Question about OKI B4600 Printer
OKI B4600 Printer will not print = error - paused
My new OKI B4600 Printer will not print. It shows that it is "paused". How do I "unpause it"? I can click on "resume print". "Resume print" will only be indicated on the screen for about 5 seconds & then it shows "paused" again. HELP !
  • Anonymous Mar 27, 2014
    toner too light
Yes
Posted on Apr 16, 2011
    Sergeant:
    Champion:
  • 373 Answers
Is there a menu thing on the screen somewhere
Posted on Feb 04, 2009
    Master:
  • 474 Answers
Does it have a control panel or buttons on the printer itself?
If so, are any of them blinking or red?
Sometimes an error will cause a pause in the printer and you have to press one of the buttons to get it to start back up again.
http://my.okidata.com/PP-B4600-Black.nsf?opendatabase
This is the link to the manuf. website. I did a search on your model, theres a few so i guessed. but the manuals are available along with drivers.
I suggest you go and update them and go through the PDF and see if there is anything partaining to this issue.
I went through the PDF a bit and didnt see anything partaining to the PAUSE issue but try going through and see if anything is it.
On the printer icon on the bottom right of your task bar, right click on the printer icon and see if you can select CANCEL print job, then try unpausing it. Also, power off and then power back on and see if that clears it.
You may have to un-install the printer and re-install it and update the drivers to clear it.
Sometimes a Print job will get stuck in que when theres a jam or something and it wont continue till the issue is resolved, then you open and close the top cover and that resets it, it rechecks then continues.
Good luck.
My B4600 only prints a single copy
You don't say which version of windows you are using. There is no windows 10 driver so you would be picking up a generic driver when plugging in via usb. If windows 7 or 8 then UNINSTALL (not delete) the Universal driver and install the US version 2.2.6. It wont be the printer as printers only print what they get. Its definitely a driver issue.
Mar 21, 2017 | OKI B4600 Printer
Okidata B4600 error message #132 on two printers. What does this error mean. The printers will not go to off line.
Error 132:
LED Head Missing, Color:Magenta
When magenta LED head connection cannot be detected
Solution:
You should first try to restart the printer.
If that doesn't resolve the problem, the ribbon cable is probably disconnected from the print head.
The led print heads are four assemblies that hang down from the lid of the machine when you open it. Make sure they are properly connected.
Sep 14, 2011 | OKI B4600 Printer
I have an Oki B4600. I recently replaced the drum & toner. The print is very light and part of the page is illegible.No error message is displayed. Please advise
The problem is most likely with your fuser and will need to be replaced. Contact Oki tech support and see if your printer is still under warranty, you will need to give them your printer's model number and serial number. Sometimes the cheapest solution is to replace the printer all together.
May 19, 2011 | OKI Electric Industry B4600 Laser Printer
What does it mean that printer is on "pause"
This means that print jobs sent to the printer will not print untill the printer is unpaused. This setting is used mainly for maintenance purposes.
To unpause a printer
1.) Left click Start in the bottom left hand corner of the screen
2.) Left click Control Panel
3.) Now, double-click "Devices and Printers" or "Printers and Faxes"
4.) In the Window you will see your printer, double-click your printer
5.) This screen will show you active print jobs, to pause or unpause the printer click File then click "Pause printing"
Hope this helps :)
May 15, 2011 | Epson Stylus C66 Inkjet Printer
Help with toner reset problem on OKI B4600. After refillig cartridge, on display apears "Tonner Empty - Replace cartridge"
Go to the maintenance part of the printers program and clean the heads is the job to perform. The run a test page for alignment. It will adjust back correctly showing you have ink
Feb 26, 2011 | OKI B4600 Printer
How do I set OKI B4600 to print to top tray?
On the back tray where the paper comes out just push the extra piece in that helps to catch the paper until it clicks and it will automatically start coming out the top so you pages are in the order that you want them to be.
Oct 07, 2009 | OKI B4600 Digital Mono Printer - Black
Oki B4600 ONLY prints to rear tray - how to print to front?
Yes. click on your printer icon. select properties then look for Tray or Output Tray or Tray settings and change it
Jul 08, 2009 | OKI B4600 Laser Printer
Printer shows paused what can i do to fix it
Unplug all the leads, wait 10 seconds, now only plug the power lead back in.
Turn back on, now if the paused message has gone, plug in the communication cable(s).
Jul 07, 2009 | OKI B4600 Printer
Oki b4600 drum reset ?
On the printer press the menu button until you reach MAINT.Then press the item + button until you reach DRUM CT RESET. Then press select.YOUR DONE!!!!!!!!
Jun 19, 2009 | OKI B4600 Printer
OKI B4600 Printer Logo
3,472 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
