Question about Nintendo Wii Fit for Wii
Wii Fit - Hoola Hoop
I just got my Wii Fit Board in the last 3 weeks. The Hoola Hoop
exercise doesn't recognize when I stop to grab the hoola hoop and
it boinks me in the head every time. I've tried everything but it
continues to boink me...and I LOVE to hoola hoop...any suggestions?
  • 3 Answers
Make sure you have the power buttin facing towards the back of you, away from the tv!
Posted on Feb 12, 2009
    Sniper:
  • 80 Answers
If you're not shifting enough weight to one side, you can't catch a hoop. I have found that lifting the opposite foot off the board as soon as the toss is thrown helps quite a bit.
If you're still having trouble, evaluate how the board works with other activities on WiiFit. If you notice problems in other areas, you may have a defective unit. There is a calibration feature on the program, and if that doesn't work, try opening up a trouble ticket on www.nintendo.com.
Posted on Feb 05, 2009
Can i do a large applique with my pfaff 7570 using the large hoop
Both the 7560 and the 7570 will only stitch out to the largest hoop it came with which is a 120 x 115 CM hoop (approx 4 1/4 x 4 3/4 inches). If you are using the Creative Big Fantasy Hoop or a Hoop-it-All you will need to split out the design so that each piece will fit within the 120 x 115 hoop. Transfer both designs to the machine. If using the original hoop, hoop your fafabric and stitch out the 1st design. Unhoop and rehoop again aligning the fabric with the hash marks on the hoop. You will have to move the design around on the screen to make a perfect fit. Stitch out the 2nd design. If you are using the Creative Big Fantasy hoop, you just have to hoop the fabric once, stitch out the 1st design and loosen the side screw on the hoop and slide the hoop into place for the 2nd design. Stitch out the 2nd design. The same process applied to the Hoop-it-All.
livingintx@yahoo.com
Feb 28, 2013 | PfaFF Creative 7570
I have a 170x100 hoop. My machine does not give
If it is not highlighted at the machine that means that the design you want to sew will not fit that hoop. You do not need a download for that hoop, just need to use designs that fit the embroidery field.
Sometimes you think a design will fit but the machine thinks otherwise. Trust the machine - it knows where the stitches are going and knows when it can't do it. I just loaded a design whose longest dimension was 97cm, other side was a lot smaller, but it would not let me sew it in the 100cm x 100cm hoop.
I was able to use my 150 x 150 hoop instead but if you do not have a choice of hoop, try downsizing the design in the Adjust menu. Try only one click each for height and width and then check if the hoop is available. If not, downsize one more click each dimension. Don't downsize a huge design using this technique - you won't like the result!
Nov 13, 2009 | Husqvarna Designer I
Wii Fit Hula Hoop does not register on rotating to the right
you rotate left your hula hoop same your body and you move the hula hoop with your body
Feb 03, 2009 | Nintendo Wii Console
Wii Fit instructions for movements are all in reverse
No it is not how Wii Fit is supposed to be. First, let me suggest that you ensure that the power button on the Wii Fit Balance Board is facing AWAY from the TV set. This may seem silly, but it's the most common error. As for the Hula Hoop game, make sure that your weight is all on the side of the Wii Fit Balance Board in the direction that you need to lean to catch the hoop.
There have been instances of the sensors in the Wii Fit Balance Board going out. If you have tried the above steps and you are still getting errors, please go to www.nintendo.com, register your product, and open a problem ticket with them.
Jan 28, 2009 | Nintendo Video Game Consoles & Games
Update for 150x150 hoop
If you have a light gray button then you need to have the embroidery unit upgraded. The hoop will fit on the machine, but the machine can not recognize the hoop. The new hoop holder that needs to be installed will have a second sensor trigger allowing the machine to recognize more hoops. The original holder only has one trigger and can only recognize earlier hoops.
Contact an authorized Husqvarna repair center to have your embroidery unit upgraded.
Nov 26, 2008 | Husqvarna Designer I
Wii Fit Hula Hoop Game
try standing as far back as u can, then jump and then do twenty jumping jacks.
Nov 24, 2008 | Nintendo Wii Console
Wii fit does not recognize movement on board. This is a new problem. I've used the board and know how to move on it. Tried new batteries, recharged battery charger, re-synched, help!!!!!!
I called Nintendo and they said there are sensor problems with some of the boards. We had to send ours back, free of charge (they even paid for shipping) and had a new one within 12 days. 1-800-255-3700 is the repair and troubleshoot #....
Sep 05, 2008 | Nintendo Wii Fit for Wii
How do you use the Plus Hoop on a Husqvarna Viking "Rose" Sewing Machine?
The plus hoop is a multi positional hoop that allows you you to embroider designs up to 4" x 6". It is essential for monogramming and lettering using your Rose. The Rose hooping system is the same as the 1+, the Scandinavia 300 and 400.
The designs you use must be formatted for the plus hoop. That is, the design has already been divided into two or three elements. Each element is an individual design. For instance, say the design is a long stemmed rose. It would probably be divided something like this: design 1: the flower and the top part of the stem, design 2: The middle part of the stem and the leaves, design 3: the bottom part of the stem.
You would hoop up your fabric to be embroidered, attach the hoop to the machine, set the hoop to position 1, select design 1, stitch out design 1, set the hoop to position 2, select design 2, stitch out design 2, set the hoop to position 3, select design 3, stitch out design 3. You should have a complete design when you're done and everything should match up perfectly!
The hoop is divided up into three squares, 4" x 4". Position 1 square overlaps position 2 square and position 2 square overlaps position 3 square. This overlapping allows the designs to stitch out more smoothly.
I hope this helps. Let me know if you have further questions. Carrie
Aug 27, 2008 | Husqvarna Rose
I have a futura 150 and I can't get it to change hoop settings. I will put the small hoop on it but it doesn't recognize it. What do I do to fix it. It will change it on the computer screen but doesn't on...
Do not switch on the machine with the small hoop attached. After changing the hoop reload (close and open again) the design or restart the software or select the small hoop manually from the menu.
Aug 26, 2008 | Singer CE-100 Futura Computerized Sewing...
Husqvarna Des 1.. won't recognize hoops
The embroidery unit needs to be calibrated. Can only been done by a trained dealer. you can relax, it is not a major issue and shuold not cost you a arm and a leg. Ask the dealer to also calibrate your touch screen and download the working hours on your machine.
Regards
dupina
Dec 11, 2007 | Husqvarna Designer I
Nintendo Wii Fit for Wii Logo
55 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
