Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Mitsubishi WS55513 480i Signal no Color
I have an issue where only my 480i signals look horrible. There is virtually no color, looks almost black and white and there are light bands running vertically all across the screen. My 1080i signals look great! The TV is about 5 years old and I never had it re-calibrated, so I am wondering if that's all it needs? I had the blinking green light of death about 6 months ago and I repaired that by replacing the Caps, but I don't think this is related? Any ideas???
  • 2 more comments
  • Anonymous Feb 05, 2009
    I am connected to a Comcast HD Cable box through a Component Connection
  • Jim Williams Feb 05, 2009
  • Jim Williams Feb 06, 2009
    That fixed it! Although pressing Menu on the box didn't work, I had to press menu on the remote and changed the setting to 480p and SD channels now look good again. I had this problem for 4 or 5 months now, I wish I would have posted something sooner.....Thank you very much for your input!!!
  • What are your signals coming from and how are they connected to the TV?
  • 139 Answers
That may be a TV problem but can also be a Cable box problem.Do you have any other 480i signals hooked to the TV?
Also most Comcast HD boxes can be set to output SD signals at 480p which may solve the problem. Usually get to the setting by turning the cable box off and pressing menu on the box, not remote.
It should display a different menu on the tv screen, arrow down to 4X3 overide then arrow right and try 480p.
Posted on Feb 06, 2009
All televisions in home lost color at same time
Check your country supports which signals NTSE, PAL and try to put the same in your TV.
Aug 16, 2014 | Directv Televison & Video
The color on my Mitsubishi WD 65734 rear projection tv just went out. I did not hear anything. I just turned it on and had no color.
With the Mitsubishi remote: have set on and hit Menu, 1,2,3 enter to do a soft reset of the unit.
I would also suggest you check all connections if you are using a box for signal and look to see if have color from DVD or blue ray etc.
Let me know what you find with a comment here before you rate this solution.
SD TECH
Jun 18, 2011 | Mitsubishi Televison & Video
I have no color on my Samsung Flatscreen TV
This means absolutely no color - equivalent to a black and white picture. Not even a hint of color.
First, confirm that the source is actually in color - try another channel or input device.
Next, check the settings of the color control - it may have accidentally been turned down. If your TV has some kind of automatic picture mode, try turning if off and adjusting the color control. Try adjusting fine tuning if you have such a control and the problem is with a broadcast or cable transmission.
At this point with a confirmed color signal source, there is a problem with the chroma circuitry.
Note that to the average person, the obvious question becomes: is my color picture tube bad? The answer is a definitive NO. It is virtually impossible for a defective CRT to cause a total loss of color. A defective CRT can cause a lack of a primary color - R, G, or, B or a short between two colors which will mess up the color but is not likely to result in a black and white picture.
Some possibilities in no particular order:
Weak signal or defect in tuner/IF causing loss of signal strength.
Coler killer set too high (internal control) if it has one.
Defective part around the chroma chip/circuit. Faulty color oscillator.
Bad connections in area of chroma chip/circuit.
Defective chroma chip (don't suspect this first just because it is probably very expensive).
Try prodding the main board around the chroma chip with an insulated tool to see if you can make the color come and go.
I had one set where a $.02 resistor decided to open up causing just this problem - perfect BW picture, no color. Another had a coil with a broken wire.
Jun 14, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
During a storm, electricity went off and when electricity came on again I lost the color on my tv
I had one set where a .02 resistor decided to open up causing just this problem - perfect BW picture, no color. Another had a coil with a broken wire.
May 26, 2010 | Televison & Video
Mitsubishi WS65807
The Color Signal on this Model Series travels across three boards before being sent to the CRTs. The 3DYC Board, Signal Board and the Terminal Board. Most likely, the 3DYC Board or the Signal Board is causing the problem. I have had intermittent solder connections on the 3DYC Board to cause no color problems. This Board plugs in and is located on the left front of the Signal Board as you look from the rear of the chassis. If you feel you are not up to the task to work on the set, call a Mitsubishi professional. To find one, call Mitsubishi at 1800-332-2119.
I hope this helps,
Skyassoc
Jul 24, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Picture is now black and white
 transmission.
  1. Weak signal or defect in tuner/IF causing loss of signal strength.
  2. Coler killer set too high (internal control) if it has one.
  3. Defective part around the chroma chip/circuit. Faulty color oscillator.
  4. Bad connections in area of chroma chip/circuit.
  5. Defective chroma chip (don't suspect this first just because it is probably very expensive).
A service manual or Sams', DMM, and scope will help greatly in attempting to troubleshoot this unless it is an obvious bad connection. Try prodding the main board around the chroma chip with an insulated tool to see if you can make the color come and go.
May 08, 2009 | JVC AV-36S33 36" TV
No Color on Zenith SG5257S
Hello Nexium7,
The best place to get a schematic would be from the manufacture Zenith, However you can try www.servicemanuals.net The cost for the schematic is $23.99.
I would suggest you start by using a color bar generator to send a known good signal in to the RF connector on your tV then go to the output of the video detector to look at the video signal, what you should find will be on the schematic, which should be the video signal with color burst if the color burst is not present or low in amplitude this is your problem and the trouble is happening before the video stages. If the burst is ok the you will have to test along the video path until you get to the point that the burst signal is no longer present, and then you will know the stage which the problem is occurring.
In any event you will need a schematic, multimeter, oscilloscope, and signal generator (color bar and raster purity)
Thank you,
Shuttle83
Nov 26, 2007 | Televison & Video
Tv lost color
Your problem most likely is on the signal board is my guess. If your not a technician it would be in your best interest to have him check L2C60 on the signal board.
Nov 19, 2007 | Mitsubishi VS-60707 60" Rear Projection...
No color
Call a service man and have him check L2C60 on the signal board. He will know what I'm referring to.
Oct 16, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Foot note to issue
If the source to the PIP input is a color signal then the PIP display will be color. PIP sets have two video sources one goes to the main screen while the other goes to the PIP. it all depends on what the format of the signal is being sent to each input. This is quite normal.
Jun 29, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
203 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
