Question about Philips Magnavox 9P6034C 60" Rear Projection Television
My big screen projection philips tv screen is bleeeding
My big screen projection tv screen is bleeding red and blue on the edges
  • 150 Answers
Mark, if red & blue are seperated from the normal image then the convergence circuit has failed, this means the IC`s will have to be removed and replaced as well as any resistors that may have burned when the chip(s) went bad, the alignment that must be performed after the new IC`s are installed can be a pain especially without the service manual, I`d advise a tech for this one, video-tek
Posted on Feb 04, 2009
Remove purple haze around edges
The set needs to be focussed and reconverged. The red and blue images combined make a magenta/purple image. Adding green makes it white. Depending on the type of TV, if it's a CRT projection TV then there's an electronic focus control for each of the three tubes as well as the mechanical adjustment of the optical lenses. Given the description, then I'd have a look at the electronic focus first. A sudden shift in focus suggests that something in that circuit has given out. This would cause the red and blue images to go soft enough to create a halo around objects on screen.
Sep 12, 2014 | Televison & Video
My big screen magnavox tv shows double lines red and blue
Model number listed here unlikely to have this issue which sounds like a convergence problem.
Oct 21, 2012 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My big screen tv shows only red green and blue. the colors are separated. what is wrong with it
the convergence circuit needs repair. You can get the convergence repair kit from which contain the parts and the CD with instructions.
Sep 22, 2010 | Philips Magnavox 9P6034C 60" Rear...
The screen on my tv has too much red and green,how can i fix this?
Your blue tube coolant has gone bad and is opaque now so no blue. this is common in philips old big screens. Can be cleaned and refilled with coolant. repair costs vary area to area. I would do it in 240 to 280 depending on the pickup and drop distance and model number. They generally need this between 5 to 8 years. Its not a DIY project and needs professional help. Check it out at for more FAQs and costs of repairs. Thanks if you voted.
Mar 24, 2010 | Philips Magnavox 51MP392H Rear Projection...
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
I have a philips big screen tv that has double color around edge. iI was informed it was convergence integrated circuit were is that located on the set
It is located internally and can be identfied by looking for the large heatsinks (aluminium) the ICs (two of them) would be labelled STK...
Sep 18, 2009 | Philips Magnavox 60PP9701 60" Rear...
My 51 inch Magnavox rear projection has red and green overlapping
the coolant is bad inside the blue and green pix tubes-to verrify this you can remove the front edge of the screen(it pulls off-one edge at a time-take out screws to remove screen-after screen is off look down at blue/green tubes pix is bad or not there
Sep 07, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips 50p8341a - the red converges, the blue does no move. the screen is all reddish with orange lines in it. the sound is ok. took the back off and the red and blue big lights are on, but the other big...
Hi, convergence IC`s have failed, set is usually a good one, call your local tv shops and get a price to replace the "convergence IC`s ", good luck, video-tek
Jul 01, 2009 | Philips 50P8341 50" Rear Projection...
55 inch Philips
I have 50" philips magnavox big screen. I recently started to have a problem with the edges of my tv. They became blurry. the center of the tv is clear and the edges are blurry. what should I do to fix this problem.
Sep 06, 2008 | Philips 9P5034C 50" Rear Projection...
Philips big screen projection tv
sounds like the Convergence ICs are getting ready to go. Does it appear as a outline almost 3D? If so its convergence if its more like a glowing halo its coolant in the blue CRT that needs changing.
Jun 20, 2008 | Philips 51PW9363 51" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
80 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
