Question about GE Spacemaker JVM1640SJ Microwave Oven
Internal fuse needs to be replaced
It is a 15 amp ceramic time delay fuse, 3/4 in long, 3/16 in diameter. I can't find it anywhere. Bussman doesn't list it. Any ideas?
  • 360 Answers
Radio Shack
Posted on Feb 04, 2009
Fuse Specifications
Suresh,
Most of the time you will need either a 15 amp or 20 amp fuse for your microwave. You will want a ceramic fuse and if you still have your old one, the amp rating and all info you need will be stamped on one of the silver collars at each end of the fuse. Hope this helps!
Jul 09, 2015 | Microwave Ovens
I replaced clock panel turn power on nothing is there a code
If no display---you may have a bad fuse. It should be located behind the control panel. The fuse will look like the old auto glass fuses about 1/4 diameter and 1 1/4 inch long but made out of a ceramic material you can't see through. Color could be white--brown or a gray color. Amp size will be stamped on the end usually 15 or 20 amps.
May 12, 2015 | Kenmore 4888 Elite 30" Built-In Microwave...
Blowing breaker
In general house hold circuit breaker of the house is 15 Amps or 20 Amps.
Either you have defected (weak) circuit breaker and wiring or bad Microwave oven.
The 99.99 % house hold Microwave ovens pull less than 15 Amps. They may have internal ceramic 15A fuse or 15 Amp internal circuit breaker.
To isolate your problem:
1. Plug your Microwave oven to different areas (different electrical circuit) if the different circuit breaker still trips... your Microwave oven has a short - Most of them has a small ceramic fuse 15 amps fuse.-also check some inter lock switches at door .
2. If the Microwave oven works Ok then you may have:
2a. You may overload the existing electrical circuit, try to unplug some other appliances
2b. You may have bad electrical outlet receptacle (Replace it with the same type , - may need helps from licensed electrician)
2c. Weak or defect house hold circuit breaker. (Replace it with the same type , brand - may need helps from licensed electrician)
Jan 24, 2014 | Goldstar Microwave Ovens
I have a blown internal fuse on my JennAir M170b microwave. The fuse holder says 250V, 15A fuse, but the fuse that was in there is a 125V, 15A fuse. The micro plugs into a normal 110V circuit. Which type...
The information on the fuse is the maximum rating. The holder may not match the rating.
The 'A' is the very important part of the size. You will need a 15 Amp fuse. The best fuse to use is 'ceramic'. You can find them at Radio Shack in the back of the store there are drawers with electrical parts.
15 Amp ceramic
Jun 10, 2010 | Jenn-Air M170 Microwave Oven
Spacemaker died while operating with nothing inside
your ceramic internal fuse blew, you can get them at most hardware stores its either a 15 or 20 amp ceramic fuse, then if this blows again chk your h.v. capacitor,h.v. diode,or the magnetron tube for defects
Oct 27, 2009 | GE Profile Spacemaker JVM1871 Microwave...
Replace fuse on GE Advantium Speedcooker Oven
there is a fuse located underneath the outer cover, its called a ceramic fuse and is of cartridge type about 1" long by 1/8" diameter and has a white body and 2 silver ends and you can take it to a hardware store they have them but make sure to get correct amperage rating 15 or 20 amp
Sep 05, 2009 | GE Advantium 120 Convection/Microwave Oven
Ok , I replaced the fuse checked all connections and checked plug for power ! Still my lg lmv1630st will not show any power at all . What gives?
by replacing the fuse you meant the house circuit fuse or the microwaves internal fuse? and by conncetions your talking the internal wiring inside the case of the unit or wiring from the plug? if not its your 15 or 20 amp ceramic fuse inside the unit,if thats blown replace,but chk h.v.diode,v.v. cap,triac,control board, mis-adjusted interlock safety door switch,and lastly the mag could be defective
Aug 15, 2009 | LG Over-the-Range Microwave
Microwave died
your microwaves internal ceramic safety fuse is blown most hdwg stores carry them they're a 15 or 20 amp fuse,dont replace w/any other type of fuse,but first find out why oven blew the fuse
Aug 13, 2009 | Whirlpool MH7140XF Microwave Oven
Fuse is blown
It's 20mm !!
It will have failed for a reason.
At 15amps, I'm guessing your Microwave has a grill too.
It could just be a bulb failure causing the fuse to blow.
Replace it and try again.
If the oven works but no light, that was the cause.
Apr 26, 2009 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
74 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
