Question about Honeywell Programmable Thermostat Heater
Rth230b honeywell display screen faint
The display is very faint and everything is shown, all the icons, just faint. I cannot program it, heat is on, can't set the time it won't work, makes a fast buzzing clicking noise. Happened after I touched it with a static electrical shock, which happens all the time in this house. What should I do? Would getting a new one solve this problem? I already tried replacing batteries many times.
  • mcrutkowski Feb 06, 2009
    I walked across the room and shocked my TH104 Economizer by Cosmo thermostat and then it wouldn't work after that. I tried re-setting it, and it still won't allow me to program it. I also tried replacing the bateries and still nothing. The screen either displays everything in 8's or 0's, but I can't get it to allow me to change the temperature. I'm assuming I have to get a new thermostat based on your comment to the previous person?
  • 31 Answers
Mike, The static electrical spark probably 'zapped' the Rth230b Honeywell Display unit. If you have already tried removing the power (batteries) from the unit and after waiting several minutes; reapply the power (batteries). If the problems remain unchanged, then it is time to replace the Display unit with a new one. The static electricity problem is problematic and the only way to prevent the same problem from recurring is to discharge yourself before touching the Honeywell Display. As you walk across the room which (probably has carpet), causes the static electricity to build up on your body and then discharges itself through the Display unit when you make contact with the Display unit. You might try coming to a complete stop and attempt to discharge the static charge on your body by touching the wall first with one hand for a second before touching the Display unit with the other hand. Naturally, cold weather with low humidity makes the static electricity worse. Hopes this helps you. Henry
Posted on Feb 05, 2009
    Problem Solver:
  • 14 Answers
I do not have the same thermostat but did need to turn my display off when sleeping downstairs near the thermostat. So, I called my utility company that installed the Honeywell Utility Pro Series Thermostat and here is how to do it. It was not in the Honeywell User Manual located at:
http://www.bgesmartenergy.com/media/pr/thermostat-operation-manual.pdf
  1. Press System – it will blink
  2. Press & Hold Square 3 + 5 at the same time
  3. 120 change with up arrow to 280
  4. 0 = OFF and 1 = ON
  5. Hit Done button
That is it for mine! Hope this helps.
Posted on Nov 20, 2009
I've clicked on Abode settings on my screen which I don't want how do I undo this please
What settings changed on your screen? The icons got bigger or smaller? If so Click Start/Control Panel and look for Display or Appearance and Personalization. Open the display and click the Settings Tab to change the Resolution. The higher the resolution, the smaller the icons. The lower the resolution, the larger the icons.
If that is not what you are looking for you can always run System Restore to go to a Restore Point (date and Time) before you made the Adobe change. System Restore does not delete your data.
In Windows XP and Vista click Start/Programs/Accessories/System Tools/System Restore and select a restore point that was before you started having problems. There should be an option to see more restore points than the one that is shown.
In Windows 7 Click Start then in the search box type System Restore.
Again, System Restore does not delete your data, documents, music, pictures, videos or programs (unless the program was installed after the restore point you selected).
System Recovery on the other hand deletes everything and sets your system back to when you first purchased it.
May 05, 2012 | Dell Inspiron 1525 Laptop
How do i set the date?
Program the Date & Time and Print Method using the 3 buttons: Mode, Select, Setting:
Date & Time: Press the Mode button. The Hour will start blinking. Press the Setting button
until the correct hour is displayed. Press Select to set the hour shown.
The Minutes will blink. Press Setting until the correct minutes are displayed. Press Select
to set the minutes shown.
The Seconds will blink. To set the seconds at 00, press the Setting button. Press Select.
The Year will blink. Press the Setting button until the desired year is shown. Press Select
to set the year shown.
The Month will blink. Press Setting until the correct month is shown. Press Select to set
the month shown.
The Day blinks. Press Setting until the correct day is shown. Press Select to set the day
shown.
Print Method: Press the Mode button until P5 (Program Mode 5 for Print Format) is displayed.
Press Setting to choose one of the following Print Methods.
The TC100 has two settings for print activation: Manual or Automatic
1 = Automatic (default setting) - The TC100 automatically prints when the time
card is inserted.
2 = Manual - After inserting the time card, press the Print Button to activate
printing.
Press Select to confirm the Print Method chosen. Press Mode to return to normal operational. hope this Help : - )
Dec 11, 2011 | The Times ROYAL TC100 TimeMaster Time...
I need a manual for the royal tc 100 time clock
the month shown.
shown.
card is inserted.
printing.
Press Select to confirm the Print Method chosen. Press Mode to return to normal operational. hope this work for you best regards happy holidays : - )
Nov 08, 2011 | The Times ROYAL TC100 TimeMaster Time...
Hi, I set the year to 11, month and then day, but when printing out, it shows the year is 10. Please help.
the month shown.
shown.
card is inserted.
printing.
Jun 09, 2011 | The Times ROYAL TC100 TimeMaster Time...
How to set the date
1. Open the front cover to show the programming buttons:
Program the Date & Time and Print Method using the 3 buttons: Mode, Select, Setting: Date & Time: Press the Mode button. The Hour will start blinking. Press the Setting button until the correct hour is displayed. Press Select to set the hour shown. The Minutes will blink. Press Setting until the correct minutes are displayed. Press Select to set the minutes shown. The Seconds will blink. To set the seconds at 00, press the Setting button. Press Select. The Year will blink. Press the Setting button until the desired year is shown. Press Select to set the year shown. The Month will blink. Press Setting until the correct month is shown. Press Select to set the month shown. The Day blinks. Press Setting until the correct day is shown. Press Select to set the day shown
If you need additional instructions the manual can be found here: TC100 Manual
Hope this helps, Myridom
Mar 04, 2011 | The Times ROYAL TC100 TimeMaster Time...
How to change the date
the month shown.
shown.
card is inserted.
printing.
Dec 20, 2010 | The Times ROYAL TC100 TimeMaster Time...
How do I change the date and time on my Meridian Business Set M5316?
To Change the Date and Time:
  1. Press
  2. Press the volume key until "Time and Date Set?" is shown on the display
  3. Press
  4. Enter the date using the format shown on the display (DDMMYY)
  5. Enter the current time based on the 24-hour clock
  6. Press to save the new time and date settings
  7. Press or to exit the programming mode
To Change the Display Fomat:
  1. Press
  2. Press the volume key until "Time and Date Format?" is shown on the display
  3. Press
  4. Press the volume key until the desired format is shown on the display
  5. Press to save the new setting
  6. Press or to exit the programming mode
Nov 16, 2010 | Cell Phones
Very faint sound on everything, including system sounds. when playing a cd, can hear music, but not lead vocals except faintly. are the speakers shot? Everything was okay yesterday, and no settings have...
First of all, if you have volume controls on the keyboard, please make sure you turn the volume up from that location.
Next, locate the Speaker icon next to the time in the lower right corner of the screen. Double or single Click on that and make sure the volume slide bar is all the way to the top. If you don't have a speaker icon, roll over these icons slowly and an info bubble will pop up. Look for one that involves audio. If you right click on the icon, you may be able to select volume mixer or something similar, there you will find multiple volume settings, turn all up.
Finally, if you are having this problem when using a media player (Windows Media Player, VLC, Quicktime, etc), there will be a separate volume control within the player itself. They are usually a slide bar underneath the video or graphics display. Turn this up also.
Please note that if you are using a laptop, Laptop speakers are notoriously of poorer quality and lack the wattage of desktop speakers. In turn, it may not be a problem with your laptop2_bing.gif. You may need to look into purchasing an inexpensive set of external speakers.
Feb 26, 2010 | Logitech Audio Players & Recorders
Will not print date 11-19 sample
the month shown.
shown.
card is inserted.
printing.
Nov 19, 2009 | The Times ROYAL TC100 TimeMaster Time...
Display has very light illumination and does not display temperature or other settings. All functions seem to work but functions are not shown on display including temperature, Bake/Broil cycle, etc. Time...
This is a failure in the electronic range (or oven control) ERC or EOC. You can replace it with a new one, or have it repaired.
- www.fixyourboard.com
Jul 26, 2009 | Ovens
Heating & Cooling Logo
1,385 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
