Question about HP iPAQ H2200 Pocket PC
IPAQ hx 2110
I put the charger in and the pda works perectly, no problems. however it doesnt charge the battery. you go into the power option, it says 'main battery:unknown o%' 'back up battery: ni mh 100%'
when i take out the power cable it all shuts down and will not start back up until i plug the power cable back in. i then have to go through the setup.
what is wrong with this?
I have a relatively similiar problem.I recently was given an HP ipaq h2200 as a gift, barely used... It had sat in a box for months, wrapped carefully and packaged. After I recieved it, I plugged it into a regular plug in charger cable... And to no avail will it charge. I can power on the unit while it is plugged in, but as soon as the power cable  is removed, the unit shuts off immediatly.  I thought maybe that my power cable was bad, so I took the cradle that came with the unit, and plugged that in to the wall, and sat the unit on top of it. The unit again powers on, but has the same problem. As soon as I removed the power source or the unit, it shuts off.  Any ideas?
  • natashanevin Feb 08, 2009
    I have a hp iPAQ 2200 which seem to work fine when plugged into the (power) cradle, however once I removed from the cradle it shuts down and loses all entries. Once powered up again (via the cradle) it goes back to it's default settings and i have to reconfigure it all over again.
You may need to purchase a new internal battery
Posted on Feb 08, 2009
The PC is not switching on
Without know exactly what already you tried to powered it on, I can only especulate on all the possible reasons, so let go one by one throuh them and their possible solutions:
1. The RX3000 Ipaq family has a known mechanical issue on the switch that senses when the back cover lid is properly closed.
When the switch is nor properly depressed, the PDA won't charge the battery if plugged on the cradle or to the USB sync cable, or won't turn on.
Remove the back cover lid and the battery, put them back again. Check the cover lid is placed flush and that there is not any gap between the cover and the PDA body.
Try again in power it on and/or charge the battery, confirming the orange LED light is turning on.
2. Either the cradle/USB sync cable or the AC wall adapter are defective.
The PDA won't power on if the battery is not charged to the minimum voltage for it. If the AC wall adapter or the cable/Cradle are defective, won't power on.
Put to charge the battery and confirm the orange LED light is turning on. If so, the you can discard that the cradle/USB cable or AC wall adapter are defective.
It the orange LED light won't turn on, it may be either one of these three parts that are defective, or that the back cover lid is not properly closed.
3. The battery dried out. If the battery is defective or won't accept charge, the pda won't power on.
To discard a defective battery, put the PDA to charge it, and it will power on when plugged to the USB cable or to the charger, and check in the settings screen, on the power icon, if the battery is charging.
If the back cover lid is properly placed, and the PDA won't power on when plugged to the USB cable or AC wall adapter, then the battery is not the problem.
4. Discarding that the battery or the USB cable or cradle or the back cover lid are the problem for this problem, the only option that is left is that the main board is defective.
Such failure on the mainboard could be caused for several reasons (moisture or humidity or water damage, or a electronic component that is worn out, or a integrated circuit that is shorted, etc) but it can be only verified and confirmed by an electronics technician.
You have the option of send it to be repaired, or try it yourself, which will require to buy a PDA with working mainboard (or the mainboard alone) and swap the parts. It requires a minimum of technical skills to do it.
Best regards,
Feb 02, 2009 | HP iPAQ RX3715 Pocket PC
Hp ipaq seems dead
Best regards,
Dec 10, 2008 | HP iPAQ RX3715 Pocket PC
Won't turn on
Best regards,
Oct 27, 2008 | HP iPAQ RX3715 Pocket PC
Dead!
Best regards,
Apr 22, 2008 | HP iPAQ RX3715 Pocket PC
Ipaq H3835 PDA - won't hold charge??
If you purchase a new battery, they usually come with directions and special tools to change the battery. I had the same issue with 2 of mine when I got them at a used electronics store. IF it is the battery that is not working, then replacing it is easy, and you can get a replacement at your local Battery-Plus store.
In my case, one was fixed by a new battery, the other was not, and I actually had to press pretty hard in the cradle to get the second one to work. It never worked out of the cradle, so I gave that one to a neighbor kid to tear apart and see if he could get it working. (I got them for $15, so no big loss.)
Apr 21, 2008 | HP iPAQ H3835 Pocket PC
Battery won't charge after being replaced
The charger might be bad. Or then the pdas connector is bad, or the motherboard is damaged.
to find out is your charger working you could use a tester to test it or another pda.
If you could get some power into the pda you could use the bootloader to test the device. Its been years since I had my 3850.
Il have to find instructions on how to get to the bootloader but test the other things first.
Drop a comment.
Mar 11, 2008 | HP iPAQ H3835 Pocket PC
IPAQ hx 2110
does it matter if usb charging is enabled? just looked through the menus and it has a slow/fast charge option etc?
Dec 22, 2007 | HP iPAQ HX2110 Pocket PC
My H5450 won't charge!
When you charge up your iPaq, do you use the cradle, or do you use the AC-adapter with the little iPaq power converter that came with the iPaq? Try both, and see if it charges up your pda. Try and borrow an iPaq car-charger and see if it charges up that way (the ones that do not need the iPaq power converter). If you are lucky enough to power up the iPaq even for 2 minutes, enable USB fast charging in the SETTING -> BATTERY. Your USB-data-cable or cradle will then be able to charge it up that way...
Sep 08, 2005 | HP iPAQ H5450 Pocket PC
HP iPAQ H2200 Pocket PC Logo
171 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
