Question about Zebra 170Xi II Thermal Printer
Zebra 170 xi labela are printing on top of each other
How do i recalibrate a zebra 170 xi printer?
  • 13 Answers
Don't forget to rate this.
You can download Zebra manulas from here. https://www.zebra.com/id/zebra/na/en/index/service_support.html here is a section of the calibration you require. Sorry it will not allow me to attach. i think issue with site usage.
Anyway press PAUSE to pause printer. Then find & press CALIBRATION, it will ask when you want to calibrate either at power up or after the print head is open & closed. I would select Power up since when you change lables out you should do so with printer off.
Good luck, post any questions to this & also rate it.
Posted on Feb 06, 2009
Zebra 170 xi manual
You can download one direct from Zebra at
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/xiiiiplus-ug-en.pdf
Mar 14, 2013 | Office Equipment & Supplies
Tip
How to calibrate the label & ribbon sensors on Zebra printers
One of the most common problems with Zebra Xi, XiII, XiIII, Xi4, and 105S,105Se, 105SL series of printers is sensing or proper advancement of the labels. The printer has two sensors, top and bottom, that must be properly aligned with each other. If you are not sure they are aligned correctly, see my other tip on how to align the media sensors.
The label passes between these two sensors. The idea is that the label blocks the light between the two sensors and the gap between each label does not block the light. So the labels advance based on light, no light, light, no light. Note that the red light you see in the “throat” of the printer when you raise the printhead is not the sensor being discussed here. That red light is a “reflective” or “mark” sensor and is used for a different purpose.
Sometimes the labels are on a backing (liner) that is almost as opaque as the label itself. If this happens, then not enough light passes through the liner when the gap passes under the sensor. The printer loses the ability to find top-of-form. We can recalibrate the printer sensors however to adjust to this new liner. My video at the link below will walk you through step-by-step on how to calibrate the sensitivity of the media sensor. The ribbon sensor is recalibrated at the same time. Once this is done, the printer should now easily advance from label to label. The procedure may have to be performed each time for different thicknesses of liners or backing.
Video tip:
on May 05, 2010 | Zebra 105SL Thermal Label Printer
My zebra only prints the half top
Try recalibrating by holding down the button on powerup. When the label starts to move let go. After it prints the diag page hit the button once to take it out of "dump mode"
Dec 06, 2011 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2844 label gaps
you can try contacting zebra. im not familiar with that model.
Aug 25, 2017 | Zebra TLP 2844 Label Printer
How can I print cirillic letters with Zebra 170 Xi II printer?
Yes this is possible. The PN# is G46999-0801 for Cyrillic Font CG Times.
Oct 14, 2010 | Zebra 170Xi II Thermal Printer
140Xi II Thermal Printer: how can I put my zebra xi-140 printer in self clea...
There is no such thing as self clean mode. get a cotton swab soaked in 90% or stronger isopropyl alchol and wipe the print head. be careful not to scratch.
May 16, 2010 | Zebra 140Xi II Thermal Printer
Clear print job on Zebra printer
Simply press the PAUSE button then press CANCEL. If you have sent a batch of 500 labels, though, you will have to press CANCEL 500 times. I usually just turn the printer off, cancel the job in the printer driver status box, then wait for all of the error messages to pop up.
Feb 24, 2010 | Zebra 170XiIIIPlus Thermal Label Printer
Hi, I have a zebra 110 xi||| plus which is printing extra labels.
Did you design the label? Do you have any control over the label design? This is usually a sign that the printer is trying to excede the page limit (usually by one dot row) and is going to the next label to finish. By making the label length slightly smaller, you can stop this.
Mar 20, 2009 | Zebra 110Xi III Plus Thermal Printer
Only printing 1/2 a label
recalibrate the printer in the set up.
Don't just do a quick cal from the front panel.
Make sure your driver is the correct dpi zebra driver, either zebra or my preferred seagull scientific.
by .5 of the label, do you mean width or heigth.
If it is heigth, check to make sure you are set for top of print correctly. Also you will have to back feed for a label that short.
Feb 24, 2009 | Zebra 110Xi III Plus Thermal Printer
Zebra 170Xi II Thermal Printer Logo
395 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
