It is the fuse. The fuse is located beside the heating element. It has 2 white wires and is about the size of a dime. The kit comes with 2 fuses and a high limit.Since the fuse is tied into the door switch, it kills the dryer if their is a fat nasty lint ball or a broken blower wheel, both of which cause a nasty heat blockage and could burn down the wigwam, not good. You change em fuse Kimosabe.
my maytag dryer wont start and the drum light doesnt work anymore. what is the problem? dryer is...
(More)
my maytag dryer wont start and the drum light doesnt work anymore. what is the problem? dryer is only 2 years old
Hi! I have a Maytag HYE3658AY and it shut off in the middle of a load of laundry with no warning. We...
(More)
Hi! I have a Maytag HYE3658AY and it shut off in the middle of a load of laundry with no warning. We tried the breaker box, and even made sure that the appliance was properly plugged in. The inside light is not coming on when we open the door, so it is evently something with the electrical wiring. What could I do to troubleshoot the dryer? I'm a working student and would rather not spend too much money on a professional - please help! and it shut off in the middle of a load of laundry with no warning. We tried the breaker box, and even made sure that the appliance was properly plugged in. The inside light is not coming on when we open the door, so it is evently something with the electrical wiring. What could I do to troubleshoot the dryer? I'm a working student and would rather not spend too much money on a professional - please help!
I replaced the element to find that it was not bad , so I replaced the thermostat on the element...
(More)
I replaced the element to find that it was not bad , so I replaced the thermostat on the element connection. I still dont get any heat. I looked at the thermal fuse and it appears to be ok , black across and not melted so I assume it's working because dryer turns but doesnt heat. Could you help me?
My dryer is not working, when i tryied to turn it on. I got it zapped me. I looked for burnt wires...
(More)
My dryer is not working, when i tryied to turn it on. I got it zapped me. I looked for burnt wires but could not find any. If I need to replace the main switch where do i find it.
