Question about Oreck Console Air Purifier
1998 Jeep Cherokee sputter, bucks, and stalls
We have rep;aced the fuel pump, crankshaft positioning sensor, coil, pick up plate on the distributor
    New Friend:
    Problem Solver:
  • 5 Answers
Either timing, sparks plugs or distributor cap. I'd do spark plugs and distributor cap first
Posted on Aug 17, 2014
It sounds like the calibration of the flux capacitor is not properly configured and is not in sync with the intercooler. Your Oreck XL won't function properly until you manually open the exhaust hatch, remove the nuclear power cell and replace the plasma coils. It also would help to wipe off the air filter with a rag.
Posted on Apr 07, 2010
Loose Fins on Electronic Air Cleaner Cell
I would use hot melt glue to hold everything in place. The air cleaner works by charging the air particle at the front and there is high voltage on the plates. The polarity of the plate alternates where the first plate is positive, the second is negative, the third is positive, forth is negative, etc .
With first wire in front charging the dust particle, the plate attract the charged dust particle to the plate to capture it.
Jan 14, 2014 | Honeywell (F50F1032) Air Purifier
Renault scenic problems
there is one major prob with renault engine manegment system is the crankshaft position sensor when it goes faulty it can cause strange problems get it changed first its easy and inexpensive to replace. is the eml light on? if so the fault code may relate to a throttle body fault
Oct 21, 2017 | Accel 77135-1 GEN VII Throttle Boddy...
Code po351
Its not the plugs. It is either the ignition coils or the crank sensor
May 06, 2013 | Spectre 2006 Ford Econoline - E250, 4.6L...
ON LOW GEAR MOTOR IS WEAK ,ON HIGH GEAR RUNS OK
Hi, Sounds like not enough fuel, in low gear motor turns over a lot faster, using more fuel, high gear it chugs on a trickle of gas. When i used to work in a garage, the final test was a long steep hill that would show flaws in the fuel delivery system, and everything else to, well worth the extra few minutes time. Also, if the big fuel tanker is at your favorite gas station, you might better keep driving bye, or else you can pay 4 bucks a gallon for mud, rust, and water. There is a sock screen on the pick-up tube in your gas tank, the screen is so fine and dense, that gas will flow easily thru it, but water has to be sucked thru. Suppose there is 4 gallons of water in the bottom of your tank, car sitten still the water is half-way covering the pick-up sock, car is running good. Junior stomps on the gas, then hits the brakes for the stop sign down the street. The water sloshes in the tank, covering the pick-up sock several brief moments, forcing the fuel pump to suck water thru the dense screen, causing all kinds of problems. Up here I have a big ice slab in the bottom of my tank that grows each time i get gas until april. Now I hear that ethenol in the fuel is supposed to cure all that. When I was young all the cars had drain cocks on the bottom of the fuel tank to let the water out. Best Wishes
Feb 25, 2013 | AM Auto Parts 2000 to 2002 VW Jetta Mass...
How do I loosen the serpentine belt on a 2001 Jeep Grand Cherokee 4.7L V8
15 mm socket on 3/8 inch ratchet and push down tensioner will get stiffer and belt will loosen and come off be careful you dont hit your knuckles
Feb 22, 2013 | aFe 2001 Jeep Grand Cherokee - 4.7L V8 -...
My xl15 runs but does not produce ozone. The little Rulien fan on the little ozone maker does not run. the regular fan works though.
You realize this is a really old machine!! The little fan is for ozone level detection, not production.
To see if the machine still will produce ozone
1) Set the switch to manual rather than auto and always run it on manual.
2) Remove the back of the machine and remove the 4" white plates. Check them for cracks, breaks in the mesh, loose mucilage, discoloration, burned spots, excessive grease or nicotine, or particulates such as dust, dog hair, or lint. Clean the plates using a solution of 1 part plain AMMONIA to 1 part warm water. Soak 5 minutes, brush with a soft brush, rinse well, and blow dry. DO NOT use any kind of cloth to dry the plate. Avoid putting fingers on the mesh.
3) If the plates are damaged in any way, call Vollara (new name for EcoQuest) and order replacements. 1-800-989-2299. Use #16618 as the dealer referral number if you are no longer in touch with the registered distributor who sold you the machine.
4) Insert the plates, making sure the metal contact fingers press on them firmly.
5) If none of the above works, most likely the power to those contact fingers is no longer strong enough to arc through the plates.
6) Call customer service, and they'll explain your options.
Feb 10, 2011 | Alpine Air XL-15 Air Purifier
Jeep rpms fluctuate and car dies 1 mile from start-up
could be voltage regulator is faulty or there could be another faulty sensor. You can test any sensor with an ohmmeter.
Nov 24, 2009 | Air Purifiers
Fan works but no light on inside the unit.
The most common problem I have found with Breeze ATs not producing ozone is corroded terminal ends. The second most common problem is the coil that energizes the plate. The terminal ends are easily replaced. If the coil is bad, it is my understanding that Ecoquest is no longer servicing the Breeze and I don't know a source for them. Another possibility is that the contacts which touch the plate are not making firm contact.
Aug 31, 2009 | Ecoquest Breeze AT Living Air Purifier
Oreck Console Air Purifier Logo
137 people viewed this question
Top Oreck Air Purifiers Experts
Jerry Greenberg
Jerry Greenberg
Are you an Oreck Air Purifier Expert? Answer questions, earn points and help others
