Question about Canon MultiPASS F50 All-In-One InkJet Printer
Displays wrong cartridge when ink tanks are fine
Have tried cleaning and it works for a little while
    Problem Solver:
  • 7 Answers
If the poblem is not with the ink tanks, then the print head may be defective. This happened to my MPF30 in 2004, so I replaced the print head, which holds the ink tanks. You may contact Canon at 1-800-385-2155 or at www.usa.canon.com/consumer/controller?act=SupportIndexAct
Posted on Feb 22, 2009
How to refill a canon lbp 2900 printer cartridge
  1. Remove the old ink jet cartridge from the printer following the manufacturer instructions. Close the lid on the printer to keep it free from dust and debris while you are refilling the Canon ink cartridge.
  2. 2
    Locate the ink tank on the cartridge. Put a 3mm drill bit in a drill. Drill a hole in the top of the ink tank on the cartridge.
  3. 3
    Gently insert the needle on the bottle of ink into the hole you just drilled in the ink cartridge. Avoid squeezing the bottle until the needle is completely inserted in the ink tank.
  4. 4
    Squeeze the ink bottle gently to refill the cartridge. Fill the tank with a little at a time until the cartridge is full.
  5. 5
    Remove the needle from the ink tank. Wipe the top of the Canon ink cartridge off with a paper towel. Place a small piece of duct tape over the drilled hole. Rub the tape to remove air bubbles and to make sure it adheres to the cartridge.
  6. 6
    Put the refilled ink cartridge back into the printer. Clean the head of the printer by running the printer software and following the instructions for head cleaning.
Nov 10, 2010 | Canon LASER SHOT LBP-2900 Printer
I replaced the clear ink tank on mx7600 and the message "the clear ink is empty" will not go away nor will it print in black. The brand new Canon brand clear ink can be seen on the ink tank itself and in...
Yeah, me too. I fiddled with cycling the power, removing and reinserting the tank, doing maintenance tasks like cleaning the jets, yadda, yadda, no dice. New full Canon tank displays empty. Boo.
I figured "What the heck, I'll try printing anyway" and sent a test page on plain paper. It warned me the tank was empty, then did a bunch of those cartridge moves it likes to do (you hear the carriage moving around cleaning or something). After like 90? seconds of cleaning noises, it figured out that the tank was full, the status went to full, and it printed the page fine.
So my advice is, try printing a page anyway.
Oct 20, 2010 | Canon PIXMA MX7600 Multifunction inkjet
How to refile the cartridge of canon pixma ip1300 printer
Instructions :
  2. Locate the ink tank on the cartridge. Put a 3mm drill bit in a drill. Drill a hole in the top of the ink tank on the cartridge.
  3. Gently insert the needle on the bottle of ink into the hole you just drilled in the ink cartridge. Avoid squeezing the bottle until the needle is completely inserted in the ink tank.
  4. Squeeze the ink bottle gently to refill the cartridge. Fill the tank with a little at a time until the cartridge is full.
  5. Remove the needle from the ink tank. Wipe the top of the Canon ink cartridge off with a paper towel. Place a small piece of duct tape over the drilled hole. Rub the tape to remove air bubbles and to make sure it adheres to the cartridge.
  6. Put the refilled ink cartridge back into the printer. Clean the head of the printer by running the printer software and following the instructions for head cleaning.
Good Luck!
Aug 28, 2010 | Canon PIXMA iP1300 Printer
Printer 5510
If you use your printer occasionally, it might be that the print head on the cartridges is clogged. I don't know what was serviced, but if your cartridges haven't been printing for a while, that is surely your problem. You can try this:
  1. Try cleaning the print cartridge from the Maintenance utility by following the steps below:
    1. On the all-in-one front panel, press Setup (or Menu) repeatedly until "Maintenance " displays, then press Enter .
    2. When "Clean Cartridges " displays, press Enter .
    3. At the end of the cartridge cleaning cycle, a page will print. Examine the page to determine if the problem is corrected.
  2. If the problem still exists, clean the cartridge following the directions below in the "Clean under the cartridges and the carriage " section below.
  3. Verify that the ink cartridge is not low on ink by checking the estimated ink levels as indicated in the "Colors on printout are wrong or fade in and out while printing " section above.
  4. Replace the print cartridge for the color that is not printing correctly.
Mar 05, 2010 | HP 5510 4-in-one Printer
All 8 new ink cartridges, new MT tank, nothing prints. it goes thru the motions of rinting, but no little to no ink is on paper, less and less ink each subsequent print. Most recent print has a hint of...
take your ink cartridge out from your printer. you can see at the ink carriage there are little pipes where the ink usually flow from cartridge. If head cleaning and power cleaning does not work, then try to clean those pipes by using 96% alcohol fluids and **** the pipes using something.
Sep 12, 2009 | Epson Stylus Pro 4800 InkJet Printer
Installed #8 M(magenta ink cartridge) New ink tank.
The problem can be one of the following:
  1. You have a faulty cartridge chip (return to purchaser and request a replacement)
  2. The chip is soiled (ink or similar is causing the connection to fail) so try cleaning the chip
  3. The chip is not properly mounted on the cartridge (maybe skewed slightly or similar). If so try straightening out carefully and then re-inserting.
Canon have been known to send out cartridges with bad chips so you should contact them if you bought a proper one and they'll sort you out.
Mar 09, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Printer error message: does not recognize cartridge
u may buy a wrong type of catridge for ur printer,the model may be slightly differ from ur printers required model so u check the catridge model which is absolute for ur printer.
Sep 03, 2008 | Canon BJC-85 InkJet Printer
Printer will not print black ink
Hi please try these steps:::
Right-click the printer icon, and then select 'Properties'.
2. Click the 'Maintenance' tab, and then click 'Deep Cleaning'.
3. Select 'All Colors', 'Black' or 'Color' for the print head to be cleaned.
4. Read the message displayed, and then click 'OK'. The power lamp blinks and print head deep cleaning starts. (Do not perform any other operations until print head deep cleaning is complete. Print head deep cleaning takes about 1 minute.)
IF ABOVE STEPS DOESN'T WORK TRY THESE STEPS BELOW
Check ink tank vent hole The ink tank requires air to flow through it so ink can move from the reservoir to the print heads.
  1. Confirm there is no orange tape across the top of the ink tank
  2. If the orange tape is as shown in Figure (1), it is properly removed.
    *BCI-3's shown in this example.
  3. If the orange tape is as shown in Figure (2), remove the remaining tape to the level shown in Figure (1).
  4. Make sure each ink tank is snapped into the printer.
    IF THESE STEPS DIDNOT WORK THEN YOUR PRINTER NEEDS REPAIR(You might need to change the printer head.)
Jun 09, 2008 | Canon i850 InkJet Photo Printer
Printing from wrong cartridge
Basically on that issue try to adjust the settings on the printing mechanism, maybe your settings when printed a photo is just for a black and white,,but usually host cartridges that comes in the box, have little amount of ink its just for testing the product if it works fine..or try to go to control panel,printer and faxes,right click on the icon->properties->print test page...after that on the same process again go to printing preferences and try to clean the cartridge.okiez...hope this can solve the issue....have a nice day!!!
Jan 06, 2008 | HP PhotoSmart 7760 InkJet Printer
Error code: U150 The following ink tank cannon be recognized (Cyan)
U150 ink error fixed!
I too was getting the error for unrecognized ink cartridge. Then the little green circ board fell out of the end of the ink cartridge and it hit me that maybe if I put in the little green circ board from the old ink cartridge of the same color, then maybe the ink cartridge would be recognized. It worked! So don't throw out an ink cartridge that still has ink just because of that error and hold onto your empty cartridges in case you need the little green/gold circ boards.
This works!
Dec 26, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon MultiPASS F50 All-In-One InkJet Printer Logo
53 people viewed this question
old marine
old marine
Corne Viljoen
