Question about Dell Latitude D800 Notebook
Cannot find \windows\system32\config\system
My son tried to reinstall a windows operating system - XP. since it was already onthe computer one would think that ity would tell us that it is already on the machine and if we wanted to over write. But the end result is that we are unasble to do anyythiong but get tot he set-up screen or boot up screen. It tries to give us an "r" to repair but that doesn't work. Any suggestions?
Thanks BRian
  • Dan rogers
    Dan rogers May 11, 2010
    is there an option to format the partition and do a full install?
    Do you only have a repair disk?
  • Tricia Scerbo
    Tricia Scerbo May 11, 2010
    It doesn't give you an option to reinstall or install on another partition?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 53 Answers
*** You will need a copy of windows w/ valid serial key *** - boot it up - hold or quickly tap a few times F8, it should bring you to "windows advanced options menu" - you should be able to select which version of windows you want to boot to (try one if it doesnt work try the other) - if that still doesnt work go to another cpu with a cd burner drive - download and burn to cd >>> powermax4.09.iso go to >>> http://digilander.libero.it/YorkOne/powermax/ - insert powermax cd run a format on the HDD - proceed with windows install
Posted on Feb 05, 2009
Registery cannot load hive file/systemroot/system 32/config/software or its log of alternatice is corrupt, absent or unwritable on compaq presario2227US
Solution 1
Requires some tech skills:
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Solution 2 Reinstall Windows Xp
Jan 29, 2014 | HP Compaq Presario CQ60-249US Notebook
Saying:/windows/system32/config/system is missing or corrupted n i dnt now how to fix it wut link exactly do i have to download to my usb to fix it n wut r the steps?
Assuming it is windows XP here are the steps to fix that error:
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line:md tmp
My YouTube Channel
Click Here Live Tech Support
May 03, 2013 | ASUS Eee PC 2G Surf Notebook
Problem with OS. How can I fix? Net book states - Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM Can you help? Thanks Philip
Note This procedure assumes that Windows XP is installed to the C:\Windows folder. Make sure to change C:\Windows to the appropriate windows_folder if it is a different location.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 03, 2010 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
My desktop shut down and is asking me to re install a 32 windows file. What is this and how do I fix it?
Hi, This normally means that a windows file from the system32 folder is missing or corrupt. You will have repair that by using your operating system cd and go to repair when prompted. If this does not work you may have to install a clean copy of your operating system.
Apr 10, 2010 | HP Pavilion a1220n (A1220NED904AA) PC...
I have toshiba L300 pc laptop, i tried to formati
kindly follow these steps:
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 20, 2010 | Toshiba Satellite Pro L300 Notebook
When I turn on the 1525 Dell laptop...a screen comes up saying windows could not start because the following file is missing or corrupt.windowssystem32configsystem. The page then suggests attempt to repair...
it is nothing but windows registry error. do one thing in another pc download the Hiren's boot cd from internet, write that file in a cd, try to boot from that cd & repair the registry. otherwise just format the operating system & reload the OS.
Jan 10, 2010 | Dell Inspiron 1525 Notebook
Hp paviliondv2050us wont start
Note This procedure assumes that Windows XP is installed to the C:\Windows folder. Make sure to change it is a different location.
If you have access to another computer, to save time, you can copy the text in step five, and then create a text file called "Regcopy1.txt" (for example). To use this file, run the following command when you start in Recovery Console: batch regcopy1.txtWith the batch command in Recovery Console, you can process all the commands in a text file sequentially. When you use the batch command, you do not have to manually type as many commands. Part two loadTOCNode(3, 'moreinformation'); To complete the procedure described in this section, you must be logged on as an administrator, or an administrative user (a user who has an account in the Administrators group). If you are using Windows XP Home Edition, you can log on as an administrative user. If you log on as an administrator, you must first start Windows XP Home Edition in Safe mode. To start the Windows XP Home Edition computer in Safe mode, follow these steps.
  1. Click Start, click Shut Down (or click Turn Off Computer), click Restart, and then click OK (or click Restart).
  2. Press the F8 key.
    On a computer that is configured to start to multiple operating systems, you can press F8 when you see the Startup menu.
  3. Use the arrow keys to select the appropriate Safe mode option, and then press ENTER.
  4. If you have a dual-boot or multiple-boot system, use the arrow keys to select the installation that you want to access, and then press ENTER.
In part two, you copy the registry files from their backed up location by using System Restore. This folder is not available in Recovery Console. Before you start this procedure, you must change several settings to make the folder visible:
  1. Start Windows Explorer.
  2. On the Tools menu, click Folder options.
  3. Click the View tab.
  4. Under Hidden files and folders, click to select Show hidden files and folders, and then click to clear the Hide protected operating system files (Recommended) check box.
  5. Click Yes when the dialog box that confirms that you want to display these files appears.
  6. Double-click the drive where you installed Windows XP to display a list of the folders. If is important to click the correct drive.
  7. Open the System Volume Information folder. This folder is unavailable and appears dimmed because it is set as a super-hidden folder.
  8. Open a folder that was not created at the current time. You may have to click Details on the View menu to see when these folders were created. There may be one or more folders starting with "RPx under this folder. These are restore points.
  9. Open one of these folders to locate a Snapshot subfolder. The following path is an example of a folder path to the Snapshot folder: C:\System Volume Information\_restore{D86480E3-73EF-47BC-A0EB-A81BE6EE3ED8}\RP1\Snapshot
  10. From the Snapshot folder, copy the following files to the C:\Windows\Tmp folder:
    • _REGISTRY_USER_.DEFAULT
    • _REGISTRY_MACHINE_SECURITY
    • _REGISTRY_MACHINE_SOFTWARE
    • _REGISTRY_MACHINE_SYSTEM
    • _REGISTRY_MACHINE_SAM
  11. Rename the files in the C:\Windows\Tmp folder as follows:
    • Rename _REGISTRY_USER_.DEFAULT to DEFAULT
    • Rename _REGISTRY_MACHINE_SECURITY to SECURITY
    • Rename _REGISTRY_MACHINE_SOFTWARE to SOFTWARE
    • Rename _REGISTRY_MACHINE_SYSTEM to SYSTEM
    • Rename _REGISTRY_MACHINE_SAM to SAM
These files are the backed up registry files from System Restore. .
Part Three loadTOCNode(3, 'moreinformation'); In part three, you delete the existing registry files, and then copy the System Restore Registry files to the C:\Windows\System32\Config folder:
  1. Start Recovery Console.
  2. At the command prompt, type the following lines, pressing ENTER after you type each line: del c:\windows\system32\config\sam
    del c:\windows\system32\config\security
    del c:\windows\system32\config\software
    del c:\windows\system32\config\default
    del c:\windows\system32\config\system
    copy c:\windows\tmp\software c:\windows\system32\config\software
    copy c:\windows\tmp\system c:\windows\system32\config\system
    copy c:\windows\tmp\sam c:\windows\system32\config\sam
    copy c:\windows\tmp\security c:\windows\system32\config\security
    copy c:\windows\tmp\default c:\windows\system32\config\default
    Note Some of these command lines may be wrapped for readability.
  3. Type exit to quit Recovery Console. Your computer restarts.
If you have access to another computer, to save time, you can copy the text in step two, and then create a text file called "Regcopy2.txt" (for example). To use this file, run the following command when you start in Recovery Console:
batch regcopy2.txt Part Four Click Start, and click All Programs. Click Accessories, click System Tools. Click System Restore, click Restore to a previous RestorePoint.
Jul 21, 2009 | Computers & Internet
Windows XP Missing configuration?
Sounds like you may have bad RAM. Try removing all of the RAM modules on your motherboard and put only one in the first slot. Start the computer and see if it works.
Jun 17, 2009 | HP L1706 17" LCD Monitor
I was installing Turbo Tax 2008 and Windows XP crashed
Madam/Sir --
I none of the mode is working you need to boot from the cd to do any further steps.
inorder to boot from the cd you need to go to the bios and change the boot sequence to boot order.
It varies system to system once to you boot from the cd try to log on to recovery console and do a manual system restore by following the below steps - :
Step 1:
Boot with the windows XP CD
At "Welcome to setup screen" Press R
Select the appropriate path for windows and press enter
If it asks you for the administrator password, normaly there is not password but if you have a password type the administrator password and
press enter or just hit enter
We will now see the Prompt c:\windows>
Step 2:
cd system32\config
ren system system.old
ren software software.old
ren SAM SAM.old
ren security security.old
ren default default.old
Then type cd Type cd system~1\_resto~1 and press Enter
If you get "access denied" (Error) then
Restart the computer by type Exit and get back to recovery console
type cd \ and it will display C:\>
type cd system~1\_resto~1 and press Enter
Step 3:
Type dir
It will list you restore points
(e.g. RP1, RP2, RP3, RP4, etc...)
Select the one from the list except the last one
Say RP4
· type cd RP3 (or RP2 or RP1 or RPn) and enter
· type cd snapshot and enter
· type copy _registry_user_.default c:\windows\system32\config\default and enter
· type copy _registry_machine_security c:\windows\system32\config\security and
enter
· type copy _registry_machine_software c:\windows\system32\config\software and
enter
· type copy _registry_machine_system c:\windows\system32\config\system and enter
· type copy _registry_machine_sam c:\windows\system32\config\sam and enter
· type exit and enter
The computer restarts and the system will be
Successfully restored
Mar 20, 2009 | Microsoft Windows XP Home Edition
I have deleted svchost.exe from windows xp
Dec 02, 2008 | Microsoft Windows XP Home Edition
Dell Latitude D800 Notebook Logo
109 people viewed this question
Alun Cox
