Question about Kenmore 62602 Electric Dryer
Dryer runs and heats but turns off after around 8 to 10 minutes. When the button is oushed again it runs and heats and so on......etc
  • Kenmore Master
  • 8,220 Answers
Probably a bad motor Read this
Posted on Feb 05, 2009
How can I get my dryer to heat up again? Its a model # 417.88042700
Whirlpool Dryer Not Heating ' U-FIX-IT ' Troubleshooting
www.ufixit.com > Repair Tips
The heating element in my dryer heats up and the. Turns off with 2 minutes. ...... I have to let it sit for 2-3 hours for it to heat again and even this is not consistent.
Dryer problems: How to fix a dryer that's not heating up ...
? 3:03
https://www.youtube.com/watch?v=aFXbYp--K5g
Jun 4, 2010 - Uploaded by eSpares
Dryer problems: How to fix a dryer that's not heating up ... went to look for a video to fix my dryer... and as ...
How To Troubleshoot A Dryer That Won't Heat ' PartSelect ...
? 4:23
https://www.youtube.com/watch?v=ahb5pt52drE
Oct 6, 2011 - Uploaded by PartSelect
In this how to video you'll learn why your dryer might not beheating properly. Remember ... Up next ...
How to clean your clothes dryer. How to make it hot again ...
? 8:36
https://www.youtube.com/watch?v=MMP7BW1lLs4
Jan 26, 2010 - Uploaded by askmediy
Also visit my site for more detail and please ask your quest... ... How to Fix YOUR gas Dryer that is not heating ...
Jan 04, 2016 | Dryers
I have a Maytag Neptune model number MDG9700A gas dryer...When I first turn the dryer on the dryer will get hot for about minute then the gas turns off and will not heat up again...It glows fine after...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 01, 2011 | Maytag Neptune MDG9700A Gas Dryer
My dryer a Whirlpool. will run for about 10 to 20 minutes, then cuts off. After about 10 to 20 minutes, I can start the dryer again (push start button) and it will run for another 10-20 minutes. ....This...
there is a hi and a low tempreture sensor best to check those for continuity first when the dryer heats up and gets to hot the hi will turn off the heater where as when the low gets to cool it will turn it back on
hope this helps
Apr 30, 2010 | Whirlpool LER4634J Electric Dryer
No heat in the dryer! The dryer runs and air has free flow to the exit vent but still not heat being generated
check on rear of dryer, as many have a small reset button for heater.If this is fitted then gently oush it inwards and this should solve the problem
Mar 08, 2010 | Dryers
I have a kenmore series 80 electric dryer. It will will run for around a minute and then cut off. seems to be over heating. when I turn the heat setting down to the lowest setting it will run longer. If I...
that sounds like the dryer motor going bad,most of the time they run alittle then stop,or when you push the start button it just buzzes-mike
Mar 02, 2010 | Kenmore Dryers
Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Jun 21, 2009 | Dryers
Doesn't run for the full amount of time.
You need a motor should cost around 150.00 to 200.00
May 28, 2009 | Dryers
Kenmore dryer. 80 series. 6 years old.
There is no reset button on these thermofuses unfortunatly. Sometimes you can have a timer go out and cause a fault in the thermostats, thermofuses, etc. Doesnt happen to often, but it does happen. Be sure before you spend a lot of money, that you thoughly clean and check you dryer vent tubes or pipe. A clogged vent tube will normally cause major league problems (i.e. burned thermofuses, busted elements, out-of-temp thermostats, slow or no drying conditions, etc.). You can replace these yourself pretty easy if you have some hand tools (call Sears to fix and you can buy a new one) and a couple of minutes. Let me know if you want further instructions or help. Good Luck!!!! JIm
Dec 29, 2007 | Dryers
Dryer runs for 5 minutes then stops
look in the vent line for a small disk shaped overload with two wires coming out of it. it may be bad. also check for a lint build-up in the exhaust line out of the blower. check the damper outlet going out of the house for a build-up of lint.
Aug 21, 2007 | Roper REX3614KW Electric Dryer
Kenmore 62602 Electric Dryer Logo
46 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
