying to install the map, you need to delete the folder that contains the map. Once you have connected your TomTom to the computer, close the TomTom home window. Double click on my computer. You will see the TomTom hard drive as a drive (like you see the CD drive). Double click on that . Once the folders of the TomTom hard drive opens, look for a folder named USA_Canada_and_Mexico_P. (Please note: this name is for American continent. For others, this name will be different) Right click on it. click properties. Check whether the size of this folder is approximately around 1.3 GB to 1.5 GB. This is just to make sure we have the correct folder. After confirming this is the map folder, copy this folder to your computer for back up purpose. Once you have it safely in your computer, delete this folder from the TomTom hardrive. Go back to TomTom home software. Use the map guarantee to update/Upgrade the new map. You will see this time around the installation completes without a problem.
Apr 25, 2010 | Tomtom ONE 3rd Edition GPS
My husband bought me a tom tom one 3rd edition
Look at this URL: http://www.tomtom.com/services/service.php?id=16&tab=87
It has Download button for the PDF Manual.
Dec 27, 2009 | Tomtom ONE 3rd Edition GPS
I am looking for the user manual on the tomtom one portable
Go to the tt website then click on support. You will find the owners manual there, or do a google for tt one third edition owners manual. You can find it in a pdf format so you can download it.
Jun 07, 2009 | Tomtom ONE 3rd Edition GPS
Flashes x when turned on
Your os has a problem. Try this in the exact order.
1. Connect your device to USB.
2. Then turn it on
It should then connect to your computer
If it ask's you do you want to connect to your computer select yes
TT home should see your device and load your os.
If it doesn't load your operating system it will get a little more involved, but can be done. If this works make a backup of your tt device but do not use tt home to do this. Make a new folder on your desktop and name it whatever you want. Next go to my computer click on your tt's drive letter to open the drive. Click on edit, select all, copy. Then go to the folder you have created and right click then paste. Now you have a backup you can use if this happens again
Apr 23, 2009 | Tomtom ONE 3rd Edition GPS
No maps found error on tomtom 3rd edition
you need to uninstall tomtom home and then reinstall again you can do this at
http://tomtom.com/plus/service.php?=17
this will take you to thevery latest tomtom home downoad
Jan 27, 2009 | Tomtom ONE 3rd Edition GPS
Change the language from spanish to english on my tom tom one 3rd edition
This is from my tomtom one (not sure what edition) so the page numbers refer to mine.
1.Touch the screen for the menu
2.on page 1 of 3 on the menu, touch the blue wrench (change prefs)
3.press the black right arrow key to page 4 of 7 in preferences and touch the flags icon
4.press your desired language
Jul 17, 2008 | Tomtom ONE 3rd Edition GPS
I need an instruction manual for my 3rd edition tomtom
You can go to the link below then under Tom TOm ONE 3rd edition you can click on user guide on the right of it.
http://www.tomtom.com/support/support.php?ID=3&Language=1
May 16, 2008 | Tomtom ONE GPS Receiver
New tomtom ONE 3rd edition
Make an account here, for free:
http://www.tomtom.com/myTomTom/myProfile/index.php
Then, install Tom Tom Home:
IMPORTANT:
Make a full backup, better safe, than sorry...
Do this backup vith explorer or similar,
just copy ALL content from device to a folder on your computer.
Remember to set explorer to show hidden and system files.
Connect device to pc, update device via TomTom Home....
Mar 28, 2008 | Tomtom ONE 3RD EDITION GPS Receiver
Tomtom ONE 3rd Edition GPS Logo
449 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
