Question about Sharp AL-1655CS Copier
Grinding noise at startup and printing, AL-1655CS
I just bought a used AL-1655CS scanner/copier and when it starts up it makes a horrible grinding noise. It does try to print out a copy but parts of it are unreadable, compressed together. From the sound of it I would guess I have a stripped gear somewhere in there. I am going to take it apart and could use some advice on what to do and any shortcuts there may be. I took the cover off the back and see a few motors in there, that's where i'm going to start. I bought a new toner cartridge and tried that hoping for the best but that was not it. Is there a common problem with a gear in these units, I swore I saw something a few days ago, can't find it again. Thanks in advance if you can help!
  • 1 more comment
  • Greg Koons Feb 04, 2009
    no paper stuck in there, it does print, but not well.
  • Greg Koons Feb 05, 2009
    No, nothing like that, it still puts paper out but quality is very bad.
  • ewagarg Mar 17, 2009
    I have the same problem of having terrible noise. Didn't force it to print to further damage it. Anyone has any idea on how to fix it? Or is it worth fixing?
    Sergeant:
    Champion:
  • 373 Answers
Is there some paper or something inside
just a thought
Posted on Feb 04, 2009
Changed the ink cartridge and drum. now it makes this loud clicking noise during printing
hope you removed all the packing material from the drum before you installed it.
Apr 23, 2015 | Sharp AL-1655CS Digital Laser Copier...
L1-00 Sharp Al 1655cs
scanner feed trouble, turn machine on and off , if problem persists then check enchoder strip under scanner glass and scanner connection
Jun 30, 2014 | Sharp AL-1655CS Laser Printer
HI. My Sharp AL-1655CS Laser Printer is making an extremely loud noise when printing and when the paper comes out its all jammed like an acordion. Can u please help me?
It's going to be the fusing unit that needs to be replaced. It's also a good idea to replace the gear in the machine that drives the fuser at the same time. Both are available here: http://olsonbros.com/sharp/specs/al1655cs.html
Sep 02, 2011 | Sharp AL-1655CS Laser Printer
My boss has a Sharp AL-1655CS Copy Machine and it makes this awful, screatching noise when I try to copy anything. Now the System Error Code L1-00 shows up. Not sure what to do.
Your problem on scanner unite.May be your copier is now lock position.
Solve:Unlock position.Left side under copy Board.Then solve your problem.Or study your copier user manual.
Jan 12, 2010 | Sharp AL-1655CS Copier
Cannot scan using Sharp AL-1655CS
Make sure that you install the driver for your operating system. Check the stop of the scanner under copying table to the left.Do installing the equipment from panel of management. Check in "system" of the "panels of management" consumption resource of your printer and scanner. The Driver of the scanner is fixed from printer apart. Arouse update the drivers in accordance with your operating system.Windows or Vista or Linuks on put www.sharp.com
Oct 07, 2009 | Sharp AL-1655CS Copier
I need the scanner/copier part of the driver CD - Sharp AL-1655cs
I'm not sure where you downloaded the printer driver but the Sharp website has a download link to the printer and scanner driver according to their website.
http://www.sharpusa.com/products/TypeSoftware/0,1086,20,00.html
Aug 20, 2009 | Sharp AL-1655CS Laser Printer
LOUD GRINDING NOISE
The black dust is toner. Be carful as it is carcenagenic (dont get it on your skin) you will need to dispose of the leaking toner cartridge and get a new one. also you will need to clean the printer very carfully to get rid of the spilt toner. A combination of spray duster and a toner hoover are the best way. do not use a normal hoover as you will kill it.
It is always possible that you have done serious damage to the printer using a non standard toner cartridge. I would recomend getting a qualified person to give the printer a good service.
Jun 03, 2009 | Sharp AL-1655CS Laser Printer
Sharo al 1631 makes clicing noise and does not
Sounds like your scanner is jammed or the scanner motor has failed.
If you are so inclined, turn the power off, you can remove the glass and try to move the scanner by hand, if you can't move it then it is jammed, if you can move it to the middle and turn the machine back on, does it return it to its home position? if so, the motor may be OK, but the control board may have a problem, if not, the motor have likely failed.
Hope this is of some help.
Ed
Apr 30, 2009 | Sharp AL-1655CS Copier
Canon PIXMA 530 grinds away
I had a persistant grinding noise about 30 seconds after the printer finished printing. It's been going on about 2 months. I did one thing which seemed to work. So try opening the cover on the back of the machine by lifting upward on the gray lever in the middle of the back of the machine. Leave this cover open during and after printing. The grinding noise went away.
Jan 11, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Hp psc 750
Very common problem with this model, the gear that drives the fuser (the hot part) breaks. If you are not a tech I would bring it into a shop. Also ask them if they can replace just the gear and not the whole fuser. (much cheaper)
Sep 20, 2007 | Sharp AL-1655CS Laser Printer
Sharp AL-1655CS Copier Logo
153 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
