Question about HP PSC 1210v All-In-One InkJet Printer
Hp psc 1210v won't spit paper out all the way after printing
So my printer prints just fine, but when it's finished printing the paper doesn't get pushed out enough to lay in the receiving tray. When the next page prints the edge hits the edge of the first page and will jam. This means that you have to pick up each page as it is finished or else you get a jam. It's almost like the printer isn't programmed to push the paper away from the wheel enough
jaylex
  • 417 Answers
SOURCE: HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Posted on Jan 28, 2008
  • 3422 Answers
SOURCE: hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Posted on Jun 18, 2008
SOURCE: hp psc 1210v all-in-one printer, scanner, copier will not scan
CHECK BELOW OTHERWISE GO TO HP WEB SITE AND LOOK FOR THE DRIVER SUPPORT TO DOWNLOAD.
Scanning
Use one of the following three methods to scan a document. Method one: Scanning with Windows Photo Gallery
  1. Click the Windows (c01367376.gif ) icon.
  2. Click All Programs .
  3. Click Windows Photo Gallery .
  4. Click File , and then click Import From Scanner or Camera .
  5. Click Import .
  6. Click Scan .
Method two: Scanning with Windows Fax and Scanning
NOTE: This feature works only with Windows Vista Ultimate, Windows Vista Business, and Windows Vista Enterprise.
  3. Click Windows Fax and Scanning .
  4. Click New Scan .
  5. Click File , and then click Scan .
Method three: Scanning with Paint
  3. Click Accessories .
  4. Click Paint .
  5. Click File , and then click From Scanner or Camera .
  6. Click Scan .
Posted on Apr 08, 2009
SOURCE: HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Posted on Aug 31, 2009
PsYcHo EvIL
  • 84 Answers
SOURCE: paper jam in hp psc 1210v all in one printer/scanner/copier
Check for any obstacle in the Outlet of Printer or Paper input area
Which dp size paper u r using try with different photo paper
Posted on Jun 01, 2010
My HP deskjet 2050 all-in-one printer only shoots out blank paper and won't print. It used to say there was no paper in it, which there was. It scans & prints just fine - just won't print...
Any error messages on the printer digital screen or the desktop? I take it the "The ink is fine" means that there is ink in the cartridges!
Try a test print via the Control Panel> Printers and Faxes> properties > Print test page.
May 31, 2011 | HP PSC 2210 All-In-One InkJet Printer
Paper jam in hp psc 1210v all in one printer/scanner/copier
Jun 01, 2010 | HP PSC 1210v All-In-One InkJet Printer
Paper run thru without printing
Empty or dried up cartridge(s) ?
The carridges supplied with printers when new have very little ink (or toner for laser printers) in them. Some will print as few as 500 pages !!
Sep 17, 2008 | HP PSC 1210v All-In-One InkJet Printer
Hp 1210 wont print
Disconnect the USB cable > click on start > Run > In the run box type services.msc and press OK.
> It will open services window > right click on print spool er > click on start.
Now connect the USB cable and try to print.
Sep 16, 2008 | HP PSC 1210v All-In-One InkJet Printer
Why does my HP printer spit out paper without printing it?
I solved the problem by cleaning the feeder of the printer.
Sep 04, 2008 | HP PSC 1315 All-In-One InkJet Printer
My hp printer psc 1210v all in one will not print anything from my computer although i do not have my setup disk
my printer hp psc 1210v does not print through my computer,i think it have driver prblm and window xp not recognize it .please solve this problem.
Apr 28, 2008 | HP LaserJet 1300 Printer
Hp psc 1210v printer print question
hi,
try to clean the rollers using a lint free cloth
> turn off the printer
> open the rear access door
> u will get full access to the rollers
> now clean it and check
thanks and regards
agnel
Jan 28, 2008 | HP PSC 1210v All-In-One InkJet Printer
HP 1410 all in one printer problems
Check "Low memory module" on Printer properties / Printing preferences / Advanced...
Sep 26, 2007 | HP PSC 1410 All-In-One InkJet Printer
Hp psc 1219
try pressing repeatitivly the red cancel button
Apr 16, 2007 | HP PSC 1210v All-In-One InkJet Printer
HP PSC 1210v All-In-One InkJet Printer Logo
42 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
