Question about Dell Dimension 2400 PC Desktop
Can I move hard drive from 1 PC(xp home) to xp pro/vista
Well my Dell 8200(XP Home) die. I'm getting a new pc with XP Pro or Vista. Can I move my hard drives(all SATA) including the one with the XP Home partition to the new pc. Will XP Pro/Vista recognize them and assign drive letter to them and I can open the files once I install the applicable programs? I will not run installed programs from the old C: partition.
TIA
  • 2 more comments
  • yman1949 Feb 05, 2009
    I try to upgrade the memory from 512MB to 1GB. These are RAMBUS memory Non-ECC. I got by mistake ECC type. I try them anyway because I was told that they can be mixed as long as they are matched in pair. Powered-up and PC won't boot(no video). Hear a beeping sequence of 5-2-2-1 and back panel LEDs were green, yellow, yellow, yellow which according to Dell manual means "no memory detected". RMA the memory and got correct one. They are the same part # as the original one Samsung PC800-45 Non-ECC. Install them but still won't boot and beeping. Try different combination. No good. I try to reset the BIOS by removing the CMOS battery. Still no good. Finally call Dell and they told me I should have brought it from Dell at about $400. They think the memory were incompatiable and the mobo may be shorted out and no longer work. I don't have any tools to check if memory is powered. The mobo light is on. The fans are on as are the drives. I even remove everything connected to the mobo except the video card, the memory and the power supply. I don't know what else to try. So if anyone has suggestion/solution, please let me know.
    So does that mean all my Word doc, mp3, photo, etc can be opened once I install their programs such winamp, MS Word? Great.
    Thanks
  • regis mizikar Apr 15, 2009
    I purchased new PC to replace an old one. I have all my data files on a separate drive. I want to use the old drive in the new PC.
    Do I just move it? The old PC had XP for home and the new PC has Vista.
    regis
    I purchased new PC to replace an old one. I have all my data files on a separate hard drive. I want to use the old drive in the new PC.
    regis
  • 4 Answers
Yes you can , all you do is remove from old pc place in new 1 and connect up being sata it will be found straight away and given a drive letter
the second part is will all my data be able to open , all data stored on it except for some program files will work the ones that wont work are the ones that had command lines wriiten to the registry.
these fail as the registrty is new and does not contain the data required to run them
hope this helps.
Posted on Feb 05, 2009
    Master:
  • 413 Answers
You should be able to install as many drives as your computer has seta ports. The problem i having is why did your old computer stop working, Or died? If it had anything to do with a virus i would not recommend retrieving this information without a serious anti-virus program. Also keep in mind that you will not be able to boot off the old C:\ drive but you should still be able to access all of its contents. Hope this answers any of your questions but am here for more advice if you need some.
Thanks for using fixya and please don't forget to rate your responses
  • 1 more comment
  • Dan rogers
    Dan rogers Feb 05, 2009
    Just to make sure..this is the correct way to install ram. There should be a blank slot in between the two sticks. Unless of course you have four sticks
  • Dan rogers
    Sorry this pic
  • Dan rogers
    And yes you will be able to open all those files when you install the appropriate programs. And if you had any installation files saved on those drives that makes it even better
Why can i play hidden object adventure pack on my dell with Windows xp
Hi Jennifer,
When you say that you are unable to play , do you mean its not loading ? unable to install it? do you get a specific error message when you try to launch it ?
hidden object adventure pack:
  • System Requirements: Windows XP (Home & Pro) SP3, Windows Vista SP1, Windows 7 . , 800 MHz processor or greater. , 512MB RAM. , 237MB free hard drive space. , DirectX 7.0. Administrator privileges are required to properly install the program on Windows XP, Windows Vista , and Windows 7. Format: WIN XP,VISTA,WIN 7 Genre: ENTERTAINMENT Rating: E10+ Age: 8386390063
if your using windows XP , make sure that you have Windows XP (Home & Pro) SP3 and the rest of the specs mentioned above.
Thank you.
Dennis
Aug 03, 2014 | Video Game Consoles & Games
Downloaded window 7 on my netbook and forgot to backup before installing i had xp
Sadly, there is no direct upgrade path for XP (pro or home) to Windows 7, only Vista. Windows 7 from XP requires a clean install.
Still, check the hard drive and see if Windows 7 moved the files to another location. It installs differently from XP or Vista and there may be a chance they are still somewhere on the drive. Use the search feature to look for a known file and see what happens.
Dec 06, 2009 | Gateway LT2021u Netbook
Pro tools m-powered problem
You may need to check to see which "service pack" you are currently on.
See below requirements:
System Software — Windows XP & Vista
  • Windows Vista Business or Ultimate Edition
    • 32-bit OS Installation Only
  • Windows XP Professional or Home Edition
    • With Windows XP Service Pack 2 or Service Pack 3
  • Not Supported:
    • Windows Vista 64-bit (any version)
    • Windows XP Professional x64 Edition
    • Windows XP Media Center Edition
    • Windows 98, Me, 2000, NT, 95, 3.1, DOS
  • Not Tested:
    • Windows Vista Home and Home Premium Edition
    • Although Windows Vista Home and Home Premium Edition have not been tested or qualified by Digidesign, there are currently no known issues with Vista Home and Home Premium 32-bit operating systems and Pro Tools M-Powered 7.4 compared to the supported Windows Vista Business or Ultimate Edition operating systems.
Windows Vista SP1
There are currently no known issues with Service Pack 1 for Windows Vista based on our initial limited testing and customer feedback. Although full qualification with all Digidesign products has not been completed, we do not recommend against updating to SP1, given the number of important overall system fixes in SP1. We do recommend that you backup your system and create a restore point before updating to SP1, should you encounter any problems after installing the update.
Sep 21, 2009 | Computers & Internet
BOOTMGR is missing Press Ctrl+Alt+Del to restart. Im trying to format an older computer with XP Pro. I physically took out the only hard drive in the computer and hooked it up externally to my laptop to...
The problem is caused by Formatting the HDD in Vista before moving back to the system.
Simplest fix, hook it back to the Vista system and delete the partition from the drive in disk management. Once that is done, then put the drive with no partition in the XP system and boot to the XP CD, create a new partition and install XP
Jan 29, 2009 | Computers & Internet
Windows Vista Home Premium will not let me open PNY Optima Pro Attache 4GB
the files from XP may or may not be readable on vista...and I can assure you vista files will not read on xp..
recommend you get two of those.
no guarantees of interchangeability from xp to vista(why am I not surprised?)
check your computers' warranty here for FREE
Mar 02, 2008 | Computers & Internet
Vist Home & Proffessional
partition your hard drive thats how you can run 2 operating systems on your computer im running xp pro and vista ultimate
i recomend you use vista ultimate it has it all
Jan 03, 2008 | Microsoft Windows 98 for PC
Windows XP Pro installed but computer boots to Home Edition
It sure is possible.
I would take it back to them and demand that WINXP Pro is put back in there and it boot correctly
They saved about 50 bucks putting in WINXP Home.
Sounds like a bunch of rookies trying to pull a fast one.
Nov 13, 2007 | Microsoft Windows XP Professional for PC
No 3d acceleration in Vista on ATI 7500
Well, I'm amazed a C640 runs Vista at all. There's no reason to buy a new hard drive, except for the novenlty of having one loaded with Vista on a C640. It's a great laptop, and runs Windows XP PRo perfectly well. If you have one od the Dell XP install disks, just boot from it, and whenever it finds the vista install, hit excape, then at the next screen hit "D" to delete the partition, then choose "quick format", and load the Operation system. If you need an install disk,let me know. Good luck
Sep 24, 2007 | Dell Latitude C640 Notebook
Dell Dimension 2400 PC Desktop Logo
133 people viewed this question
Alun Cox
