Question about Syntax Olevia 537H Television
Channel selector does not work; can not auto tune
Olevia 537 TV has suddenly decided to not respond to channel up-down button on remote; I think I chose "Showroom" instead of "Home" at initial start-up; can't do anything to auto-tune channels, etc.... thanks, GD
  • Anonymous Apr 07, 2009
    I have the exact same problem! The ch up down buttons dont even work on the tv! I just bought a couple new remotes to see if I can sync them and maybe the channel up down buttons will work on them but it just wont work! ill keep trying...
Sorry not be able to solve the problem. I have exactly the same problem. So it is not related to anything you've done. Something faulty in the TV. It happened after 1.5 years in my case. Any tech support link appreciated
Posted on Jan 12, 2010
  • argos01 Jan 12, 2010
    Well I did some troubleshooting and I have the answer (at least in my case). Check list of channels by clicking Enter. If no list of channels it means that you have initialized the source and delete channels (no up or down in the list since no list).
    Do a rescan and you should be good to go.
    Enjoy
    Sergeant:
    Champion:
  • 373 Answers
Try the battery first
Posted on Feb 04, 2009
  • jim beckwith Feb 04, 2009
    try the battery first
I Need a remote code
Have you checked online with manufacturer of the remote? Remote codes are usually available.
May 08, 2014 | Frisby GPX HT219B Home theater system
I can't get my Olevia tv (537-B11) to scan for channels
I don't know this model of TV, however, you may find that you need to use the Source button on the remote to cycle through the available inputs & select digital tuner as the input source before you press the Menu button & go into the setup section.
Jan 05, 2014 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
I have two remotes. One is for the Olevia TV and one is for the cable - Smart City. I only use the Olevia TV remote for powering on and off and volumn. The channel down button on the TV remote got...
Make sure your cable box is on and on a channel that you normally watch so that we know there is video being transmitted to the TV,then useing the remote that came with the TV press the button that is labeled " input" or " source" multiple times until you see a picture back on your TV screen. Good luck and Happy Holidays!
Dec 23, 2009 | Televison & Video
Olevia not searching channels
try the following..
Q. Why are the menu settings that I changed not being saved? A. The TV is in Showroom mode. The following steps will help you switch to Home mode.
  1. Press Menu button from the remote,
  2. Press Down arrow key until you see the word Picture, then press the Right arrow key,
  3. Press Down arrow key until you see Mode, then press the Right arrow key,
  4. Press Down arrow key until you see Power Up, then press the Right arrow key,
  5. Press Down arrow key until you see Home, then press the Enter key,
  6. Press Menu button four times to exit out from the OSD Menu.
***Showroom mode is designed for retailers to display the TV and to protect from shoppers changing the settings that are predetermined for shelf display environment.***.
Q. Why does my TV display "No Signal" or "Channel not in List"? A. Channel search needs to run the very first time of use or after the default settings are loaded from the OSD menu. The following steps will guide you through the process.
  1. Press Source button until Tuner is visible on the upper right corner,
  2. Press Menu button from the remote,
  3. Press Down arrow key until you see Setup, then press the Right arrow key,
  4. Press Down arrow key until you see TV, then press the Right arrow key,
  5. Press Down arrow key until you see Auto Channel Search, then press the Right arrow key,
  6. Press Down arrow key until you see Air (for antenna; select Cable if you have cable service), then press the Right arrow key. The scan process will start.
  7. Wait until the process is complete then you will be able to select the channel you like to watch.
Jul 29, 2009 | Televison & Video
Tv is in showroom mode cant change it
Jun 19, 2009 | Olevia 227-S11 27 in. LCD TV
Olevia 537 - wont select HD channels
I assume the control panel on the tv still works correctly? If so i would think you have a remote problem. If thats the case let me know I will send you a link to instructions to repair your remote.
lone99star
Jan 09, 2009 | Televison & Video
Unlock Olevia remote control
Nov 14, 2008 | Olevia LT42HVi 42 in. LCD Television
AUTO PROGRAMMING T.V.
Your TV is in Showroom Mode - to change:
Menu>Picture>Mode>Power up>Home
Then go back and autosearch channels.
Jan 10, 2008 | Olevia LT42HVi 42 in. LCD Television
Tv signal locked
A: The TV is in Showroom mode. The following steps will help you switch to Home mode. 1) Press Menu button from the remote,
2) Press Down arrow key until you see the word Picture, then press the Right arrow key,
3) Press Down arrow key until you see Mode, then press the Right arrow key,
4) Press Down arrow key until you see Power Up, then press the Right arrow key,
5) Press Down arrow key until you see Home, then press the Enter key,
6) Press Menu button four times to exit out from the OSD Menu.
Dec 10, 2007 | Olevia LT27HVX 27 in. LCD Television
27 INCH OLEVIA LCD FLATSCREEN
I had the same problem....
The CC button should work now.
Sep 07, 2007 | Olevia LT32HVE 32 in. LCD Television
Syntax Olevia 537H Television Logo
691 people viewed this question
Top Syntax Televison & Video Experts
Computer Repairing
Computer Repairing
Kolbrun...
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
