Question about Danby DDW497W 22 in. Countertop Dishwasher
Plexi glass on the inside of danby dishwasher is broken
Where can i order another
    Problem Solver:
  • 10 Answers
Try calling the number below - we managed to get parts for our portable dishwasher (after a considerable wait). Dan by Products Inc. 1-800-263-2629 Ext. 212 1-419-425-8627 Fax: 1-419-425-1244
Posted on Jun 16, 2009
  • M Thompson Mar 20, 2012
    March 20, 2012: The number above is Customer Service. The redirected me to 1-800-496-6049 for the Danby Parts; click 1 for USA and 2 for Canada. Very fast response time, courteous service.
    I phoned the number above and was redirected to 1-800-496-6049 and was served very quickly and courteously. Choice to click 1 for USA, 2 for Canada.
    Excellent service. Done within 10 minutes!
Water doesn't drain out of bottom.
Broken glass is caught in the pump. a take apart cleaning of the pump and drain hose is in order.
Mar 13, 2010 | Maytag MDB9600A Jetclean II Built-in...
I have a Mitsubishi WS-A48 TV. The plexi-glass
not personally order them no, mitsubishi will not let private parties order servisable parts, so u will need to order it through a service man, then, take of the back part side part etc... can be done, but before u get to it u will feel like u own a hardware store with all the screws they put in. be carefull not to touch the mirror!!!
Mar 04, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Broken plexi glass on the inside of machine
Another thing that has worked acceptably well for me in this case is 'gluing' the plastic window back into place with a generous layer of GE Silicone II Kitchen and Bath sealant.
it works on both metal and plastic.
make sure the surfaces are all completely dry and apply a layer around the rectangle area where the plastic would normally meet the stainless steel (remove any plastic bits from the holes so that the sealant can squeeze in a little), place the plastic window back into position and put some weight over the entire surface of the window....not too much, but enough so that it'll squeeze the sealant out to the edges and seal entirely around.
let 'cure' 24 hours
mine has held together over a month now and doesn't appear to be coming apart (although i think i could've used a bit more sealant)
Feb 04, 2009 | Danby DDW497W 22 in. Countertop Dishwasher
Need plexi-glass cover off my mitsubishi hd 1080 projection tv.
the plastic trim pops off and there are screws that hold the glass in place that you have to take out to be able to remove the plexi. it takes about 20 minutes to do
Jan 27, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Danby counter top dishwasher
CLR should do the trick, read instructions on back of the bottle. Also there are some dishwasher cleaners that you buy.
I bought one at Safeway. Small bottle, has a picture of a dishwasher on it. It has a wax seal that melts when you run it on the hottest cycle upside down. It cleans the inside of the dishwasher.
Of course this is assuming that its build up.
May 31, 2008 | Danby DDW496W Free-Standing Dishwasher
How do I remove the outer protective screen on my Mitsubishi WS-55315?
There are trim pieces around the edges that can be removed by sliding a knife underneath and lightly prying. They should remove fairly easily, don't force them as they may break. Use the knife on the cabinet side and pry toward the center of the screen.
The tear on the inner screen may be best left as is.
lexan would be better than plexi as it is tougher, but try to get anti-glare if possible. Anti-glare plexi would be better than regular lexan.
Feb 17, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Danby dishwasher
Call Marcone Supplies, Tampa Florida. (they are Danbys Supplier for parts.) DO NOT WASTE YOUR TYIME CALLING DANBY. They are not helpful. Danby 18" Dishwasher. Model # DDW 180 2W Parts 800-482-6022. Marcone:Very helpful. My door is open; thank goodness; it just will not stay closed. Latch broken on door. I have to order the "whole handle assembly" (all one piece which includes the door handle latch too.) $4.16 shipping from PA. I am in Calif. Total $12.53. 2 screws. Easy. I can do it, I know I can. (Signed, a woman in LA!)
Jan 22, 2008 | Danby 17 in. DDW1802W Designer Series...
I have a Danby DDW399 W countertop dishwasher
I have a Danby DDW399W countertop dishwasher. I need a replacement tap attachment and haven't been able to locate one. Email buddysmom@telus.net
Jan 14, 2008 | Danby 22 in. DDW396 Free-standing...
Panasonic HDTV 1080i Screen
Usualy Panasonic have 3 layers on the screen. From inside to outside is: fresnel, lenticular and protective. If only the one from outside is broken don't wory. It;s just protective and the film it's just a filter to improve the black level. You can use it like that but be carrefull because the lenticular it's not protected anymore and if you scrach it ... And do not try to clean it with anything else just dry rag.
Dec 10, 2007 | Draper Replacement Surface ONLY for...
Danby DDW497W 22 in. Countertop Dishwasher Logo
238 people viewed this question
Top Danby Dishwashers Experts
Oloyede Monsuru
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
