Question about POS X BIXOLON Samsung Kps SRP350 Thermal Receipt Serial Drk Gray Ac Printer
How do I print a bmp file to the SR 350 Samsung Thermal Printer? I am trying to print a logo. I need the commands and perhaps an example. Thanks, Abe
2 Suggested Answers
SOURCE: i have bixolon srp 350
hello, im trying to send a print to my BIXOLON SRP350 Thermal printer by java codes. but java can't use the all the page width, what should i do to use all of the page width ?
Posted on Apr 01, 2011
I have bixolon srp 350 for my restarant when i give print command from register it always comes in queue with showing error. i done all softaware re installation and self test for printer everything works...
Feb 20, 2011 | POS X BIXOLON Samsung Kps SRP350 Thermal...
How can I upload the logolab.bmp from linux to the datamax I-4208 printer?
Assuming you want to print the file use the command "lpr" This is the only protocol used by this printer anyway.
If you have root access to the printer you can use "lp" but otherwise use "lpr"
command line usage:
"$ lpr logolab.bmp" please let me know if this helped or if I can clarify more.Joe
Feb 17, 2011 | Datamax I-4208 Thermal Label Printer
I have developed an ms access POS. When i print receipt to samung thermal printer srp 350 ver 2, it prints very slow. i have tried several drivers but i end up with the same slow printing problem. I am...
itecghana, printing slow is probably an issue of the interface type (serial, parallel, usb, ethernet...) and not the printer itself. The Bixolon 350 has a self test printout capability (turn on printer while holding down the feed button) which'll demonstrate the print speed capability of the printer.
My guess is you have a serial interface (COM port), serial is notoriously slow when printing via any windows driver.
If the printer you have is a 350, one solution is to change the interface card on the printer from Serial to USB. The part number of the USB interface card is IFA-U Type, can buy one for about 35 bucks online.
Jan 10, 2011 | Samsung SRP 350 Thermal Printer
PROBLEMS PRINTING
Hi Anabel,
I've heard of this kinds of issue in cases where an adaptor cable (usb-serial, usb-parallel) causes this. But if this isnt you perhaps you can try reloading the printer's newest driver.
Jan 21, 2009 | Samsung SRP 350 Thermal Printer
TO Print the image using IPL.
I've printed images over 500kb. Can you print a small image? If not, perhaps the driver is the problem.
If you're trying to send a text file of IPL commands to the printer, set up a Generic Text printer driver, to to send the file as ascii characters instead of as a graphic image. You can set this up in addition to your Intermec driver.
Go to Printers and Faxes, Add Printer, Next, Select the Port, Select "Generic" Manufacturer, "Generic / Text Only" Printer, and give it a name like "Text". Cycle the printer power to clear previous attempts, then print the file to this printer name.
Aug 22, 2008 | Intermec EasyCoder 3400 Thermal Label...
Print Graphic by coding program to Zebra printer
no u cant use jpeg... u can use .bmp "Monochrome Bitmap (*.bmp,*.dlib)"
Aug 15, 2008 | Zebra Z4M Printer
IBM 4610 TG4 Printer configurations from windows
Hi
you onli need send commands by excel is ASCII CODE its easy
Apr 10, 2008 | IBM 4610 TG4 Thermal Label Printer
SRP-350 barcode CODE 128 C printing problem
I have a samsung printer srp-350pg, it is printing garbiches, I download a driver does the samething, used generic driver but nothing changed
Please help
Mar 28, 2007 | Samsung SRP 350 Thermal Printer
POS X BIXOLON Samsung Kps SRP350 Thermal Receipt Serial Drk Gray Ac Printer Logo
501 people viewed this question
Top POS X Office Equipment & Supplies Experts
jasbo
jasbo
Are you a POS X Office Equipment and Supply Expert? Answer questions, earn points and help others
