Question about LG W2242T-BF Monitor
Gamma setting Flatron W2242T
I'm trying to find the gamma setting for this monitor in relation to setting available ie -50, 0, +50
Using monitor for photo editing and trying get setting correct for printing,
5 Suggested Answers
waterppk
  • 42 Answers
SOURCE: Best Display Setting for LG Flatron L1732S
Use these charts:
http://www.help4web.net/setup/mire.html
Theory behind it here:
http://www.poynton.com/notes/brightness_and_contrast/
Next time type into Google:
http://www.google.com/search?q=brightness+and+contrast+set+up+page
Posted on Mar 18, 2008
bluegreenash
  • 657 Answers
SOURCE: Pictures are stretched
change the screen resolution to different proportions, sounds like you may have set to 1208 x 768 a more appropriate setting would be 1024 x 768 however switch between the different settings until you find one you like
Posted on Apr 24, 2009
FixinFax
  • 3085 Answers
SOURCE: W2242T's backlight not working...
You can buy backlight fluorescent bulbs on eBay.
Posted on Jul 05, 2009
  • 460 Answers
SOURCE: i want to know ls flatron monitor shape settings
there is usually a default setting in the os menu.
Posted on Nov 12, 2009
SOURCE: i have a lg flatron
Not problem!
Posted on Oct 08, 2010
I have a LG FLATRON model L1720B, problem is that the brightnesss,contrast and gamma options in the picture can't be selected and in the auto modes all the setting is higher than usual which i am not able...
Hi. There should be an option on the menu of that LCD to return or to reset it to factory default, try doing that one it might solve the issue. Hope this helps
Jun 04, 2010 | Computers & Internet
Dark Photos after import
chekck the gamma settings for your video adaptor.
To check it
  1. right click on desktop
  2. go to the properties
  3. click the settings
  4. after that click on advance button.
  5. select gamma settings
  6. and check it out.
Aug 25, 2009 | Computers & Internet
SyncMaster 191t Screen is to dark. Brightness is set to 100%.
make sure you have the latest video driver.
Some video drivers you can configure/enhance your desktop settings.. ie. brightness, gamma, contrast..
If you're using windows, right click on your desktop, click Properties, choose the tab Settings, then click on the Advanced button. Choose your video card tab, and continue accordingly.
Jul 17, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
Power saving mode on screen when I turn computer on
if you are using dvi connector, change to vga connector
Jun 23, 2009 | LG 22" FLATRON LCD Monitor
Sudden lost of color gamma - "discoloration"
GO ON LINE AND SEE IF ANYONE ELSE HAS BEEN HAVING THE SAME OR SIMERLY PROBLEMS OR MAYBE A RECALL ON THAT CERTAIN ITEM.
ADDRESS BAR:
BENQ G2110W GAMMA ISSUES,
GAMMA FAILURE,
LOST GAMMA.
ENTER...................... AFTER EACH COMA
ANYTYPE OF PROBLEMS WITH BENQ G2110W
ENTER
GO ON TO ABOUT.COM, ASK.COM, INFO.COM
ROD
Feb 17, 2009 | BenQ G2110W 21" Monitor
Samsung SyncMaster 510N LCD TFT Monitor
Does the monitor remain on does it switch off?
Problem seems to be hardware related ie monitor itself is defective.Try connecting to another known working system.If monitor is defective it could be a power/inverter related issue or panel could be defective.
Please provide feedback and rate the solution.
Samir
Jun 13, 2008 | Samsung SyncMaster 510N (Silver) 15 inch...
Use these charts:
Mar 17, 2008 | Gateway FPD2275W LCD Monitor
Bright screen with very low contrast
I fixed it myself, it seems that the monitor have some problems remembering it's settings and sometimes it automatically set its settings to crazy values that are out of the range that we are allowed to input. For my case, the setting that was crazy was the gamma setting since it was set so high. I wasn't able to bring it back to a normal setting so I found a way to do it by resetting the monitor. So to reset these display settings such as colour, contrast, brightness and gama, you need to turn on the monitor and unplug the monitor without turning it off and plug it back in again. It will automatically power on and the correct default settings will be present.
This forum isn't very helpful is it?
Dec 09, 2007 | LG Flatron L1811S 18.1" LCD Monitor
Calibration
Have you tried adjusting the "Adobe Gamma" via the setup from your control panel?
Oct 12, 2007 | LG Flatron L1750S 17" LCD Monitor
LG W2242T-BF  Monitor Logo
411 people viewed this question
Top LG Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Teet Bergmann
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
