Question about Konica Minolta Office Equipment & Supplies
Error code F-46-11 in my photocopier konica minolta 7035
After paper jamming before the fuser heater an error code F-46-11 appears on the lcd panel,how can I fix this trouble?
I do appreciate your effort to help me sir,but if I do accept your offer which is the premium plan which I understand I have to pay,my problem is I do not know how to pay you,if through credit card I don't have it.So what I did was to brought my machine to the dealer where I bought this unit and their technician fix it.What went wrong was that the A/D conversion board has something wrong in it, so the tech'n. took up a working conversion board from a good unit and replaced it with the faulty one.Tried it and ok. They charged me for that conversion board with 95 dollars.So what's your comment on that sir? May I know soon?Thanks anyway.
Posted on Feb 11, 2009
  • LUCIEN CELESTE
    LUCIEN CELESTE May 11, 2014
    ERROR CODE F-46-8 IN MY CPIER
Media jam fuser
replace the fuser unit. and replace the transfer roller and belt,
Jan 30, 2014 | Konica Minolta Magicolor 2530 DL Laser...
How do i fix error code C-3502 on a konica minolta bizhub500 photocopier
C 3502 - fusing high temperature abnormality.Check the fuser unit electrical components,wires,thermistors,thermofuses,heater lamps.To reset the error code turn OFF the copier.Press and keep pressed the function key and turn ON the copier.Keep pressed the function key until Trouble reset message appaire on display.Release the function key ,touch the message and turn Off and ON the copier.
Dec 27, 2013 | Konica Minolta bizhub C450P Laser Printer
My copier is konica minolta bizhub 210 have problem error code M1. please help me solution.
My Friend You must do general service in your photocopier and then you must program your machine.
Sep 29, 2010 | Konica Minolta bizhub 180 All-In-One...
I have a Konica 7035 that has code F-35-6 show up. We found a major paper jam, removed it after taking apart part of the copier but the code remains. Any advise? Also, where can I find a manual for this...
Hello sir; Here is the way to reset this error code; press and hold down 25 while you turn on the machine, chose 1 for software switch, use up/down key to select dipswitch 3, and bit 1, then change 1 to 0 by pressing ''off".
Jan 10, 2010 | Konica Minolta DiALTA Di200 Copier
Frequent paper jams with my Konica 2223 photocopier
I wish I could help you, You need to call for service for your copier. An authorized dealer or Konica minolta branch service in your area. You might need a fuser unit that the upper separating claws disloge or broken, exit paper detect actuator is broken or disloged, or you need a new developer.
Feb 05, 2009 | Konica Minolta DiALTA Di200 Copier
A 46-11 code indicates a communication failure between the A/D converter board and the main control board. Likely a bad or poorly seated ribbon cable. Try to reset the machine by turning off the main power switch on the side of the machine for 10 seconds and re-powering up. If the problem persists you will need to call a technician.
Feb 04, 2009 | Konica Minolta DiALTA Di200 Copier
Konica minolta bizhub 162 photocopier paper jam problem
tenho um problema de paper ja open 1st side cover,m o que fazer
Sep 02, 2008 | Office Equipment & Supplies
Konica Minolta Di251
Could be that it is printing a legal print on letter paper. This causes a timing error which appears as a jam. If it is accordion folding behind the exit rollers the paper could be hanging on the exit sensor flag. If it accordian folds in the fuser then the fuser needs replacing.
Jan 04, 2008 | Konica Minolta DiALTA Di200 Copier
Konica photocopier
My service info doesn't go back that far either, but this procedure should work to reset the code. However, I would make sure there's no toner build-up on the fuser thermistor or thermostat first, otherwise the code will reappear.
Here's the instructions on clearing the code:
Enter the 25 mode by holding down the 2 and 5 keys while turning on the copier.
Press the P key, then enter 47, then press P again.
Enter 0 and press the Print key.
Turn the machine off/on to exit the 25 mode.
If the code reappears, then theres a problem. If it doesn't, you're good to go!
Nov 11, 2007 | Konica Minolta DiALTA CF910 Copier
Konica minolta EP2010 error code c05
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of the 220V. Immediately the malfunction code (error code) of "C05" appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found the "Trouble Reset Switch" (not shown in the user manual) by opening the upper back panel and pressing the small black button in the lower right hand corner of the middle circuit board (green).
It worked perfectly!7df26b9.tif
Nov 08, 2007 | Konica Minolta DiALTA Di200 Copier
211 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
