Question about Toshiba Satellite A25-S207 Notebook
My Toshiba satellite A25-s207 laptop will not boot up
It shows the windows logo and then goes black. can someone tell me what's wrong.
    Master:
  • 474 Answers
Does it restart and then ask to go into windows safe mode, things like that. If so here something to try.
I can help, Leave everything to me!!!!
Im asuming its doing what is called, " The windows boot loop" or as well call it at work anyways.
Dels are known for this.
let me guess, it starts up normally, gets to the windows startup but asks you to pick between 4 different start up options like safe mode.
Do you have your original CD that came with it, or at least a windows XP CD?
You will need one.
What you do is,
1st: Bot from CD. Start the machine with the Winxp CD in the drive, hit F12 for boot options, or whatever key function it is. Do this as soon as you turn it on,
2: select " Boot from CD" and press any key when it askes if you want to boot from CD.
3: It will load like your doing a fresh install of windows. Thats alright, its normal and no it wont re-install windows at this point.
4: Once it loads, it will have some options. Pres " R" for repair.
It will go out and to the command prompt after about 5 seconds.
5: once at the command prompt, type in exactly ( CHKDSK C: /P ) Dont include the ( ) . Then press "Enter key "
6: after it runs the disk check, normally about 3 to 5 minutes, It will finishand go back to C:/
Just type ( EXIT ), Enter key, and let it reboot.
you can remove the disk now or later, shouldnt matter, It will go to the options screen like before, but just let it default to the normal startup, or hit enter.
Windows should now load fine and you shouldnt get that message at startup anymore.
WHY THIS HAPPENED?, you may be asking.
For some reason, certain Dell Hardware and software conflict, usually when you have installed some new program, or for just no reason.
Your Boot Up files get corrupt or cleared and windows needs those to start.
What you did was re-installed those windows files.
Now copy and paste into a word document and print it out in case it happens again. Not likley but it could.
This works with any computer experienceing this issue, usually, unless there is something worse going on.
You can help other now that you know how and become a hero, make sure to charge them $10 though for your time:)
Let me know if this doesnt work and we can try something else.
Good Luck.
Posted on Feb 04, 2009
I WANT MY DRIVERS FOR LAPTOP TOSHIBA SATALITE SA10-S203 PLZ
You can download any orall the Windows device drivers for your model laptop from the Toshiba WEB sitefrom their download page. Make sure you enter the model of your laptop so youcan get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
Apr 17, 2011 | Toshiba Satellite A25-S207 Notebook
My toshiba satellite a25 s207 trys to power on but wont
Hello sir, the reasons why your power supply wont turn on;
  1. It detected an overload, it is called a switching power supply, if it detects shorts, or something wrong on the mainboard it will not start.
  2. It cannot supply the right amount of current, the power supply is defective.
I had that symptom on my compaq armada, I dissassemble it part by part, then slowly reassemble it, piece by piece making sure all contacts are good and clean. As i power on the unit it turns on without a problem. to do this you should know a little thing about laptops/PCs. hope this helps
Aug 06, 2009 | Computers & Internet
A problem with the cooling system is detected. Satellite A25-S207
The sensor that reports the cpu temperature could be faulty or could be fan loose from cpu or faulty motherboard .
Aug 02, 2009 | Toshiba Satellite A25-S207 Notebook
Wireless connection
on the left side is an on and off button,is it on. what is the name of your router and adapter if is used.
Oct 25, 2008 | Toshiba Satellite A25-S207 Notebook
Your laptop?
it would be easy...i think you can do that alone..if file missing only...try to repair your windows....first, what operating sytem do you have? XP or vista?....i hope you have the oroginal cd for that...if you have,then no problem.....lets start....
1.go in bios setup..change the setting into the CDrom boot.
2.insert the OS disk and save the setting in the bios and amke restart.
3.you can boot now into the OS cd and press any key to continue..and you will install now the windows....
Oct 19, 2008 | Toshiba Satellite A25-S207 Notebook
Slow
Getting 330 error. In order to fix that, you can run this command at dos prompt > SFC /SCANNOW
It can fix errors at windows XP. Normally there are two memory slots for toshiba satellite. You might be running at 512 or two 256. You can purchase two 512 or i 1g.
Oct 07, 2008 | Toshiba Satellite A25-S207 Notebook
Notebook did not go in BIOS setup
It depends on the brand of your BIOS. Try these two steps, Press F2 upon boot up or press ESC and F1 upon boot up.
Oct 05, 2008 | Toshiba Satellite A25-S207 Notebook
Unable to boot
pls give the following detail
model of notebook
is not able to boot into any of the mode??
May 19, 2008 | Toshiba Satellite A25-S207 Notebook
Toshiba Satellite A25-S207 Notebook Logo
240 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
